Question about TP-LINK TL-WR642G Router
Tplink lock unable to reset the router, and router stuck on settings icon or lock icon
  • 40 Answers
If there is a physical button on the router(like reset(reset as in factory mode)), just press it for 10 seconds for a reset.
Posted on Sep 02, 2014
2 Suggested Answers
  • 1768 Answers
SOURCE: Must be reset router tl-mr3420
1.You will possibly need to configure the router for what is called "port Triggering"
2. from what I read is that there is no IP via the Hikvision external there fore requiring a new IP each time for connectivity.
Instruction set from the manual states:
To add a new rule, follow the steps below.
1. Click the Add New... button, the next screen will pop-up as shown in Figure 4-40.
2. Select a common application from the Common Applications drop-down list, then the
Trigger Port field and the Incoming Ports field will be automatically filled. If the Common
Applications do not have the application you need, enter the Trigger Port and the
Incoming Ports manually.
3. Select the protocol used for Trigger Port from the Trigger Protocol drop-down list, either
TCP, UDP, or All.
4. Select the protocol used for Incoming Ports from the Incoming Protocol drop-down list,
either TCP or UDP, or All.
5. Select Enable in Status field.
6. Click the Save button to save the new rule.
check the "Local management" in the router
you must allow certain devices to obtain an IP via either MAC address or IP address.
Posted on Sep 12, 2011
I have a problem with my network key i am unable to login into my own network
A few things. 1) Make sure your caps lock is off. 2) You may need to soft reset your router. Just unplug it wait 30 secs then plug it back in and try again. 3) Hard reset it. This will reset it back to factory defaults. On the back of the router hold the little button in for 5 secs and watch the lights blink on and off and the setting are back to the way they where when you bought it.
Jun 22, 2011 | Arris SURFboard SBG900 Wireless Router...
Connection error appears as i connect to the internet in Belkin wireless router in my itouch. I touch on the settings and tried to connect with Belkin. But there's a lock symbol in it. Then I tried to...
It is locked because there is wireless security enabled on it. Do you have the passcode? you can reset by going to the default ip address of the router. There should be no other reason for it not to let you connect and should in fact prompt you for a security key. If you still have problems go to Settings > General > Reset > Reset Network Settings on the deice and then hold the power button until you are prompted to reboot the device and then do so. After this restart the setup process.
Mar 03, 2011 | Belkin Basic Wireless Router
Phone not responding to touch screen stuck on icon section unable to navigate to any of the apps
reset the settings and format phone memory remove the memory card restart the fone and check it if its not solved go to lg customer care
May 23, 2010 | LG KU990 Viewty
Unable to contact router via laptop
What is the Operating system on the laptop ?
If it is XP then in the bottom right hand corner you will find Wireless network connection ( looks like 1 computer monitor). Use that icon to connect to the wireless network.
If it is windows Vista, then in the bottom right hand corner you will find 2 computer monitor icon. Use that icon to connect to the wireless network.
If it is Windows 98/ME/2000 then use the adapter utility to connect to the wireless network.
For MAC you will see the AIRPORT icon at the top.
Check the wireless settings of the router first . Make sure that yopu have all the wireless settings of the router. If you are not sure about the settings, then open the router set up and check the settings.
Click Here for step by step instructions on how to connect to the wireless network and troubleshooting steps
Jan 02, 2010 | Cnet CNBR-914W Wireless Router
I am unable to setup may router. I forgot my password.So I reset the router. Know I am unable to form a new password to setup security and follow through with setting-up my router. Help
You said that you reset the router.
So you will need to reconfigure the router.
You can do it manually. It is very easy.
Click Here for step by step solution
Nov 13, 2009 | NetGear WGR614 Wireless Router
I would like to use my wireless Dlink service on my laptop but I am unable. Can you please help me
Oct 10, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Resetting the siemens router
ok
u can accesss your router with folowing link
http://192.168.1.1
or
http://192.168.0.1
type username as "admin" and password is "admin" or blank or "password"
then first not all settings.
then if u want to reset rourter press reset button for 15 seconds then it reset .
Reset button is in backl sdie of router.
Please let me know.
Jun 11, 2009 | Siemens SpeedStream 2624 (SS2624) Wireless...
My wireless icon on my compaq Presario f500 has disappeared
Checked your router Wifi settings, and if wireless parts is enabled there, and the rest of the settings.
Maybe some joker broke in, happened to me just 4 weeks ago.
Or some software caused factory default. Or ISP forced that resetting WEP and/or WPA settings. The one I have gives out one router wireless (Alcatel) only with locked firmware only they can control :((
May 03, 2009 | Computers & Internet
CANNOT CONNECT TO INTERNET
in the installation manual you have a url you can type in...its something like 192.428.111.1...ect about 10-12 numbers...type this number in the internet browser search window. this will tell you first if you have access to the internet. you should get the settings windows for your router. there you can make adjustments as needed for your rounter unit.once confirmed.
if you are having access to the wireless network you set up the password you set in is obviously incorrect when it was set up. first check the light on the front of the wireless router it should have various light on ..such as power,,usb...dsl...and internet..with the internet light flashing... as a precaution please do a repair connection on your internet access point on the computer ur using..right click the wireless icon at the bottom of your screen if ur using xp..sometimes this repair will be just enough to clear up issues.and allow access.
if this continues...you may need to reinstall the unit...there is generally a reset button (very small) on the underside of ur wireless unit and take the appropriate steps..
gl
K.
Dec 30, 2007 | D-Link 802.11g Wireless Router WBR-1310...
TP-LINK TL-WR642G Router Logo
354 people viewed this question
Top TP-LINK Computers & Internet Experts
Martin Murray
Robert
Level 1 Expert
Are you a TP-LINK Computer and Internet Expert? Answer questions, earn points and help others
