Question about Fisher Price Power Wheels Kawasaki KFX Ninja Ride-On Toy
Car just stopped working
Battery fully charged def not that cause we have a spare. My son first had a mustang tha stopped working then we bought him a ford truck and it has just stopped also.
    Genius:
  • Fisher Price Master
  • 1,508 Answers
First of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter
Posted on Jun 19, 2012
4 Suggested Answers
  • 50 Answers
SOURCE: The wheel on my sons
http://www.toyservice.ms/Search.aspx?sq=mustang go to this link and select your model number... you should be able to order the part to fix it with no problems... good luck
please rate if this helps.
Posted on Jan 13, 2009
  • 3 Answers
SOURCE: bought new battery for power wheels-charged it for 18 hours and t
It will most likely be the Failsafe foot pedal switch. You can pull that switch out and order a new one through online vendors such as Amazon.com or you can make the repair on the spot by purchasing a "sealed 60 amp starter button" from your local autozone and replacing this for the old one. You will have to make it fit in the old compartment, but that can easily be done with an oversized washer. If this toy truck has three wires going to the pedal switch and most likely it does, disregard the orange one and only connect the white ones and the red one. That fixed the problem on my little one's Fisher Price Power Wheels Escalade. You can also check if the battery is good and if the motors are working by simply connecting each motor to the battery with a pair of gator clips and some cables. <!-- from fixya rte -->
Posted on Aug 10, 2010
SOURCE: my son ford f150 truck
my son's does the same. It will go in reverse but not forward. sometimes if I shift it repeatedly it goes forward for a little while. the shifter feels kind of loose. have you tried replacing it? i found a website that sells them. I think I need to replace it & see if it fixes it.
http://www.householdappliance.com/power_wheels_shifters.html
Posted on Nov 23, 2010
Car wont start has charged battery lights and radio come on new starter. drainging battery even though the battery is fully charged its reading its not tempature gauge reading hot but its not runn
If the problem began when (or soon after) installing the new starter, start checking there. Ensure that all cables to the starter are tight. As a second possibility, if the new starter was actually a rebuilt replacement, the solenoid could be faulty. (I went through three rebuilt starters on my son's truck until we got one that worked properly.)
Mar 06, 2014 | 2004 Ford Mustang GT
Central locking not working on Astra SRi 08
check the battery, try with the spare one, if not contact the dealer
Jun 23, 2012 | Vauxhall Astra Cars & Trucks
Bmw 325i wagon slow starting then totally no turning over at all.All lights work dash is all lit up .Battery is fully charged car has faint click.but still wont turn over.I think it might be the starter...
I would try replacing the battery first. Even a fully charged battery can have bad cells which will cause the battery to not have enough "power" to turn over the starter/engine.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Apr 27, 2011 | 2003 BMW 325
94 MUSTANG GT,STARTER CLICKS BUT WONT CRANK, NEW STARTER NEW POSITIVE CABLE, CHARGED BATTERY, HEADLIGHTS WORK GOOD
When you installed the starter you may have inadvertently put the gears in a bind. Make sure the bendix meshes properly with the flywheel. The bendix is the small gear on the starter that slides out and connects with the flywheel when the ignition key is turned.
Oct 09, 2010 | 1994 Ford Mustang
2006 Ford Mustang GT 4.6 liter can jump off
its most likey your altenator there =s no charge going to the batt
Dec 19, 2009 | 2006 Ford Mustang
2001 mustang gt,all access. work fully charged
I would suspect the starter solenoid has failed.
A starter solenoid (or starter relay) is the part of an automobile which relays a large electric current to the starter motor, which in turn sets the engine in motion. In many vehicles the solenoid also engages the starter pinion with the ring gear of the engine.
The starter solenoid receives a large electric current from the car battery and a small electric current from the ignition switch. When the ignition switch is turned on, a small electric current is sent to the starter solenoid. This causes the starter solenoid to close a pair of heavy contacts, thus relaying a large electric current to the starter motor, which in turn sets the engine in motion. The starter motor is an electric motor that initiates piston motion in a car's internal combustion engine before it can power itself.
Nov 27, 2009 | 2001 Ford Mustang
Will not turn on
Make sure that the hold/lock switch isn't engaged, and make sure it has been plugged into the computer for 3-4 hours to fully charge.
If it still won't work, run a Repair in the Philips Device Manager.
-Tha Mp3 Doctor
Jan 20, 2009 | Philips GoGear SA3125/37 MP3 Player
Ipod nano - stopped working - will not come on anymore
Do the 5 R's suggested in the user's manual first. If those fail, then the player has an internal problem and needs to be replaced.
Sep 03, 2008 | Apple iPod nano
Fisher Price Power Wheels Kawasaki KFX Ninja Ride-On Toy Logo
238 people viewed this question
Top Fisher Price Toys Experts
Bill Boyd
Jennifer Rock
Jennifer Rock
NOEL
NOEL
Are you a Fisher Price Toy Expert? Answer questions, earn points and help others
