Question about Polaroid FLM-3732 Television
Lite color that moves acrose picture - Polaroid FLM-3732 Television
I have a Mitsubishi WD-62530 and the screen is now lite green color. The sky color is now lite green and the background color is real lite green.
is the problem like this. 7731a3ef-e74e-4749-85d8-fec3c051ffc0.jpgthis is a sing that the DLP chip is failing. these can be changed but I don't know the number off hand, when you take off the back in the middle there is a board with 3 plastic caps. take the wires off this board. take the caps off and there is some screws inside this is the lining up the screen part you will need to do after you have replaced the chip. take the board away. and take the casings of the board you will find a heat sink take this off as behind it hold the screw that hold the DLP chip in place when it is all removed carefully remove the chip being very careful it just prise out but has very tiny pins on the back of it. put new one in and now do in revers order replace the heat sink paste on the back of the cooling fin. when all back together you need to lockat the switch were the light is fitted it will be a push type that when the case is fitted it will push it in. make it so it stays pushed in. not turn on the tv. remember them 3 screws in the plastic. them are now going to need to be adjusted. using a flat head or something plastic. just have the screw touching in place so the board can be moved. have tv set to a tv program with reports on the bottom of the screen. you need to lift the board and move it around til the screen fits the picture. this is a long and tedious thing to do, take a few goes as you need to keep checking that it matches with other programs. I used a screen program on laptop into the tv and set it up that way but still ended up using programs to test the placement should not be green any more any way. this is a picture of the chip you will need.cbb17047-10d9-4d29-943c-ce58603c7069.jpghope this helps you out need any more info contacted me here.
Oct 21, 2013 | Televison & Video
Passenger door window switch
https://s14.postimg.org/6r7zxgtox/power_windows.jpg
Click on the link.
I can only help by telling you to check voltage and ground circuits. You check voltage by using a test lite, see the fuse in diagram, not only check the fuse, check the fuse circuit for voltage.
To check ground, you can still use the test lite, one end comes from voltage, the other end you touch to ground wire, the actual wire not the insulation, if the lite comes on, at least you know the ground is good enough to turn on the lite.
You can see voltage wire color coming from fuse. The ground wire not in the picture, black with yellow tracer.
on the hinge side of driver door is usually a wiring harness going into the driver door, probably has a protective covering, move cover back far enough to find the wire colors you want to check.
You open/shut driver door so much, sometimes those wires may break?
Apr 16, 2017 | 2006 Mazda 6
LOOKING FOR PICTURE SETTING SAMSUNG MO.NO.LN-T5265F
This may help you...you can also get an owners manual free on line.
English - 23
Using Automatic Picture Settings
Your TV has Three automatic picture settings ("Dynamic", "Standard", "Movie") that are preset at the factory.
You can activate either Dynamic, Standard, Movie by making a selection from the menu.
1. Press the MENU button to display the menu.
Press the ENTER button, to select "Picture".
2. Press the ENTER button to select "Mode".
Press the ??² or ??¼ buttons to select the "Dynamic", "Standard", "Movie" picture
setting. Press the ENTER button.
?³ Choose Dynamic to increase the clarity and sharpness of the picture.
?³ Choose Standard for the standard factory settings.
?³ Choose Movie for a natural Image without picture enhancements.
3. Press the ??² or ??¼ buttons to select "Contrast", "Brightness", "Sharpness",
"Color", or "Tint(G/R)", then press the ENTER button.
4. Press the ??? or ??? buttons to decrease or increase the value of a particular item.
For example, if you select "Contrast", pressing the ??? button increases it.
Press the EXIT button to exit.
• When you make changes to Contrast, Brightness, Sharpness, Color, Tint(G/R)
the OSD will be adjusted accordingly.
• When in PC mode, Tint, Sharpness, and Color are not available.
Press the P.MODE button on the remote control repeatedly to select the desired
picture mode.
Picture Control
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 00
??¼More
TV Picture
Move Enter Return
Mode : Dynamic
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 0
??¼More
TV Picture
Dynamic
Standard
Movie
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 0
??¼More
TV Picture
50
??² Con trast ??¼
Move Adjust Return
English - 24
Adjusting the Color Tone
You can change the color of the entire screen according to your preference.
Press the ENTER button to select "Picture".
2. Press the ??² or ??¼ button to select "Color Tone", then press the ENT ER button.
3. Press the ??² or ??¼ button to select "Cool2", "Cool1", "Normal", "Warm1",
or "Warm2".
When the picture mode is set to Dynamic or Standard, Warm1 and Warm2
cannot be selected. Movie mode is only available.
Move Enter Return
??²More
Color Tone : Cool2 ???
Detailed settings ???
Size : 16 : 9 ???
Digital NR : Low ???
Active Color : On ???
DNle : On ???
Reset : OK ???
TV Picture
Move Enter Return
??²More
Color Tone : Cool2
Detailed settings
Size : 16 : 9
Digital NR : Low
Active Color : On
DNle : On
Reset : OK
TV Picture
Cool2
Cool1
Normal
Warm1
Warm2
Activating Backlight
You can adjust the screen brightness by adjusting the LCD backlight brightness. (0~10)
2. Press the ??² or ??¼ button to select "Backlight", then press the ENTER button.
3. Press the ??? or ??? button to decrease or increase the valueof the backlight
brightness.
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balcklight 1 0
??¼More
TV Picture
5
??² Balcklight
??¼
Move Adjust Return
Move Enter Return
??²More
Color Tone : Cool2
Detailed settings
Size : 16 : 9
Digital NR : Low
Active Color : On
DNle : Off
Reset : OK
TV Picture
OK
Cancel
Resetting the Picture Settings to the Factory Defaults
1. Press the ??² or ??¼ button to select "Reset", then press the ENTER button.
Press the ??² or ??¼ button to select "Cancel" or "OK" then press the ENTER button.
Each mode can be reset.
Feb 04, 2011 | Televison & Video
I have a Sony vaio computer for my system I purchased the Cintiq 12W tablet. When installing these Items together I came acrose the problem of not having a vga dvi outlet so I was informed that I would...
use a dvi - hdmi convert cable and connect via the dvi-d cable on the cintiq instead of the analogue. should have been your first move as it is alot cheaper than an external vga card
May 15, 2010 | Wacom (PTZ930AC) Graphic Tablet
Line acrose tv and only two colors the top and bottom are ha;f moon shape
Convergence is dead.Must know how to solders?Tries websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost U $300 for parts,and labors.
Mar 20, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
THEN SEEN HAS A LITE GREEN TINT TO THE BOTTOM PART
Sounds like your main control board or the color wheel.
Dec 29, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Picture looked 3d now tv wont come on. red lite flashes 6 times.
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts down
  • TV Chirps
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 03, 2009 | Sony KP-51WS510 51" Rear Projection...
Looks uneven almost like 3d
The lenses might have moved out of line - with power off give a gentle tap to the side of lense suspected of this problem. (power off) then switch on if there are changes then you have found your problem.
good luck
Sher
May 30, 2009 | Philips 60PP9401 60" Rear Projection...
I do not have a color picture
If you had a color picture before moving the TV, then you should check the inputs. Make sure all the cabling is properly and securely attached.
If this does not help, please provide more information, such as a description of the TV, indicate whether the TV had a color picture immediately before moving it, and whether you have reason to think that there is a mode for black&white.
Nov 30, 2008 | Televison & Video
Sanyo DS24425 24" TV has great sound and no picture(black screen)
if tv have black screen,increse screen control to see vert ic is defective,and if screen is white with lots of line acrose ,you can find open resister,on pic tube board,or in main board near transformer.
May 20, 2007 | Sanyo DS24425 24" TV
Televison & Video Logo
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
