Question about Epson Workforce Pro Wp-4530 All-In-One Printer
Bold black lines on sent faxes
Put a fax through the roller and on the other end it shows bold black lines. put the same fax through on the glass..no lines
2 Suggested Answers
  • 526 Answers
SOURCE: Able to send faxes but unable to receive.
you need to check how the fax machine is setup for receiving faxes. i recommend you try it first without the answering machine, to see if it works. if it doesnt, then it has to do with the auto answer or the number of rings not set right, if it does work, it could be that you need to set it to check for fax while the answering machine is answering, check the manual under answering faxes.
thanks adi
Posted on Dec 11, 2009
I keep getting a black line about 2 inches along the right side of the paper if copying as well any faxes sent are also getting that blac line. Brother fax machine intel 4750e
Well you said the Lines are present when you are copying and when you are sending from the fax unit. Copying and sending functions both uses the scanning unit. What you lift open the document feeder for original documents. In there you should see rollers and a glass. clean this glass with cotton swab and alcohol for left to right the entire glass. Close the unit and try copying or sending, documents should now be clean.
Apr 04, 2011 | Office Equipment & Supplies
Mfc-7420 ,when sending faxes puts a black line down centre of page
the scanner glass which reads the page is dusty.or any hair like material is stuck on that.just open the scanner and clean the glass.
pls do rate the solution
thanks.
regards.
fixya expert team
Sep 01, 2008 | Brother Office Equipment & Supplies
There is are lines on the faxes when they print out
are the lines on the other end or incoming ....if incoming then you need to replace your drum if on teh other end and are faxes you have sent then the scanner glass has got dirty.. you need to look where the documents are put in to scan lift the cover up and look at the glass slip the documents scan over there may be typex or ink on it this can be cleaned with glass cleaner and a soft cloth.. there may be a roller over this you have to unclip both ends to take out clean this as well..goood luck A
Jul 15, 2010 | Canon FAX-C855
I am getting a white line down the entire page
Is it when u send or recieve faxes!If on sending(open the part where u put in the faxes to sent!U will see a big black roller and under that a small black one,undeer that a long strip of glass,make sure that there's no marks of any kind on the glass!If recieving it might be on the fax that is sending the fax!Good Luck!
Apr 26, 2010 | Canon FaxPhone L75 Plain Paper Laser
Two black lines printed on sent faxes
Clean the glass onder the cover where the document feeds in.
Apr 24, 2009 | Canon FAX-L1000 Plain Paper Laser
PANASONIC FAX MACHINE PRINTING BLACK THICK LINE
Open the front of the fax machine. Then pull down the the tray that has the down arrow imprinted on it. Locate the glass strip towards the back, just behind the center roller. Use a cloth and rubbing alcohol to clean the glass and that should remove the black line.
Apr 22, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Black lines on sent faxes
open up the document feeder and clean the scanner glass.
Only use soapy water or alcohol for cleaning
Acetone will melt rollers and plastic parts.
Feb 16, 2009 | Sharp UX B700 Plain Paper Inkjet Fax
Black lines printing out on sent fax
If you make a copie and the lines are on the copie then the optics's are dirty, white out, ink or fourn oblrct on glass.
If you have clean the optics and the lines are still there then the C,C,D, needs to be replaces the part that reeds the documents.
more then what the fax is worth sorry.
Black Line on all faxes sent
Sometimes, the reason for a black line is dirt on the glass. Try cleaning the glass and rollers so there is no dirt that will stick to the glass from the rollers.
Also the original document make sure there is no dirt or creases as the creases will translate into a black line on the receiving end.
I hope this has answered your question sufficiently. If you have more questions please post a reply and i would be happy to assist. Thanks.
Oct 11, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Black line on all faxes I send to recipients
open the document feeder and look for wite-out on the small scanner glass.
Sep 10, 2008 | Brother IntelliFAX 4100 Laser Fax
Epson Workforce Pro Wp-4530 All-In-One Printer Logo
10 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
