Question about Electric Mobility Mobility Electric Power Scooter Wheelchair. Heavy Duty
No power output from Rascal 600f from controller
No power output to the Rascal 600f motor but hear click from the relay in the control board. Neutral position micro switch works, and wires have been checked.
    Master:
  • Electric Mob... Master
  • 351 Answers
Put a meter on the Connection to the motor, try to engage the throttle see if any DC voltage is being given. if so does the voltage go up and down?
Posted on Jul 03, 2016
2 Suggested Answers
  • 177 Answers
SOURCE: I needto replace the battery charger on my Rascal 600F scooter
Hi. Most chargers with only two wires, have a small bridge wire from the
black ( negative ) wire to the middle terminal of the connector. This disables the controller while the machine is charging. The charger will still work without this bridge wire, but the scooter will still operate normally.
There are a few different chargers around that have an internal relay that disables the scooter, but these chargers are normally "on-board" chargers.
Good luck. Neil.
Posted on Jul 07, 2010
Incline broken on horizon T61. I put in a new motor and it still goes above 5 and won't stop.
did you run a calibration after you installed. your manual should tell you how
Feb 24, 2016 | Horizon Exercise & Fitness
Rascal Candy Apple. Why did it stop moving while I was driving it?
On the rascal, if your driving along and it suddenly stops, the throttle lever could be bad or the speed control could be bad or both. A battery lead maybe loose. The tiller cable may have slid back causing line interruption.
The flashing 4 indicates current timeout, the scooter may have been going up a steep hill, over heating the motor, turn off and allow motor to cool. then try again. if this happens on flat ground then check the parking brake, it maybe hanging up causing the motor to over work. Other trouble-shooting information for rascal, scooters on my free app.
Scooter Doctor App
Aug 11, 2015 | Health & Beauty
KFI winch won't spool in or out there is power to it I can hear it clicking
If your wiring a remote control to the winch or inside control,,, 4 solinoids type,,make sure the solinoids have ground on the brown wire(warn)...if you don't have a ground all it will do is click,,,even if power is applyed
Feb 19, 2015 | Cars & Trucks
I have a kenmore oven. Just got an F2 error and the oven element will not turn off. Even when powered down, it heats back up when oven is in off position.
Range "Older Style"
F2 Oven too hot Replace relay board (if present) or oven temperature sensor
Range "Newer Style"
F2 Oven temp sensed; over 600F sensed by control in time of day mode, bake mode, or over 900F sensed in clean mode. Ohm test the oven temperature sensor, if OK, change power relay board.
Oct 17, 2012 | Kenmore 40494 / 40495 / 40499 Electric...
My GE GSL 25JFPABS Refrigerator failed yesterday. No Comressor no evap or condensor fan
Fan motor starts with the compressor. Sounds like you need a main board and condenser fan motor. Call GE. It might be covered under warranty. A known issue with certain models. You will also need serial # if you call.
Mar 23, 2017 | GE Refrigerators
Good luck. Neil.
Jul 05, 2010 | Electric Mobility Power Electric Scooter...
My Jenn Air oven W27200B displays F2 error any solutions? Also one of the burners would hang- one worked and the other didnt.
HI. this is a failed oven temp sensor or relay board.
Sep 14, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Maytag Neptune MAH5500BWW Will not spin
maytag neptune washers do have a motor problem and they have a kit to replace the motor and motor controller.
when the motor fails, it wont wash or spin. most units have a 5 year parts warranty and should be replaced with a free part, but you will have to pay an authorized servicer to do this.
if it is over 5 years then i would call maytag and see if they will help you with an authorization for repair.
most of the time they will provide the part for free. just call the 800 # and ask for help. they wont send you the part but might give you some help with the parts.
Jan 04, 2009 | Maytag Neptune MAH5500B Front Load Washer
Gms80904bna
Since you have 24VAC, put a jumper between “R” and “W”, you should hear a relay click from the control board, this is for the inducer motor, if you don’t have 120VAC at the board, you have a faulty control board, it’s the same scenario if you do NOT hear a click.
Hope this helps
Oct 25, 2008 | Goodman GMS80904BNA Open Flame Mid-Size...
Washer's tub will not move
I don't know what the E5E error code refers to but I can think of at least one possible reason for no motor action, even if motor itself is ok and board has been replaced. The relay itself could be faulty with no power from the output side, even if it clicks on. Less likely but still possible would be a faulty overload protector at the motor.
Feb 16, 2008 | Kenmore 43042 Front Load Washer
Electric Mobility Mobility Electric Power Scooter Wheelchair. Heavy Duty Logo
63 people viewed this question
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
