Question about Camping, Backpacking & Hiking
Freezing coils on mabe refrigerator - Camping, Backpacking & Hiking
My refrigerator is freezing everything I changed the door gaskets but it us stll freezing sny suggestions
If the freezer is freezing everything, check the coils. A refrigerant leak will cause ice to build up on the coils, not extra ice in the fridge. ... A leak in the compressor or coil will chill the air around the leak as long as it is outside, but a leak into the fridge could cause it to get extra cold.31 Aug 2015
How to Fix a Refrigerator that Freezes Everything - YouTube
https://www.youtube.com/watch?v=gXMJYv6kzKg refrigerator is freezing everything Google Search
Oct 23, 2017 | Refrigerators
Coils freeze
Either your coil is blocked with paper or wrap, or you have a refrigerant leak in the coil and the little bit of gas that's left is flashing as it enters the coil. Make sure that the cooling coil and condenser is clear and the fans are running. That's all you can do without refrigeration tools. Good luck and hope this helps
Apr 22, 2014 | True Refrigerated Sandwich Prep Table 72"...
I have a mabe fridge top freeze! Lately it has being freezing to a point of building scorch and plugging the vent conduicts to the bottom!
sounds like your defrost heater is not working, there is a timer that turns on a electric coil to defrost your coils, either the timer is out or the coil is bad. take the back cover off the freezer and check the defrost coil it is usually obvious if the defrost coil is bad if its not that it is probably the timer that controls it.
Mar 19, 2014 | Sub-Zero 650 / O Bottom Freezer...
Freezer not working but fridge is ok
mabe that heater in fridge not working make sure there is not alot of frost on back panel if there is a some amount in corner then its probly low on refrigerant if its frosted all the way across then its a problem with the defrost cycle really need more info to help any more
Jan 12, 2014 | Hotpoint Refrigerators
My Airconditioner has ice forming and no cooling. can u suggest what the problem cud be?
Most likely a slow refrigerant leak. When the refrigerant is low, it actually gets colder and causes freezing in the coil. Another possibility is the coil is dirty, not allowing enough air flow through the coil. You didn't indicate if this is a room air conditioner or one attached to your furnace.In either case the coil should be cleaned first. Then if it is still freezing, you will need to have the leak repaired and refrigerant (freon) added to proper level.Normally the coil is not below freezing, but when the pressure drops too low it gets colder and then the condensate that normally drips off the coil freezes.
Oct 30, 2010 | Home
Frigidaire central unit freezing up leaking
The coil freezing can be caused by a couple of things. 1) Not enough air flow over the coil or 2) A low refrigerant charge. First make sure that the indoor fan is running. Then check your air filters and make sure your evaporator coil is clean. After that you can get the refrigerant charge checked. The lower the refrigerant pressure is, the lower it's boiling point is and when it gets below 32F then the evaporator coil and usually the low pressure line freeze up. The leaking you were talking about is probably from the ice melting. Hope this helps.
Jun 06, 2010 | Frigidaire Heating & Cooling
GE Profile refrigerator temperature problem
refrigerators have 2 coils. the evaporator coil and the condensing coil. one is on the bottom of the fridg and one is on the back or inside behind a false panel. these coils must be kept clean or if the condensing coil cannot reject the heat absorbed by the evaporator, the box temp will stay high and if the evap coil cant absorb heat the box temp stays low running the risk of freezing
Nov 26, 2009 | Refrigerators
Coil freezes up. i am wondering if there is a problem with the coil defrost. i also notice that the fan that is behind the coil is not running. should it be running all the time of just when the it is in...
yes the fan needs to operate or it will freeze-up, also make sure coils are clean,dirty coils will freeze,also as a last resort you may be low on freon(refrigerant)
Aug 15, 2009 | Samsung 26.0 Cu. Ft. Side-by-Side...
Coils freezing
coil freezing is a sign of under charged system. Contact aized service center for recharging of refrigerant.
I hope this helps.
Jul 21, 2009 | GE GSS20IEP Side by Side Refrigerator
Samsung RB2055Sl Top refrigerator couling coil freezing up every 2 or 3 weeks
The problem is freeze up. Bad door gasket or too much window shopping are the biggest issues. Could be low gas. Either take off the back freezer panel and defrost or unplug for 2 days to defrost fully. Oh, and clean the condenser coil. Then, let's see what the unit does.
Nov 27, 2007 | Samsung RS2630SH Side by Side Refrigerator
Camping, Backpacking & Hiking Logo
62 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
