Question about Shimano Rd-Ty18-6-Gsd Bike Rear Derailleur with Bracket
Does anyone have fitting instructions Shimano Rd-Ty18-6-Gsd Bike Rear Derailleur with Bracket
This slides onto rear axle but has no fixing so unsure how to align - comes with a bolt with a semi circular nut which I am guessing is a spacer
4 Suggested Answers
  • 484 Answers
SOURCE: Need to replace a Shimano 7 speed SIS rear
Go to parktool.com/repair for pretty great step-by-step instructions with diagrams and pictures on the procedure. It would be easier to see than to try to tell.
i hope this helps you out,
matthew
Posted on Oct 23, 2009
Coachphil
  • 347 Answers
SOURCE: Describe your shimano xtr rear derailleur spare
Broken inner plate can be a potential warranty. Contact your local bike shop and they can process the warranty for you, if it isn't a warranty then the same shop can order you a new plate.
Posted on Dec 12, 2010
  • 388 Answers
SOURCE: Fitting instructions needed for Shimano Rd-Ty18-6-Gsd Bike Rear Derailleur with Bracket
The semi-circular spacer is what holds the derailleur in the dropout. Take the part that looks like a "C" and line it up on the drop out, the spacer goes on the other side of the dropout. There should be a screw that fastens to the spacer and clamps the derailleur to the drop out.
Posted on Apr 15, 2014
Testimonial: "Thanks - that's spot on, my little girl will now be having fun on her bike in no time!"
Why cant I find any information on my Shimano Tourney RD-TY10 rear derailleur?
Because it's been out of production for some time. There's no useful info to be had anyway. It is adjusted the same as most any rear friction derailleur. It is not useable with indexed levers (click to shift). If you really think you need info do the following Google search: "RD-TY10 site:shimano.com" and scroll through the results.
May 05, 2017 | Shimano Cycling
Can I replace a Shimano RD-TY15 with Shimano Tourney TX?
Main thing with gears is that they have the same number of gears, and that the cage is the same length. Also the RD TY15 has a built in hanger.
The Tourney pictured has a built in hanger (below link) just make sure the replacement does.
SHIMANO TOURNEY TX 55 Rear Derailleur with Hanger Virtue Bike
Apr 24, 2015 | Shimano Cycling
Can I replace a Shimano RD-TY15 with a Shimano Tourney TX?
This may be to do with the replacement having a shorter cage, so it can't go on the big sprocket and big chain ring at the same time.
Try to not use the big rear sproket and the the big front chaining at at the same time,
How do i connect cable to front derailer on shimano comfort 050 gears ?
I'm confused, You show a rear derailleur and ask a question about a front one? Cable for front usually goes from bottom up, through an eyelet then into the holding bolt. Make sure your cable is in the low gear setting and your chain is on the smallest gear. Pull cable tight, and secure. If you have problems, take your bike to the nearest bike shop, they can help you
Sep 01, 2014 | Shimano Rd TX50 Tourney Mega Range Rear...
Apr 14, 2014 | Shimano Rd-Ty18-6-Gsd Bike Rear Derailleur...
Could you advise on which jockey wheels I need to suit Shimano RD-M581 and where to buy them thanks Jon
"Need to suit"????
Find all documentation here.
http://techdocs.shimano.com/techdocs/index.jsp
Then use a search engine to locate a source or just call a local bike shop.
May 30, 2011 | Shimano Rd M581 Lx Rear Derailleur, 9...
Describe your shimano xtr rear derailleur spare Problem: Broken inner plate (xtr rd-m972 shadow gs)
Dec 12, 2010 | Shimano Xtr Rear Derailleur
Shimano Rd-Ty18-6-Gsd Bike Rear Derailleur with Bracket Logo
46 people viewed this question
Top Shimano Cycling Experts
Michial Gueffroy
John Egan
John Egan
Eric Hidle
Level 1 Expert
Are you a Shimano Cycling Expert? Answer questions, earn points and help others
