Question about Lexmark E320 Laser Printer
Crinkled paper The print quality is fine but the paper is coming out of the printer crinkled - almost accordian fold.
  • cmbc Nov 06, 2007
    Looks like on the lower roller where the paper feeds between, one of the smaller white plastic wheels, which roll on top of the larger gray rubber wheels, isn't rolling like all the rest.
It sounds like a fuser problem. You may have something stuck in it, or the lower roller could be defective. You may have to replace the fuser.
Posted on Nov 03, 2007
Paper jam in back, accordian fashion, cannot extract lexmark e328
There might be a access door in the back of the printer, remove the door and gently pull the paper out.
May 26, 2010 | Lexmark E322 Laser Printer
The page is starts printing about 1 inch below the top of the page
I am having the same problem too. the quality of the first page look crapy too.
this only happens to the first page i believe when the machine was out of power saving. if i print more then one file at the same time, only the first page of the first file was printed one inch below.
i suspect some cleaning might be needed. hope someone have a solution for this probelm. thanks,
May 21, 2010 | Konica Minolta magicolor 2300DL Laser...
When printing paper comes out all "crinkled" maybe roller problem?
It the paper comes out crinkled or accordion looking then it is your fuser. Check where your the paper comes out of. There might be a piece of paper jammed in there that is causing this. If no obstuctions then it might be the roller on the fuser cracking and cause it to crinkle the paper. The fuser is the last thing the paper goes through before coming out. It "fuses" the toner to the paper.
Apr 26, 2010 | Brother MFC-8660DN 5-in-1 Laser...
Paper jams and folds into accordians
Most problems with the HP4 series can be fixed by replacing the paper pick roller. Is your paper jamming at the output slot on the top? Can you print ok with the back door open? If so, you need a new output assembly. Try for cheap parts.
Oct 07, 2009 | HP LaserJet 4 plus Printer
My printer folds the paper in the back accordian
check the drum unit and toner unit, also check on all rolls inside the printer.
if still not working you can send it to me to fix it for you.
Jul 13, 2009 | Brother MFC 7420 All-In-One Laser Printer
Paper jam repeatedly
Possible cause:
The eject rollers get too slippery because of paper dust and other foreign matter.
Clean the eject rollers with a paper towel dampened with water. A second cleaning may be
necessary. The easiest way to do this (without disassembling the machine for full access to
the rollers) is to hold the dampened paper towel against the rollers and make a blank print.
Clean the rollers as they turn and remove the paper towel as the paper ejects. Repeat as
Now is a good time to also clean the paper pick up roller and feed rollers to prevent
feeding problems.
Jun 18, 2009 | Brother HL-2070N Laser Printer
Paper is jamming when I print something
Were you able to remove all of the original jammed business cards? where the leading edge of the "Fanfold" prints occurs, you will probably find something blocking the paper path. HP printers usually have a limit on the paper weight that the printer can handle when doing duplex (2 sided) printing. Check this against the weight of the cards you are printing.
Apr 18, 2009 | HP Color LaserJet 2600n Printer
HP Laserjet 4M makes accordion folds in the paper before jamming
I have found that with laser printers that have an occasional "crinkle" problem that "fanning" the paper does alleviate the problem ... but it will not if there is an actual feed/hardware problem with the rollers
Mar 13, 2009 | HP LaserJet 4M Printer
Paper prints halfway but jams at top roller
maybe your fuser assembly is in lack of silicon paste that's why you are experiencing paper jam..
just try to apply a silicon paste it will run in smooth again...
Oct 30, 2008 | HP LaserJet 4L Printer
Martin Yale Paper Folder Problem
Im not familiar with a paper folder but if its anything like a printer, it probably has a maintenance kit you can buy or you may have to replace the rollers. Alot of the times they have a rubber grabber that wears out or a roller that gets dirty and doesnt catch the paper evenly and pulls it through at an angle, crinkling it. Check for debree or paper particles that may be floating around inside.
Jan 02, 2008 | Computers & Internet
Lexmark E320 Laser Printer Logo
191 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
