Question about RCA D61W20 61" Rear Projection Television
Who does in home TV repair have an RCA D61W20 or can it be done m
Who does in home TV repair have an RCA D61W20 with a ITC222 Chassis? Called Sears and they won't work on any RCA with a ITC222 chassis, something about it being digital. I live in Ionia Mi about 30 miles from Grand Rapids. Don't want to take this monster to a shop and goof something else up. Believe it only needs a convergence power board? Has a small swatch of red in the left bottom screen and a 3D look in this corner of the screen, the rest of the screen is fine. I find that their are two convergence boards for this model on www.partstore.com, on I believe part # 264103 is the convergence board and the other part # 264104 is the convergence power board. Have you heard of these and is the 264104 easy to change out? Have knowlege of swapping out electronic cards in a corrections institutions door systems and soldering boards. Have entered the service menu and tried fine tuning the convergence looks better but will only let me go so far in the left bottom corner. Still have the 3d looking corner but it is tighter now.
  • awiles854 Jun 24, 2009
    Can't find these resisters on board schematic I do fin RP610-RP613 have *.png of my Convergence Power Board but can't send here too big of a file if i can get an email I would send to a tech for verification of the prpper resisters to change out
  • RCA Master
  • 8,617 Answers
The most obvious item which is causing your problem are the 220K ohm 1/4 watt resistors on the convergence power supply board. There are four of them RP10, RP11, RP12 amd RP13
Posted on Jun 18, 2009
The inputs on my RCA scenium dlp tv wont work.
It sounds like your talking about the ITC222 chassis series which is having a small signal board problem. Very common in the RCA ITC222 and ITC222A Chassis HDTV's
Jul 12, 2010 | RCA Televison & Video
D61w20 rca turns on and off
I have a RCA D61W20 chassis ITC222, I had the same problem and my repair guy found out the blue bulb was the main problem, along with replacing some transisters on one of the power boards, He also had to adjust the service convergence (not auto convergence). Works great now!
Aug 27, 2009 | RCA D61W20 61" Rear Projection Television
Picture on TV shuts down but sound still on.
If this RCA TV has a Chassis number of ITC222 then you need to call a tech to swap out the deflection circuit board for a new or rebuilt board. This RCA Chassis is a TV Techs worst nightmare to repair.
Jul 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
The tv wont converge it doesnt even come up on the menu and there is a triple picture red blue green
That sounds like a RCA ITC222 chassis. If so theres a repair kit called ITC222 convergence option missing kit at the following link it has the components and instructions on how to do the repair.
http://www.tvrepairworld.com/
Jul 14, 2009 | Televison & Video
52" tv
It sounds like youre decsribing the ITC222 chassis HDTV rear projection. Look on the rear tag to see if its a ITC222 chassis and let me know and I can assist you with it.
May 18, 2009 | Televison & Video
RCA ITC222 Board
Also replace CP150 and CP120 then check for an open 1.25 amp fuse. It looks like a little tiny brown box behind the composite inputs about an inch inward. We always change those caps regardless of the problem. GO GET EM TIGER. Let me know?
Apr 21, 2009 | RCA D61W20 61" Rear Projection Television
RCA HDTV #D61W20, CHASSIS ITC222, PUSH & TWIST CAP ON HV CABLE
do you have the part number for the flyback ? I need it if you would please. send it to
swampbiker@hotmail.com
thank you
Apr 01, 2009 | RCA D61W20 61" Rear Projection Television
RCA HDTV #D61W20, CHASSIS ITC222, Power button flashing 1, pause, 9. Possible error code 19, anyone know what this means
This is not a friendly chasis, the only easy fix that you might check on the power supply board and the left side (looking from the back) 3 capacitor (220,330,and 2200uf 16V) have the top pop up. Other than that poping, arcing noise, burn smell when first start up is bad york, Flyback Transformer and even the cooling leak for those tubes you will need professional TV repair man. Those TV picture not very nice anyway.
Nov 07, 2008 | RCA D61W20 61" Rear Projection Television
New Problem with RCA D61W20
Donna, the 52 and 62 inch are both ITC222 chassis so the parts are the same for both models. Did the solder get shorted when you instaslled it or perhaps the HOT was shorted, as usually only a dead short will cause that type of arching. If it didnt burn a hole through the circuit board, the board should still be salvageable. Please respond to this same post and let me know wether the board is burned through our not.
Jul 08, 2008 | RCA D61W20 61" Rear Projection Television
Doesn't stay on
power supply is bad needs replaced
Apr 05, 2008 | RCA D61W20 61" Rear Projection Television
RCA D61W20 61" Rear Projection Television Logo
266 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
