Question about Konica Minolta Office Equipment & Supplies
Hi i am having bizhub c650, it prints blue instead of green
  • Konica Minolta Master
  • 6,161 Answers
You are using what as a reference?? Replace the yellow and or cyan image unit.
try this site for parts
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Posted on Dec 30, 2015
SOURCE: Printing error (Canon ip1800)
replaced ink cartridges..error message appears now telling me to re align printer..can you tell me how to do this
Posted on Oct 07, 2008
SOURCE: BizHub 350 Network Fax - Prints instead of faxing
Set the Gateway TX to "Allow"
1. Press the Utility/Counter button.
2. Touch Admin Management
3. Enter Password (The default password is 12345678)
4. Touch Admin2
5. Touch Network Settings
6. Touch Network Settings1
7. Touch Scanner Settings
8. Touch Gateway TX
9. Set Gateway TX to Allow
Posted on Jan 16, 2009
  • 30 Answers
SOURCE: Printing consecutive page numbers on multiple documents
look in applications (mainscreen) and I thinkit's under stamps/overlays. You might even be able to choose what page number to start with
Posted on Feb 25, 2009
SOURCE: konika bizhub c650 not printing through network
pls can i join
Posted on Apr 20, 2010
caroldon
  • 17130 Answers
SOURCE: instead of printing out blue
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . check the wire tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Thank you for using Fixya
Posted on Aug 09, 2011
Bizhub c650 cyan toner chip error
Take the cyan image unit out, clean the contacts on the chip remove any oil from your and interfering with the electrical contacts. Is the toner cartridge Third party or OEM??? if third party get a OEM. Sure it does not say Cyan Image Unit not Toner Cartridge?
Aug 30, 2015 | Konica Minolta BizHub C650 Copier
Konica minota c650 Printing balck baground copies
replace the black image unit. and ensure modification lock is installed to ensure proper connection if you pull out the black image unit is there black developer piled up in the rear???????
Jun 20, 2015 | Konica Minolta BizHub C650 Copier
How do you replace the staples in a konica minolta c650
pull out the blue cartridge do not throw away you then place the staple cart from the box you have insert into the cart,
Apr 29, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
My colours do not align on my bizhub c650
run the registration procedure. do you have any oil can showing on the bottom of the control panel P-21. P-28 etc
Apr 16, 2014 | Konica Minolta BizHub C650 Copier
Error code:P21 and P8
try to go to your printers and faxes it is located in the start menu.
Apr 03, 2014 | Konica Minolta Minolta Bizhub C253 Copier
Konica Minolta c650 Bizhub Address Book Questions
no all you get is the square buttons on the screen and they are shown in the order that they are entered
Mar 02, 2009 | Konica Minolta Office Equipment & Supplies
Print Booklets with Konica Minolta Biz Hub C650 Printer
Select Print, and then "Properties"
Layout Tab - select Print Type: Booklet
Basic Tab - Select original size and then size of PAPER to be printed. 11x17 is standard 8.5x11 book when folded.
Finish Tab - select saddle stitch.
Thats it, easy as pie.
Jan 22, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Jan 06, 2009 | Office Equipment & Supplies
24 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
