Question about Daewoo FRSU20IA Freezer
Fan in freezer not working - Daewoo FRSU20IA Freezer
  • Daewoo Expert
  • 448 Answers
Needs new fan
Posted on Mar 02, 2017
Ice build up in refrigerator
Ice build up is either obstructed air flow. Too much stuff in the freezer. The freezer evaporator fan is not working or the defrost system is not working. Check obstructions to air flow first and see if the fan is running. If the fan is not running, you mostly likely have a dead fan motor. Not an easy fix for average person.
Jan 06, 2014 | Whirlpool Stainless Steel Top Freezer...
Upper part of freezer not freezing
  • When the top half of a freezer is not working properly it is a sign that the air circulation within the freezer is not functioning. In other words, the freezer refrigerant is still working properly, but the cold air it produces isn't going anywhere: Instead, it is sinking to the bottom of the freezer (heat rises) where it does an excellent job of keeping that half of the freezer cold while missing the top section entirely.
  • The air circulation problem is usually caused by a fan issue. Find where your fan connects to the refrigerant system and pumps the air out into the freezer. If the fan blades are stuck or frozen, you may be able to loosen them or replace the fan. If the fan works mechanically but does not turn on the problem lies with the motor instead. In this case, you can replace the motor or call a professional it may also be fan or evaporator
Dec 07, 2013 | GE 13.7 cu. ft. General Electric Upright...
Samsung Refrigerator with bottom freezer model # RB195BSBB freezer will not hold temperature. There is a fan running a loud and constantly, and freezer will work it's way down to 8 degrees but will not get...
Check for ice build-up in and around the freezer fan where the blades are, if you can see ice in there (some times it may look like white foam but dont be fooled, it will be ice), the fan will be hitting it, defrost the freezer and check defrost element, (you will have to dismantle freezer section to get to it but reletively simple job) disconect from mains first. Good luck
Dec 18, 2010 | Samsung Freezers
Freezer temp turned down but still freezing everying
just look for a better fan to buy to prevent the compressor from having problem . thanks.
Feb 15, 2010 | Freezers
My whirlpool ART 900G fridge freeser, the freezer works but the fridge wont chill
Check the fan that moves the air from the freezer side to the refrigerator side. It is either stuck in ice or not working. Defrost the refrigerator for 24 hours and then restart it Listen for the fan operation be aware that the fan may shut off when you open the door, so listen closely. Defrosting it may fix or the fan may need to be replaced.
Nov 12, 2009 | Whirlpool 11.8 cu. ft. / 334 liter Upright...
Freezer smells hot and sides are hot
Check behind freezer , to make sure the fan which cools the compressor , is working . If not , replace the fan motor , or , something may be blocking the fan blade ( paper , plastic , etc ) .
Sep 12, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Freezer,Frost fan does not work,deos not destribute temp in coolr
Confused: You may well have a defrost issue but your description makes no sense.
keep this link handy for future reference
Oct 08, 2017 | Freezers
Access to the circulation fan Kenmore upright freezer
There is a panel on the lower back wall inside the freezer.
Remove it to access the fan motor.
Mar 21, 2009 | Kenmore Freezers
Red light on
have you checked if the fan is running in the freezer??
if not, check if fan connected to defrost thermostat, if it is suspect defective defrost thermostat but try the fan directly if it doesn't go on, suspect bad freezer f
Apr 20, 2008 | Freezers
Daewoo FRSU20IA Freezer Logo
261 people viewed this question
Top Daewoo Freezers Experts
mike cooper
Ken Wieczorek
Ken Wieczorek
Melissa Martin
Melissa Martin
Are you a Daewoo Freezer Expert? Answer questions, earn points and help others
