Question about Rainbow E series Canister Wet/Dry Vacuum
The rainbow sat for too long on the water now wont run
The rainbow sat on the water tank for too long and now it smells burning rubber. The rubber ring is distended and misshapen
  • Rainbow Expert
  • 324 Answers
So depending on how long, you may have rusted out the bearings in your motor, especially if it sat so long as to eat the glue off of your gasket.
Sounds like you may need a new motor, gasket, baffle plate and separator.
Rainbow series vacuum main unit parts
GoodVac.com
800-775-6586
Posted on Mar 06, 2015
3 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: Burning Smell
Check the carbon motor brushes, there might be arcing on the armature. New brushes may help if the armature is ok.
Posted on Mar 30, 2008
Vac Belts
  • 701 Answers
SOURCE: Rainbow Vacuum smells like something is burning.
Your belt is worn and that is why there is a burnt rubber smell. You need to change your belt. You can find a replacement belt and instructions here:
Rainbow Replacement Belts
Posted on Oct 29, 2009
Burning smell
The response by Lynnette is in reference to the power nozzle....if you are having this issue with the main unit, then it could be the armature is starting to go bad. Have your Rainbow in front of you and give us a call. We can walk you through some steps to narrow it down.
www.rainvac.com
800-523-0510
Apr 09, 2014 | Rainbow E series Canister Wet/Dry Vacuum
Work well but smell like a burning belt
If it smells like burning rubber, the belt is probably worn and slipping. If it's another burning smell, your motor windings are probably shorting and will burn out soon
Oct 12, 2010 | Rainbow E series Canister Wet/Dry Vacuum
IT WILL NOT START - IT TRIES BUT DOES NOT TURN ON.
Unplug the vac and spin the acorn nut on the separator in the water reservoir. If it spins freely and this vac has run for a few years you may need a fresh set of motor brushes. Do not attempt to run the vac if the motor hums or makes a burning smell. Worn brushes are normal and can often be replaced in an older Rainbow/ Rexair
Sep 28, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Apr 02, 2009 | Rainbow E series Canister Wet/Dry Vacuum
When it is running look on top of unit to see if there is any flashing from the brushes, if your unit has been getting pretty hot on top, it would probably be motor brushes. These are not very expenseive to replace and by doing so you will have your unit for so many more years.
Dec 31, 2008 | Rainbow 75th Anniversary Canister Vacuum
Loud rainbow and water leaking
If pieces are missing or broken I would try and replace the piece. You can usually get these items cheap on Ebay.
Apr 08, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Burning Smell
Mar 29, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E series Canister Wet/Dry Vacuum Logo
214 people viewed this question
Top Rainbow Vacuums Experts
Jim Parker
Jim Parker
Chris Nomland
Chris Nomland
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
