Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
How do I remove the cutting deck on a Craftsman LT1000?
Pull the pins from the rods attached to the front of the deck. then let the deck all the way down. remove the pins in the deck lift arms and remove the pin in the top of the tension pully and lift the end of the cable off the pully remove the clip holding the blade ingadgment cable in place . pull the pin in the arm at the back of the deck disconnect all of the rods you pulled the pins out of and slide the deck out. put it back in reversing the above prossess.
Posted on Jun 20, 2009
How many belts are on a craftsman LT1000?
you have the drive belt,the deck's cutting belt. so only 2
May 03, 2015 | Craftsman Garden
I have a craftsman LT1000 model # 917-275351.It cuts crooked and I don't have an owners manual.How do I adjust it to cut evenly
2 ways to adjust deck level, the obvious is the ground wheels. The other is adjustment rods that hold the deck to the under side of the frame, usually 2 rods one on each side and maybe 1 in the front of deck/frame
Jun 13, 2014 | Craftsman Garden
Where is bypass lever for craftsman lt1000 riding lawnmower
there is a rod hanging out from the rear of the machine you pull that out and move into the lock cut out
Jul 08, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman LT1000 mower deck cutting uneven. How
try biger wheels on the low side???? ha ha?
no you hit and bent the bed hight ajusters you may need to take the mower bed off to fix this part,,,,,
look as were the morer hight ajuster is,,, is it in the same place on both sides,,, my gess is its not
the bed has a tilt on it,,,they dont cut down trees very well do they?
Jun 11, 2010 | Garden
Cuts lower on side
first and foremost! make sure the tire pressure is correct in ALL TIRES and then level the deck.
May 27, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman lt1000 rider 42 in deck is stuck in gear and wont go into neutral. so i cant get it started.
this happens when lawnmower is cut off in gear try this mash clutch and shake mower forward and backwards while trying to shift into neutral
Sep 18, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Have to overlap about half my cutting deck to get clean cut.
A: Is the blade on right?
B: Is the belt on the pulley?
C: Is the blade tight on the spindle?
D: Does the spindle turn freely with the belt off?
I can't think of any other possibilities
Jul 03, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Removing tire from SEARS CRAFTSMAN LT1000 TRACTOR.
You need to remove the black rubber cap from the center of the wheel. Remove the "C" clip from the axle and the wheel should come off. The rear tires will have a square key in it. Do not loose the key.
Jan 26, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
355 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
