Question about Mini Motorized Bike
Mimi bike got no handbook do not know pertol to oil mix bike is 43cc 2stroke
  • 30 Answers
32:1 4 ounces of oil to 1 gallon of gas.
-John
Posted on Jun 18, 2009
How do i mix the gas/oil on a 3.5hp craftsman edger
50 to 1 ratio of gas to two cycle oil.
Jul 10, 2016 | Craftsman Garden
Previous owner running 25/1 mixture in tank. 2stroke oil tank dry. How do I check whether the oil pump is injecting oil to crankcase.
It doesn't inject oil into the crankcase on a 2 stroke. It is mixed with the petrol at the carb. But, it is difficult to tell you how to check it as you haven't said the make and model of your bike!?!?!
Aug 10, 2013 | Motorcycles
What is the right 2stroke oil mix for a Vespa 150 Super 1962?
the mix should always be only 2% oil = ratio 1:50
for 1 liter =20ml & for 5 liter =100ml of 2stroke oil
- you better get an oil measuring jug to be sure:
Jun 20, 2012 | Vespa S Motorcycles
5litres of petrol how much 2stroke oil
you should always lean toward the rich side of any fuel/oil mix 50:1 would be 5 ltrs of fuel 100 mls 40:1 would be 125 mils the best with out a doubt is 20:1 better to push blue then to push it home
Nov 11, 2011 | Motorcycles
What type of oil for a 90 horsepower 1998 engine for a boat?
The outboard leg/transom leg oil is most important, where the gears drive the propeller it will need a heavy oil like hypoid gear oil No. 90. If it is a four cycle motor which doesn't need to have oil mixed with the gas, the base of the motor will have an oil plug and dipstick, and most likely take a high performance oil which acts as a coolant as well as a lube oil, so keep it right on but not over the full mark to avoid deadly engine heat.
If it is a Two-cycle motor you will need a 2cycle oil to mix with the gas according to that engine's particular mix strength on the instructions. Some are automatic oilers - 2cycle injection so you just keep the 2cycle oil tank full. You need to find a sticker on the motor or brochure to get the right oil weight and weather it can take the new multi-weight synthetic oils or not. Also oil the cables and steering pivots and all joints after you take it out of salt water and do your routine flush-out for the leg coolant water system with a hose - the coolant pump in the leg is not rust proof at all, even for fresh water boating.
Jun 21, 2011 | Garden
I own a 1997 yamaha 180 rt does its my firts bike does it need mixure gas meanind do i mix it with 2stroke oil....its also has a choke so im thinking it mixes itself......lately its been back fireing can...
it should have its own oil mixing tank that you need to check all the time if you cant find it then just mix two stoke. if its a 2stroke and it sounds like your timming is out that will make it back fire
Apr 21, 2011 | Cycling
How to check the oil in a 2005 yz250 2stroke
Their should be a sight glass on the left hand side of the bike at the bottom but if mixed for a 2stroke u should know in the mixture directions.
Aug 10, 2010 | Yamaha YZ 250 Motorcycles
How much 2stroke do i add per ml of petrol
Like most 2 stroke weedwackers they run on a 25:1 fuel ratio. It is advised that you mix the petrol & oil in a separate container (remember to shake it for a few seconds) first to ensure it mixes properly.
Example: 1 Liter of petrol needs 25ml of oil. (Use 2 stroke oil) Hope this helps.
Jul 27, 2010 | RTO Mini Quads
Do you mix petrol with 2stroke oil
Yes if you have a 2 stroke. You will need to look at the manual, or somewhere on the bike for the ratio.
Jun 13, 2009 | 2005 kawasaki KLX 110
Dirtbike is smoking
could be too much 2 stroke oil in your mix or worse case, your piston rings are going.
Nov 20, 2008 | 2003 Suzuki RM 250
Mini Motorized Bike Logo
126 people viewed this question
Top Mini Sport & Outdoor - Others Experts
Marvin
Marvin
Bill Eager
Are you a Mini Sport and Outdoor - Other Expert? Answer questions, earn points and help others
