Question about Dometic Refrigerators
Rv refrgerator burn smell - Dometic Refrigerators
Dometic penguin air ac
either the fan motor or heat strip
Apr 02, 2014 | Dometic Rooftop RV Air Conditioner
Xantrex inverter/ charger smells like burning electrical
I would call or e-mail the manufacturer of the inverter. The dealer or dealers may know the issue but likely the manufacturer will be more help.
Some devices like an inverter will have a smell in the beginning, power supplies are like that. You said that the inverter didn't get hot but smell indicates something is hot.
Apr 13, 2017 | Xantrex Electronics - Others
Fridge emitting burning smell. Its a fridge in a new caravan
Had smell probs with ours sorta gassy and what seemed like overheating and lack of cooling Found " exhaust pipe " completely choked - cleaned it out and all fine.
Apr 23, 2012 | Thetford RV Refrigerator - N400 Model -...
We have a dometic Duo-Therm model# 600315.321 mounted on our 25' RV we purchased in 2005. We recently noticed a faint smell of buring oil emitting from the vents when operating. My husband seems to...
I'm sure you are aware of the fact that any odors inside the RV, can be drawn in through ceiling assembly at filter and recirculated through duct work etc. With that said, first try taking down the filter at the ceiling and washing it well in water and dish soap, or for the sake of a few $'s, replace it. If that doesn't cure it, then for the sake of safety, remove cover over AC unit on roof and do a careful visual inspection of all wiring, components and especially connections at capacitors as they are prone to get hot and melt plastic in those areas, thus giving off a burning smell. Also be aware that capacitors are very, very , dangerous to handle if not experienced, so please alert whoever does inspect them, that touching them can result in a very high voltage shock, which can be fatal. !!
Aug 21, 2011 | Dometic Rooftop RV Air Conditioner
When I turn on my ac the compressor will not kick in and I get a burnt smell like wires or rubber burning. what might cause this?
Loose wiring/high/low voltage may create wire burning. Please call repairman to check and rectify. Don't use as it is. Thanks.
Mar 09, 2011 | Dometic Rooftop RV Air Conditioner
Dometic RV Rooftop A/C stopped working. Burnt electrical smell
if you can find a decent a/c mn in the area he might be able to patch you up until you get to an authorized dealer?
Jun 07, 2009 | Dometic Rooftop RV Air Conditioner
Dimetic RM2652 refrgerator problem
Check the coils to the left of the burn chamber they should be hot not as hot as the burn chamber but hot to the touch. If not you could have blockage in the coils not allowing the fluids to flow. Also check that the flu area is clear no nest of any sort wasp or birds.
Sep 02, 2008 | Dometic RM2652 Refrigerator
Compresser will not kick in and there a electrical smell
Stop it!
Something has gone wrong and needs to be repaired. It's an electrical problem. The more you smell it, the more stuff is getting burnt. Take it apart and look inside it. Then restart it. The burning stuff will lead you to the bad part.
Jul 27, 2008 | Dometic Rooftop RV Air Conditioner
Refrigerators Logo
10 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
