Question about Fuji FinePix S7000 Digital Camera
Fuji s7000 my battery door is jammed shut Dave
    Sergeant:
  • 321 Answers
Slide use WD40 drop
Posted on Jun 18, 2009
My fuji s7000 zoom has coloured wavey lines when turned on. It goes back to normal intermitantly but at the moment it is constant Ian
Hi Ian.
If the lines are reproduced in the pictures taken, then the image sensor located behind the lens is starting to fail. The problem will usually get progressively worse until you won't be able to shoot regular pictures anymore.
Call Fuji and ask about repair. You can get a quote from a third party here: Repair.
Regards.
Ginko
May 27, 2011 | Fuji FinePix S7000 Digital Camera
My fuji S7000 automatically shut down (Switched off) frequently while I am taking pictures. Let me know what is the problem?
If the batteries are OK, then the shutdown has a simply-cured physical cause. Open the CF card door and look for a small square opening at the bottom of the door. Look inside this and there should be a small plastic 'plate' or flap. DO NOT TRY PUSHING IT WITH A PENCIL OR NEEDLE etc. The bad news is that if you DO see that flap inside the little square opening, then your problem probably lies elsewhere. But if what you see looks like the tip of a pencil, then THAT'S your problem. The flap is there to keep dust out. It's thickness is needed so that closing the door operates the switch. Without it, the door seems to be open and the camera shuts down. If you can find an alternative for that small plate, your problem should be solved. One solution is to attach a small (about 3mm square) piece of foam pad to the tip of the protrusion inside the square. A typical example for this type of foam pad is what scrapbookers fasten photos into their albums. There will be other solutions - but the loss of that flap will be the cause.
Mar 14, 2011 | Fuji FinePix S7000 Digital Camera
Battery cover replacement required for model s7000 fuji....
This part is only available with the Fuji service centre and you must contact their help site to get the part,.Please check this link below for help:
Fuji service
Nov 30, 2010 | Fuji FinePix S7000 Digital Camera
Fuji S7000 shuts itself down...without a reason
remove the xdcard and use compact flash. also put camera in set mode and run the battery drain function. it seems to reset the battery voltage meter. clean batery contacts with q-tip and rubbing alcohol. worked for me
Dec 27, 2009 | Fuji FinePix S7000 Digital Camera
Quick battery drain with Finepix S7000. Only about 25 shots!
See if there's a firmware download on the support section of the Fuji website.
Oct 20, 2009 | Fuji FinePix S7000 Digital Camera
Where can I get a replacement plastic battery door for Fujifilm Finepix s7000?
I didn't see where anyone had replied to this. II ordered a replacemtn door this morning frmo Fuji. Around $13 including shipping.
Just told them what I was looking for.
1-800-659-3854 and enter extension 3451
Jul 07, 2009 | Fuji FinePix S7000 Digital Camera
Lense stuck in out position
Hi. If your camera is turning on with the lens stuck out. Turn the camera on, and without turning it off, open the battery door, and take the batteries out. Leave it for about 1-2 minutes and try again. This process is call power reset. Usually works. Good Luck.
Dec 22, 2008 | Fuji FinePix S7000 Digital Camera
Fuji s7000
Contact you local Fuji dealer. They should know where you can get parts (or THEY may even to be able to get them for you). It can be done, we fix Fuji stuff all the time.
Jul 30, 2008 | Fuji FinePix S7000 Digital Camera
Flat batteries
a well known problem , this camera eats batteries there are high power (2950MaH) accus , those should be used with this camera even with 2700 MaH it is empty real quick
Mar 04, 2008 | Fuji FinePix S7000 Digital Camera
Camera shuts down when I go to take pic mode
Ahhhhh! I have the same problem occuring!! I cleaned all of the battery terminals and replaced the batteries, and STILL have this problem, although not as frequent. It always happens when I take the best pics, the image shows on the screen for a fraction of a second, and then the whole camera shuts off. Again, I can play back images with no problem. What's the deal here?? It's become so frustrating that I just want to throw the camera in the garbage. It has been such a good camera up until this point. PLEASE, someone help us here!!!
Aug 30, 2006 | Fuji FinePix S7000 Digital Camera
Fuji FinePix S7000 Digital Camera Logo
56 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
