Question about ASUS DSL-N10 Wireless-N ADSL Modem Router
Cannot connect to internet
The internet light is not on at the front panel
    Master:
  • 368 Answers
You need to check configuration setting or adaptor .
Posted on Jan 29, 2015
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 37 Answers
Look for internet switch. Either on the side or with fn+Internet key
Posted on Apr 15, 2014
How to turn off web services on a HP T790
You can configure the printer's Internet connection from the Embedded Web Server or from the front
panel.
NOTE: If an administrator password has been set, it will be required to change these settings. Thus,
the administrator can prevent the printer from being connected to the Internet, if desired.
? In the Embedded Web Server: select Setup > Internet connection.
? Using the front panel: press , then , then Connectivity > Internet connectivity.
The following settings are available:
? Enable Internet connection: The default value is Yes.
Change to No
Mar 20, 2014 | HEWLETT-PACKARD T790 InkJet Plotter...
How do i turn wifi off
Locate the Wireless LAN switch located on the front of your computer.
This could be located on the upper row on a laptop it will have the radiation look (((·)))
Make sure its pressed on or off whichever you need.
Move the switch to the right to turn on Wireless connections.
Right-click the network icon located on the system tray next to the clock.
You should see a list of available wireless networks.
Select the network you want to connect to and click "Dis Connect."
Motorola Surfboard Cable Modem User Guide
The user guide for your Motorola Surfboard cable modem can mean the difference between knowing how to locate and diagnose problems with your connection or staring angrily into a maze of blinking lights.
The user guide provides information on properly setting up your cable modem, understanding the indicator lights and troubleshooting problems before you have to call your Internet Service Provider.Connecting Your Modem
Your Motorola Surfboard cable modem must be connected to your home's coaxial cable connection.
Connect the coaxial cable from your cable outlet into the "Input" jack on your cable modem.
If your modem is wireless, it will connect to any computers and wireless devices in your home through the wireless signal sent from the modem.
Wired Internet connections require that you use an Ethernet cable to connect your cable modem to any supported computers and devices.
Understanding the Front Panel
The front panel of your modem is your key to understanding the status of your cable modem.
The front panel features "Power," "Send," "Receive," "Online" and "Link" lights, each of which displays information about your modem.
The "Power" button will display a solid green light when operating normally and will turn off when there is a problem with the power supply.
The "Send" and "Receive" lights will transmit a solid green or blue color when data is being normally transmitted through your modem and will blink when it the modem is scanning for an upstream or downstream connection.
A solid green "Online" light indicates that you are connected to your Internet Service Provider, while no light indicates that the Internet connection in your home is experiencing problems.
A yellow "Link" light indicates that a computer is connected to your modem with an Ethernet connection while a blue light indicates that a high-speed Ethernet connection is being utilized through the modem.
Configuring TCP/IP
The Transmission Control Protocol/Internet Protocol provides the basic foundation for establishing a local network and a connection to the Internet. The TCP/IP can be configured in the "Control Panel" of your Windows computer. Open the "Network and Sharing Center" from the control panel and double-click the "Manage network connections" option. Right-click the network connection displayed and select "Properties," then select Internet Protocol Version 4 and open the TCP/IP properties menu. Select "Obtain an IP address automatically" and "Obtain DNS Server address automatically" from the TCP/IP properties menu and click "Ok" to save your TCP/IP settings.
Troubleshooting
Many technical issues with your cable modem can be resolved by power cycling your modem and the computers and devices connected to it.
To power cycle your modem, unplug it from the power supply for 10 to 15 seconds and reconnect it to the power supply.
Restart all of your connected computers and devices while your modem is power cycling. Problems with the "Send" and "Receive" functions can be the result of a poor signal being sent to your cable modem. Tighten the coaxial cable connection to your modem and contact your internet service provider if problems persist.
http://www.motorola.com/staticfiles/Consumers/Products/Cable Modems and Gateways/SURFboard Cable Modem-SB6120/_Documents/Static Files/557621-001_SB6120_User Guide-US-EN.pdf
Nov 19, 2013 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
How to connect wifi in lenovo g575
In order to connect to a wireless network and the Internet on an IBM Lenovo machine, you must first enable wireless networking via your computer's operating system. Allow about five minutes to enable your IBM Lenovo computer's wireless capabilities.
Click the Windows logo in the bottom left of your screen. Select "Control Panel" from the menu. Click the "Network and Internet" icon in the Control Panel. Click "Network and Sharing Center." Right click "Wireless Network Connection" icon. Select "Enable." Enable Wireless via Switch Check your IBM Lenovo laptop for a wireless networking switch. It is usually on the front of the computer above the keyboard. Slide the wireless switch to the "On" position. Look for a wireless light on the front of the laptop. In some cases a light will come on to indicate that wireless networking is active. Other switches, when active, reveal a green strip of plastic.
Troubleshoot network connection problems http://windows.microsoft.com/en-US/windows-vista/Troubleshoot-network-connection-problems Lenovo support http://www-307.ibm.com/pc/support/site.wss/migr-50402.html
Apr 02, 2013 | Lenovo G575-438343u Amd E-350 1.60ghz...
How do i turn the wifi on on my lenovo ideacentre b3?
Step 1:
Feb 24, 2013 | Computers & Internet
Compaq presario F500. Wireless internet connection not working. Internet works when plugged into modem. D-Link wireless modem working perfectly. Constant red/orange light on next to wireless switch at...
Hi, Thanks for using fixya.
When you connect it to wireless make sure you go into control panel / network view your connection right click on local area network connection choose disable then connect to your wireless connection. Right click your wireless icon by your clock choose connect to wireless network or view available local wireless connection.
Terry
Feb 15, 2011 | HP Compaq Presario F500 F700 and G6000...
I have been using this router for a few years now and have not had any problems until now. i contacted optimum online and and they were able to get me on line by over riding the router; however, when i...
Hi, below are the steps we need to follow:
Step 1: Unplug the end of the Ethernet cable from the back of your computer and connect it to the Internet or WAN port of the router. This will now connect the modem and the router.
Step 2: Take a different Ethernet cable and plug it into the Ethernet or LAN port of the router and connect the other end to the computer. The connection sequence now would be modem > router > computer.
Checking the LEDs
After connecting the devices together, check the lights on the front panel of the router. Ensure that the Internet light, as well as numbered light corresponding to the Ethernet port where the computer is connected is lit.
Configuring a Linksys Router for Cable Internet Connection
At the back panel of the router, there is a reset button, reset it for 30 seconds and we can proceed to the next step.
Step 1: Access the router's web-based setup page. Open internet browser like internet explorer. On the address bar type 192.168.1.1 and press enter. That will be prompted us for username and password. By default, leave the username blank and password is admin(lower case).
Step 2: On the Setup tab, click the MAC Address Clone sub-tab.
Step 3: Select Enabled, then click Clone My PC's MAC.
Step 4: Click Save Settings.
Step 6: Check the Internet IP Address under the Router sub-tab that's on the upper right hand corner under status. If the Internet IP Address has numbers, this means the router has been properly configured. You should now be able to access the Internet.
Dec 22, 2010 | Linksys Wireless-G WRT54G Router
Hi! im having a problem on connecting via wi-fi using this router, my iphone3gs is connecting but theres no internet connection. please help me...
The main problem is with the Internet port connection on this router.
Make sure that the internet port is connected to your DSL modem, or Cable modem. The 3rd light from the left on the front panel is the WAN (Internet) light. It should be solid green or blinking.
You should also be able to connect into the router using a web browser.
http://192.168.0.1
enter the username and password.
If it has never been configured before: username (admin) / password (leave it blank)
Try running the setup wizard in the web browser.
Dec 10, 2010 | D-Link DIR-300 Wireless Router
I have RV082 Router , and Diag Led is constant what to do
Checking the Router's LEDs
The Linksys router's front panel will indicate the status of the connection. After connecting the broadband modem to the WAN or Internet port, the computer to an available numbered port and powering on the router check the lights on the front panel of the router.
The Linksys router's front panel will indicate the status of the connection. After connecting the broadband modem to the WAN or Internet port, the computer to an available numbered port and powering on the router, the following should be lit:
  • 1 - 8 (LAN)
  • DMZ/Internet (WAN2)
  • Internet (WAN1)
  • Diag
  • System
Step 1:
Make sure the System LED is lit.
NOTE: If the Diag LED doesn't goes off, you need to upgrade the router's firmware. For instructions, click here .
Step 2:
Make sure the LAN 1-8 ports is lit depending on the computers connected to the designated Ethernet port.
NOTE: If the LAN 1-8 port is not lit, make sure that the computer is powered on. You can also try connecting the PC using another working cable.
Step 3:
Make sure the Internet (WAN1) and DMZ/Internet (WAN2) LED is lit.
NOTE: If the Internet or DMZ/Internet LED is not lit make sure the Broadband modem is powered on and that the modem is properly connected to the Ethernet port
You can access the web-based user interface utility of the RV082 by using one of two methods:
  • Through the RV082 IP address (192.168.1.1 by default), or
  • Through its default hostname ("RV082")
1. Open a web browser (Internet Explorer or Netscape Navigator)
· By IP address: Type http://192.168.1.1 (192.168.1.1 is the default IP address of the RV082)
and click Go or press the [Enter] key.
· By Hostname: Type http://RV082 and click Go or press the [Enter] key.
2. When the username and password prompt appears, type admin in both the username and password fields. (admin is both the default username and default password for the RV082).
Nov 08, 2010 | Linksys RV082 Router (RV082-AU)
Connecting to the Internet
check for switch on front of laptop(facing you) and look for light to be on.
if that's not the case, it's in control panel, under Network connections..
click on the wireless, and select repair.
check your computers' warranty here 4 FREE
Feb 27, 2008 | Acer Aspire 5500 5570-2609 Laptop
ASUS DSL-N10 Wireless-N ADSL Modem Router Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
