Question about Whirlpool Washing Machines
Whirlpool LXR9245EQ2 top loading washer tub won't fill
Whirlpool LXR9245EQ2 top loading washerFor some strange reason, when I started the washer this morning, it went straight to agitating instead of filling with water first. I tried changing the cycle, even tried putting it on a rinse cycle, still no fill. Changed the size of the load, no fill, but when I moved it while the cycle was agitating, the water started flowing as the size knob was between sizes. I was able to hold it there while the tub filled and get my load completed, but I can't do this for every load. Is this something I can fix myself? Payday isn't until the 1st.
  • 20 Answers
Try taking the knob off and see if the nut is tight on the timer,it might if came loose
Posted on Jun 20, 2009
Water leak at bottom of Whirlpool Estate washer. Removed the cabinet. No leaks from the water pump, hoses or inlet valve. The tub leans a little toward the front of the machine. When filling/rinsin
It is common on Whirlpool models for the water to splash out the top when filling especially when sheets or nylon cloth is loaded in the washer. Air fills the cloth and balloons the garment up this caused water to bounce off the garment and splash out the back. This is the most common reason for those mysterious leaks. Lowering the water pressure coming into the washer can help prevent this.
Jan 25, 2015 | Whirlpool Washing Machines
Whirlpool top loading washer won't fill completely
did you shorten the stand pipe for the outlet drain ?if not try putting a short extension on the top .
Nov 18, 2017 | Whirlpool Washing Machines
Whirlpool top loading washer, LXR9245EQ2, quit agitating, spinning and makes a clacking noise, pump looks like it's still holding the water in the tub though and won't pump out?
There are two clips that hold the pump to the motor, remove it and inspect, turn pump axle in either direction. If not replace the pump. However if you remove it you may find a sock or something in which case you can remove item and put back into service. If jammed you need to replace with a new pump. Good luck, masta tech
P.s.if water remains in tub it has something blocking it, be ready to capture any water in tub when removing hose clamps. If it a small amount you may be able to just lean it backward to hold water.
Aug 21, 2011 | Whirlpool LSR5132PQ Top Load Washer
My Whirlpool Gold Ultimate Care washer doesnt agitate or spin. Makes a strange almost clicking like noise instead.
sounds like the drive block under the tub is stripped out or broken and it needs replacing,it sits under the tub to help drive the tub on direct drive models
Jul 18, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool LXR9245EQ2 tub won't fill at beginning of cycle
HI, you have a combination issue. the Water fill level pressure switch and, the cycle selector switch are both damaged and, they should be replaced. the total cost of these switches will run you about $90.00.
We recommend the hands of a skilled service tech when repairing this type of electrical issue.
Jun 18, 2009 | Whirlpool Washing Machines
Maytag Atlantis MAV6200AWW Washer Problem?
I HAVE AN ATLANTIS MAYTAG WASHER . I HAD THE SAME PROBLEM AND I SOLVED AS FOLOLWS. REMOVED THE MOTOR, I APPLIED GENERAL PURPOSE GREASE ON BOTH SIDES OF THE SLIDING MOTOR SURFACE PLATE (MOTOR BASE) . THE GRASE HELPS THE MOTOR TO SLIDE BECAUSE AS YOU KNOW THE MOTOR DOES NOT HAVE ANY ADJUSTMENT. TRY IT PLEASE . GOOD LUCK
Feb 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Frigidaire stackable will not stop filling with water or agitate.
yes unless pressure switch(water level switch)detects proper fill level wash will never start agitating some washer will not spin if switch does not detect empty tub
Jun 02, 2008 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool LTE6234D Top Load Stacked Washer / Dryer
Is your drain hose above the washer tub.. its got to be higher or will syphone out
Dec 01, 2006 | Whirlpool LTE6234D Top Load Stacked...
Washing Machines Logo
244 people viewed this question
Dan Webster
Dan Webster
Sal De
