Question about Dometic RM2620 Refrigerator
Keep blowing 5 amp fuse for fridge heater element
Keep blowing 5 amp fuse for dometic modelrm2620 refridgerator heater element
    Top Expert:
  • Dometic Master
  • 7,915 Answers
Bad heater element
Posted on May 25, 2016
roadrunning1
  • 152 Answers
SOURCE: 5 amp fuse blows when I try to start on AC
Sounds like your heaters are shorted ,  This is best carried out by a fridggy but you can do it yourself with the right tools ,  First of all make sure you turn it off and unplug it completely. take off the back panels and located the tank  with the heaters wrapped around it. disconnect the heaters and remove them and make sure you take note of where each wire came from , ie; tag the wires or write it down, once the heaters and fuse is replaced it should be cool sailing..
Posted on May 11, 2009
jumptrout51
  • 3361 Answers
SOURCE: My Dometic NDR1062 only runs on gas, its set for auto and has 110
There is a control board and a step down transformer that may be at fault.
These should be located in the lower rear of the unit.
Posted on Jul 11, 2010
motor1258
  • 6674 Answers
SOURCE: dometic rerigerator won't work on electric keeps
Have you tried locating the connectors on circuit board for the AC (hydro) element and removing them from circuit board and see what happens when you turn it on hydro then? Follow them back from element if necessary. If fuse doesn't pop, then I'd suspect a shorted element and change the heating element. Double check fuse is correct amperage as well. If it's a 3 way fridge, make sure it's the AC element and not the 12 volt you remove.
Posted on Jul 20, 2010
motor1258
  • 6674 Answers
SOURCE: RM2652 Dometic, blows 15A fuse in about 15 seconds
Sounds like you have a short in your heating element for 120VAC. I'd change it.
Posted on Jun 21, 2011
  • 230 Answers
SOURCE: I have a Americana RM2652 It works on gas, but not
My guess is that the element is shorted out not much else to go wrong, elements are not that resilient to shocks and bumps.
Posted on Jul 01, 2011
Why does 15 amp 250 volt fuse in my lg refridgerator keep blowing
the 15 amp fuse is blowing because the current draw to run the compressor exceeds 15 amps
that problem could be from a failed start/ run capacitor or a failed compressor motor (I am betting on the capacitor)
the best answer is to get a fridge technician to check it out as the capacitor is a cheap fix while the compressor unit is as costly as a new fridge
Jun 25, 2015 | LG Refrigerators
5 amp fuse keeps blowing on ac input into cir. brd. on norcold model 6162
shorted heater element unplug and see if it still does it if still shorted board
Jun 17, 2014 | Dometic RM2652 Refrigerator
Dometic Fridge Intermittent on 120V
the dometic fridge you mentioned was outsourced by Dometic and they are having problems. (unit 2652) call dometic at 18888674188 and give them your mod and serial number.
May 26, 2012 | Dometic RM2652 Refrigerator
Dometic rerigerator won't work on electric keeps blowing fuse on circuit board
Sep 03, 2009 | Dometic RM2652 Refrigerator
Apr 12, 2009 | Dometic RM2652 Refrigerator
Dometic RM2620 Refrigerator Logo
119 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
