Question about HP DeskJet 5650 InkJet Printer
PRINTING LEGAL SIZE
WON'T PRINT LEGAL SIZE
headstrong
  • 233 Answers
SOURCE: printing error on legal size paper
Make sure you are selecting "legal" for the paper size in the program you are printing from
thanks for rating
Posted on Jan 10, 2008
SOURCE: tray output
You should configure TRAY 1 as Legal only.
and Tray 2 as plain letter.
Specially when you specify from what tray/paper type to print.
This can be easily configured from the Printer Properties within the Printers and Faxes section of the Control Panel.
Posted on Jan 26, 2008
  • 48 Answers
SOURCE: cannot print to legal size paper format
There could be a few issues causing this problem.
1. Your document size on the actual document you are attempting to print believes it is letter (which is the default).
To change this setting, you must tell the computer you wish to print on legal paper.
To do this in MS. OUTLOOK:
Put the curser at the top of the page
then...under 'File-Print-Preferences-Layout-Advanced-Paper size-change to legal (from Letter'
-slightly tedious...but follow along and this should help
2. The printer needs to be adjusted to hold the legal paper.
Open up the legal tray to adjust the paper holder to hold the paper snuggly...it slides roughly.
Hope this helps..if you need more assistance please ask...also please rate my solution.
PLEASE note that anything other than a FIX-YA is actually a negative rank...and will lower my success...I didn't make the system...but that is the way it is in FIX-YA.
thanks
bearb
Posted on Nov 10, 2008
websnail
  • 419 Answers
SOURCE: Printing duplex and legal size.
I don't have legal size paper to test this with so it's a theoretical point but it looks like the printer will not do duplex in anything other than:
  • A4
  • Letter
  • B5 (JIS)
  • Executive
You can always print in duplex manually which is always an option regardless of paper size.
Hope that helps.
Posted on Mar 03, 2009
  • 191 Answers
SOURCE: can't print proper legal size documents
please you aply the comand control p and you go the property select
and ok. you so the paper select and ok and you so the paper size
in select legal is ok and ok
and aply print legal size print ok
Posted on Sep 15, 2009
Brother 9840 print on legal size paper
it seems that on your model you can only use legal size paper on tray 1 & 2, then you have to set the paper size.
here is a link to instructions for your model.
http://download.brother.com/welcome/doc002258/mfc9840_uk_usr_b.pdf
Feb 19, 2015 | Brother MFC-9840CDW Laser Printer
Canon IR1022if copier can't print in Legal size(8.5inx13in) using bypass or even paper cassettee
Did you trying hitting an Ok button, green button, etc to confirm legal size paper, maybe it wants you to confirm paper size. Also legal is 8.5x14, did you select legal or enter the size as a custom page?
May 22, 2014 | Canon IR1022IF 220-240 VOLT, 50/60HZ
When I print a "letter" size document I have to push the green button to make it print. If it is legal it prints automatically to the legal tray.
Obviosly your magazine (Place of taking paper) of the printer is set to legal. The lights is lighting, couse the printer is telling you: You want me to print on letter, but I don have any letter, so please confirm that you want me to print on legal.
In order to avoid this set the printer to all types of paper available.
Jan 29, 2013 | HP LaserJet P2015dn Printer
Lexmark printer won't print on bottom half inch of page
Make sure to set the correct paper size when printing. Letter - letter; legal - legal size.
Sep 21, 2012 | Lexmark Platinum Pro905 multifunction...
My printer won't print letter automatically. It's stuck on printing only legal. If I pull legal tray out it will print letter. But I need it to adjust with alternating print jobs.
Printer wont stop paper, if any page length mismatch,Select page length as any size, as well as while shooting the print command select page length as legal & try it. I feel that teflon not rotating properly, result paper jamming at bottom end. If any paper length faulty printer detects the length give message of mis match..Pl check carefully...
Feb 01, 2012 | HP Laserjet M2727nf Multifunction Printer
I have a printer Canon LASER SHOT LBP 1210 but i can't set up page size Legal thats mean 8.5"x 14.00". Would u pls give me solution how can I get print in the legal size print.
I am Canon LBP 1210 User. canon LBP 1210 laserjet printer not supporting legal size printing. When I give a legal size page printing, there is no response from the printer.Please give a solution.
Aug 22, 2010 | Canon LASER SHOT LBP-3000 Printer
Can't print proper legal size documents
Sep 15, 2009 | HP LaserJet 1018 Printer
  • A4
  • Letter
  • B5 (JIS)
  • Executive
Hope that helps.
Mar 02, 2009 | HP Officejet Pro L7680 All-In-One Printer
Legal size paper on LBP-1210
For printing the Legal Size (8.5′x14′) in cannon LBP-1210, follow the instruction:
Step 1- Go to start
Step 2-printer and faxs
Step 3-select printer(Canon LASER SHOT LBP-1210)
Step 4-go to file
Step 5-select Server properties
Step 6-select creat new form (for legal page)
Step 7-give form name legal 1
Step 8-give paper size width 8.50in, hight 14.00
Step 9-give paper margin top 0.30in, left 0.30in, right 0.30in, bottom 0.30in
Step 10-select save form Step 11-then select advanced
Step 12-select informational notifications for local printers
Step 13-select apply
Step 14-then close
Step 15-select Canon Laser Shot LBP-1210
Step 16-select printer
Step 17-select properties
Step 18-select-select forms
Step 19-select change forms
Step 20-select legal 1
Step 21-select OK
Step 22-select apply
Step 23-select OK
Remember: 1 U need to set paper size (8.5′ x 14′) manually in the word documents and befor printing you need to set in printer properties “Legal 1′ for printing. Print preview may not show the whole page but the printer will print the whole page.
All the best.
PARVEZ [ info(at)parvezbd(dot)com ]
Jun 22, 2008 | Video Cameras
HP DeskJet 5650 InkJet Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
