Question about Arrow Staples T-50 1/4""
How do I open the Arrow T 50 stapler to load staples?
sbg_ofp
  • 10 Answers
SOURCE: Stapler works intermittantly
If not the power source or cord, the next activation point would be the trigger. Does the stapler make any sort of noise when the trigger is depressed? What type and model stapler is it?
Posted on Nov 05, 2008
SOURCE: refilling the staple gun
The staples do not go on the bar you pull back but directly into the bottom once you have pulled the bar back. I was trying to put the staples on the bar at the back and push them into the stapler.
Posted on Dec 05, 2008
SOURCE: Arrow T-50 stapler
Take out the screw/nut combo @ the end of the gun where you load the staples. The whole rail that holds the staples will then come out and you can then get the little devils of the nested, jammed, rousted up staples out by sliding them out with a screwdriver. Don't jam the screwdriver into your fingers/hand when doing it.
Posted on Dec 08, 2008
  • 384 Answers
SOURCE: my jt 21m stapler is jammed and i cant get it to open
At the end of the stapler opposite where the staplers are driven out is a release. Push it in and turn it should come out with a long spring.
Posted on Jun 26, 2009
  • 233 Answers
SOURCE: staples are stuck inside the stapler and will not come out
Typically you do not open these up.
Makes it difficult to remove stuck or wrong staples.
I have had good luck removing the staple ram rod and rapping firmly on the **** of the stapler against a wooden table. The idea is jolting the stuck staples into reverse out the way they went in. Tedious process but usually works. Removing the jammed staples in the nose at the striker plate requires using needle nose pliers and a sharp awl or small screw driver used on very small screws.
My T50 Arrow stapler is over 20 years old.
Still works great. Sometimes I slide in the wrong size staples by mistake. The process above usually works.
Posted on May 27, 2010
Loading staples into a Stanley sharpshooter staplegun
There are 4 staplers in the Stanley SharpShooter family. You drop the staples on top of the "slide out loader," then slide it into the gun. See models and staple sizes below:
TR150HL Stanley Sharpshooter
  • Stanley SharpShooter TRA700 series or Arrow T-50 heavy duty staples
TR150 SharpShooter
PHT150C SharpShooter Heavy Duty Hammer Tracker
  • TRA700 series or Arrow T-50 heavy duty staples (1/4"-3/8")
TR250 SharpShooter Plus Heavy Duty Staple/Brad Nail Gun
  • Stanley SharpShooter TRA700 series or Arrow T-50 heavy duty staples and 1/2", 9/16" and 5/8" Brads
More information on the Stanley SharpShooter and a quick loading demo can be found here: http://www.expotv.com/videos/reviews/12/134/StanleyTR150HLSharpShooterHeavyDuty/185661
Sep 11, 2012 | Stanley Proto Stanley TR150HL SharpShooter...
Loading staples
Powershot Pro (Model 8000) Loading staples is pretty much what you would guess,
EXCEPT that releasing the catch takes a very strong pull, or it won't budge at all. Grasp the black plastic catch at the rear of the stapler base, pull very hard (probably 5lbs or more) and the catch will move about 1/4" away from the stapler ("down" if you think of the stapler in its usual orientation.) You can then slide the catch and the spring mechanism "backwards" leaving room to insert staples or brads. (Note, "T-50" staples and brads should fit. If loading brads, they go along the side of the magazine which is closest to the "staples remaining" window.)
Oct 10, 2011 | Arrow 8000 Power Shot Pro Staple & Nail...
How do you load new staples?
Find the button on the bottom of the stapler's back edge. Push the button in and down. Pull out the bar that pushes the staples into place. Slide in a row of staples with the points facing down. Push the bar back and lock it into place
Feb 20, 2011 | Arrow CHROME STAPLE GUN ARROW IND....
How do I load JT21 staples into a Arrow JT27 Stapler gun?
I was having the problems everyone listed... with the staples loading & firing... I guess the instructions are lousy .. should be ON THE PACKAGE to make it clear.. but.. on the stapler itself on the bottom.. it explains how to correctly load.. you don't put the staples on the piece that slides out.. you slide it out, load the staples in the open tunnel ..then slide the piece back.. that piece is the spring loader... since i finally figured it out ( by coincidence that I turned it over & noticed some faint words printed) - it works PERFECT every time! great little stapler... please fix your directions... seems to be a common misunderstanding!!!
Nov 07, 2010 | Arrow T50P ARROW STAPLE GUN
How to put the staples
depress the handle enough to release the side catch on the stapler. now pull the bottom track down. insert a few rows of staples and snap the track back up into the stapler. the spring loaded follower goes in back of the staple stack.
Oct 20, 2009 | Arrow CHROME STAPLE GUN ARROW IND....
My jt 21m stapler is jammed and i cant get it to open
Jun 26, 2009 | Arrow Fastener Co. Lt Duty Staple Gun -...
Can't load staples
Fire the stapler with the load chamber open and down, see if anything falls out. Point it in different positions and fire it, just make sure it cannot fire anything at you.
Apr 18, 2009 | Stanley Tools TRE550 Electric Staple/Brad...
Is the Ace Hardware #22084 Staple Gun the same as Arrow T-50 ?
Found a friend who had an Arrow T-50 stapler and compared staple sizes - not the same.
Feb 17, 2009 | Arrow T50P ARROW STAPLE GUN
My friend let me borrow an Arrow HT50P Stapler and I would like to know how to open the stapler so I can load it
Most arrow staplers have slide levers along the sides toward the front. Pull back on these and it should pop open. Some however load from the rear of the stapler. You push in and down on a square metal piece and it will unlock and than you pull it out toward you. slide in a rack of staples, put it in, relock and ready to go. If you put in too many staples it wont go all the way in to re lock.
Dec 02, 2008 | Tools & Hardware - Others
Arrow T-50 stapler
Nov 03, 2008 | Arrow T25 Staple Gun
Arrow Staples T-50 1/4"" Logo
69 people viewed this question
Top Arrow Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you an Arrow Craft and Hobby Expert? Answer questions, earn points and help others
