Question about True T-35
Condensation on cabinet of True Freezer model number T-35
Temp on inside is 5 degrees
Candyhelp
  • 136 Answers
SOURCE: true t-35 temp control
in the top right hand corner there should be a thermostate gauge
Posted on Mar 18, 2008
  • 89 Answers
SOURCE: My True beer fridge is freezing inside.
call repairman sounds like low on freon or thermostat problem either way better to have pro do it hope this helps
Posted on Sep 05, 2008
farfield
  • 462 Answers
SOURCE: true 2 door reach in freezer
If its getting warmer or more humid where you are this is probably a sign of needing to clean your outer coils. Remove the panel covering the compressor and check the condition of the coils. Clean with a nylon brush or wire brush. Or blow out with compressed air.
If the outer coils look ok see if they feel warm up and down the sides. If they dont you may have a defrost problem. If they are warm recheck them in 30 minutes if still warm or warmer and no one has opened the door check the lite inside, and the fan inside (it will only run with door closed). Hit the switch and see if lite goes out and make sure the switch is being activated whith the door closed.
It could be low on refrigerant or an inefficent compressor but not laikey as much as these other items are.
The last thing is the thermometer could be reading wrong or out of calibration. Is it Electronic? Yes - Then its most likely one of the other problem before. If its mechanical (bi-metal) get another thermometer you trust or a new one and check it before you trust it. 2 of them telling you its 5'f then Id believe it other wise one or both of them are wrong.
Posted on Mar 12, 2009
farfield
  • 462 Answers
SOURCE: i have a 2 door reach in true freezer which is now
If the outer coils look OK see if they feel warm up and down the sides. If they don't you may have a defrost problem. If they are warm recheck them in 30 minutes if still warm or warmer and no one has opened the door check the lite inside, and the fan inside (it will only run with door closed). Hit the switch and see if lite goes out and make sure the switch is being activated with the door closed. And check the door seals any vinyl cracked on them they need replacing but can be warped sometimes letting in warm air (usually a sign of frost inside the door or water leaking out but not always).
It could be low on refrigerant or an inefficient compressor but not likely as much as these other items are.
jeffbvegas1
  • 520 Answers
SOURCE: True Freezer
Hopefully you were good on cap tube length is this is an important aspect of this system.The length must be matched
Posted on Jul 01, 2009
Where is the condensation forming? Usually a door seal or door closure problem, or site conditions (high ambient). Make sure the condenser grille is clear and clean, as the thermostat can easily be fooled into running long periods
Apr 14, 2014 | True T-35
Refrigerator condensation inside
Whether on the outside of the cabinet or the inside it is because you have warm moist air hitting the coldness of the refrigeration. It can also happen if you put hot food into the cabinet.
Also at the back of the inside of the cabinet there is often a small drain that empties the water from the defrost cycles. Check that they are clear.
Feb 02, 2018 | Frigidaire Refrigerators
What is the normal operational pressure in lo/hi side at the compressor of commercial freezer like dispaly case, reach in cabinet or other any low temp refrigeration uses 502 or408A/404a. is there any rule...
why yes there is. Generally speaking, the head pressure should be around the "ambient +30" rule.
That is, measure the entering air temp to the condenser, say 75 degrees. Now add 30 to that and get 105 degrees. Look at a P/T chart and see what the pressure is for that temp which is about 253 for R-404-A.
The evap on a freezer leads the load so, as a general rule, the evap temp is going to be around minus 10 degrees to get a 0 degree box. Coolers are different. So, the pressure for a minus 10 evap is around 25 or so. But the unit has to be close to operating temp. If the box is warm, naturally the pressure is higher. And what influences the pressure is whether or not it's a TXV or a cap tube system.
If a TXV and no receiver, charge by subcooling. If a receiver, fill by sight glass. If Cap tube, charge by superheat.
Hope that answers your question.
Oct 03, 2010 | True 49 cu. ft. / 1388 liter Commercial...
Last two weeks refrigerator temp goes anywhere from 30-35 degrees and freezer temp -5 to -1 degrees.several times a day we attempt to set temp to reccommended temp, but no success.we do not have mannual,...
fridge temp should be 30 to 35 degrees/freezer -1 to -5 f or between 2 to 5 C for fridge and -18 to -22 C for freezer several times a day is too often...... try once every 2 days without opening door in between checks....
Feb 11, 2010 | GE Profile PSW26P Stainless Steel Side by...
Refrigerator temperature climbs and takes too long to recover.
Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
  • Send this information so I can help you better, Thanks, Sea Breeze
Mar 28, 2009 | Refrigerators
16 month old GE Profile refrigerator with bottom freezer can no longer maintain freezer temp. With control set at zero degrees, freezer temp varies from twenty down to six degrees. Both sides of cabinet...
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Nov 25, 2008 | Pds GE Profile Energy Star 22.2 Cu. Ft....
Outside of fridge condensation; hissing boiling noise
under the compressor there will be rubber bushes which would have got damaged so change the rubber bush and ur problem may get solved
Jul 25, 2008 | LG LRFC25750 Refrigerator French Door
GE 25 side by side refrigerator ice maker problem
Assuming the temp inside the freezer is at around 0 or -2 degrees, it should dump ice every ~50 minutes or so. Again, depending on temp's, an Ice Bin should fill within 24 to 48 hours. If your freezer temp is running at around 10 degrees, everything will obviously still be frozen (below 32), but the ice maker will take longer to freeze the water than it would if it were at 0 degrees. Open both doors and place the palm of your hand on the partition between the freezer and Fresh Food compartments... (where the door gaskets seat when they're closed). The temp of the partition should be about 5 or 10 degrees warmer than body temp., If it's hotter than that, you found the problem. Either the condenser coils are dirty and need a good cleaning OR your condenser fan motor (the fan in back, near the floor in the compressor area) is failed or about to fail.
Jul 29, 2007 | Maytag MSD2756G Side by Side Refrigerator
True T-35 Logo
20 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
