Question about Kenmore 61912
Remove freezerf from compact Kenmore 61912 - Kenmore 61912
Model 417-94702300 need help removing agitator
The agitator is just a slip fit over a splined shaft, so if the part will not move after the retaining nut is removed it is rusted to the shaft and you have to do whatever it takes to break it free.
Oct 16, 2016 | Kenmore 3.4 cu. ft. Capacity Compact...
Kenmore 1.8 cu. ft. Compact Refrigerator stopped running and won't turn back on?
It is really hard to say why it shut down, but my best advice is to make a service appt. asap to have the problem looked at.
Feb 15, 2012 | Kenmore Refrigerators
How can I defrost a Kenmore Compact 91601 refirgerator without pulling the unit out??
to do that remove food from top shelf,place a towel there,turn off refrigerator,use a hair blow dryer and melt frost
Aug 07, 2011 | Kenmore 91601 Compact Refrigerator
Need to replace tub seal on a Kenmore compact washer model # 1102670091 is there a special tool for this
Here is a link to the wrench you will need to remove the agitator in your machine. Here is a video to show you how to replace it.
Happy Holidays!
Richard
Dec 09, 2010 | Kenmore 2.1 cu. ft. Portable Top Load...
Defrosting
T^he simple answer is yes....
unplug it and let it warmup enough to be able to remove the ice easily.
Then plug it back in and you should be good to go...
heatman101
Apr 18, 2010 | Kenmore 91365 Compact Refrigerator
Water build up at bottom of Kenmore Compact Fridge
Problem on your Refrigerator bypass plastic water sypply pipe.May be it was block dust,so you can clean it then water thorough the tank.
Mar 15, 2010 | Kenmore 4.9 cu. ft. Compact Refrigerator
Compact Kenmore top loadwasher does not spin
Clutch is failed. replace it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 29, 2009 | Kenmore Washing Machines
Kenmore 2.1 cu. ft. Portable Washer - won't drain
Probably something caught inthe pump. Will have to remove pump and take obstruction out. Only other thing I can think of is the pump ran tight and would have to be replaced
Aug 15, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
Refrigerators Logo
14 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
