Question about Wacom Cintiq 15X Graphic Tablet
Wacom 15x brightness flickering every 5 seconds
Exactly every 5 seconds, the screen's brightness changes and it makes it really hard to focus on drawing. Is there any setting to change that?
4 Suggested Answers
SOURCE: using colour with wacom bamboo fun tablet on Apple Imac OSX 10.5
Downloaded from Apple.co.uk " Paint Shop" Freeware application. Works really well. Opens up with its own page to draw on and art work utensils to use in the side bar.
Posted on Feb 15, 2009
  • 4 Answers
SOURCE: Pen keeps drawing when I lift it off tablet
This problem commonly occurs due to a stuck "nib" sensor (the sensor that detects pen pressure).
Take out the "nib" (important, so the sensor isn't damaged further) and whack the pen on your desk (or drop it on the floor from 3 feet up). It re-seats the "nib" sensor when it's stuck. If this doesn't work after multiple attempts, then the sensor may be too damaged.
Posted on Jan 19, 2010
sgdemondog
SOURCE: wacom cintiq tablet video isnt working
If you have Windows Xp, try right-clicking on your screen, click 'Propetries', then click the "Settings" Tab, then there will be a picture of two screens - one has a number 1 on it, and the other has number 2. Click on number 2 and raise the "color quality" from Lowest (8 bit) to Highest (32 bit). Also, take the "Screen resolution" up to about less than half way. Then click "Apply". You will get a prompt asking if you really want to do this, so just hit yes. Your screen should turn on immediately after that.
Ps. After you do this, hit "Identify". There should be a giant number 1 on your computer, and a giant number 2 on your tablet.
Posted on Jul 26, 2012
Wacom cintiq tablet video isnt working
Nov 16, 2011 | Wacom Cintiq 15X Graphic Tablet
Grip pen not working correctly
clean and clear the side pannels sensors
Dec 14, 2009 | Wacom Cintiq 15X Graphic Tablet
My Cintiq 21ux is not recognized as a 2nd monitor it just works as a huge wacom tablet with a black screen.It recognizes the pen as a mouse on my other monitor I get the same message No /sync /go to...
HI, I've had a similar problem. This solved it for me. Connect the cintiq first to a dvi to vga adapter, then connect that to apples vga to mini display port adapter.
worked for me so I'll keep my fingers crossed for you.
Jun 06, 2009 | Wacom Cintiq 15X Graphic Tablet
Sony KP75HW40 unstable red. (not the usual problem)
I would suggest either the Focus block or the RED CRT drive board either one of those items could cause the symptom. A defective CRT could also, but a shorted CRT doesnt usually go back to being normal
Mar 16, 2009 | Sony KP-57HW40 57" Rear Projection...
Duel Monitor Cintiq Problem... pen affecting wrong monitor
under the calibrate tab in the wacom tablet properties window there is a drop down window with a list of monitors. Change that to the Cintiq
Jan 19, 2009 | Wacom Cintiq 15X Graphic Tablet
Flaw on LCD monitor
This is normal. It may be distracting, but what it is is light. If you notice, it happens when there are bright spots, lights, reflections. These distortions will show up in video so try to avoid aiming at bright things while in video mode. Another type of flicker will happen mostly in florescent light.
Before CCD image sensors, video camera used tubes and aiming them at the sun or bright objects would burn the tubes permanently so cameras have come a long way, but by the nature of cameras being devices that record light, it is hard to eliminate that effect altogether (similar to red eye...just can't be a perfect science due to human nature of having blood vessels in the back of their eyes that when bright light is shined into them, their pupils open and the red color is reflected and shows up as red eye...this is best fixed in a photo editing program. It is hard to totally prevent, but changing angles and not shooting directly head on at subject helps). But I digress...
If it is really distracting for you, here is the one thing I found helpful; recompose the shot slightly by moving yourself, the camera, the angle (doesn't have to be dramatically different, but try to have the sun or light source behind the camera). As you move around, continue to push the shutter halfway down (each time not continuously) to bring subject into focus (getting your green box or boxes that indicate proper focus). Sometimes the lines will disappear if you change your shot even very slightly.
Hope this Helps!
May 31, 2008 | Canon PowerShot A720 IS Digital Camera
Picture Brightness Flickers
could be one or more of three things.
1.could be the crt itself.(sony had a bad bunch of crts for this model)
2.could be the vertical ic on crt board.
3.could be the focus block
in my experience solutions 2 and 3 are more common....
Oct 19, 2007 | Sony KP-51WS500 51" Rear Projection...
RCA D52W19 (52"HDTV)
The common culprit for this problem is a defective Focus/Screen control block. It is located behind a removable panel in the front under the speaker grill. It is a little black box mounted up along the top of the opening with two rows of three openings for adjustment of the Red, Green and Blue "focus" and "Screen" (brightness) settings. They often get contaminated with dust which is attracted by the high voltage flowing through this block. It is held on by a single screw and has 9 push on/off wires into the back of it. The replacement is fairly straightforeward, just keep track of which wires go where. Leave the set unplugged and powered down for a day or so and the voltages should all have bled away to ground by then.
Aug 01, 2007 | RCA D52W19 52" Rear Projection Television
JVC AV-60D501 I belive it is a 60" full screen projection tv for the last few months the picture has been flickering, Flickering like a VHS with bad tracking. It does this in all imputs, from cable imput...
From what you're describing your focus block is probably failing JVC p/n#129P059050. It's probably also very vibration sensitive. They're about $80.00 dollars and they are also interchangeable with the Mitsubishi focus pack p/n#920p016010. Not a difficult repair - we do about 5-6 a month. Real easy in-home repair. Hope this helps. Bill
Jun 18, 2007 | JVC AV-60D501 60" Rear Projection...
Wacom Cintiq 15X Graphic Tablet Logo
42 people viewed this question
Top Wacom Computers & Internet Experts
toddmat
Level 1 Expert
jasbo
jasbo
William F. Bryant Jr
Level 1 Expert
Are you a Wacom Computer and Internet Expert? Answer questions, earn points and help others
