Question about Vermeer BC935 9IN Brush Chipper
Auto feed not shutting pollers down - Vermeer BC935 9IN Brush Chipper
Where is the auto shut down relay on a 1999 dodge durango
The auto shut down relay is located in the fuse box that is located under the hood of the Durango. The auto shut down relay should be marked for location on the underside of the lid of the fuse box.
May 17, 2014 | 1999 Dodge Durango
Tip
Copiers Sharp AL-1631 AL-1641CS DESCRIPTION OF SPECIAL FUNCTIONS
Toner save mode
Reduces toner consumption by approximately 10%.
Power save modes
The unit has two power save modes of operation: preheat mode and auto power
shut-off mode.
Preheat mode
When the unit enters the preheat mode, the power save indicator will light up
and other indicators will remain on or off as before. In this condition, the fuser in
the unit is maintained at a lower heat level, thereby saving power. To copy from
the preheat mode, make desired copier selections and press the start key
using the normal copying procedure.
Auto power shut-off mode
When the unit enters the auto power shut-off mode, the power save ( ) indicator
will light up and other indicators except the ONLINE indicator will go out. The auto
power shut-off mode saves more power than the preheat mode but requires a
longer time before starting copying. To copy from the auto power shut-off mode,
press the start key. Then make desired copier selections and press the star key using the normal copying procedure.
Auto clear
The unit returns to the initial settings a preset amount of time after the end of copy, or
scanner job. This preset amount of time (auto clear time) can be changed.
Stream feeding mode
For description of the stream feeding mode, see "Stream feeding mode".
Resolution of AUTO & MANUAL mode
You can set the copy resolution used for AUTO and MANUAL ( ) exposure
mode.
on Mar 14, 2010 | Office Equipment & Supplies
Panasonic KX-P7110 printer won't print from the auto feed tray, shows error when printing is attempted.
Please check the entire length of the paper feed path from input to output for a small piece of paper that is stuck causing a "Paper Jam".
You are lucky that you can still print manually as this usually shuts a printer down until the jam is found and removed!
Good Luck!
Rich Lilja
Jan 06, 2014 | Panasonic KX Office Equipment & Supplies
Constantly runs when on auto and won't accept paper
Shut off power and turn the shredder upside down. It is highly likely you will find shredded paper jammed in the mechanism, especially near the center where the feed sensor is located. A thorough cleaning should get your shredder operating again
Feb 02, 2013 | Staples SPL638X (CrossCut) Shredder
ITS ALWAYS SHUTTING OFF BY ITS SELF AND IMM SOOOOOOOO FRIGGIN PISSED OFF WITH IT WHAT SHOULD I DOOO!!! EVEN WHEN THE BATTERY IS FULL!! IS IT LIKE THAT OR WHAT
please watch the setting and if you find there any stand by / auto shut down time setting then changed the timing.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Jan 31, 2010 | Megxon X32 Digital Camera
Problem with Banner Shredder Shark, Model # SH 92050P
Blow some canned air down into the feed slot to clean the sensors.
Sep 24, 2009 | Banner American Products QuikFinish ...
Pages aren't being sent properly
BUILD UP OF INK ON THE POLLERS AND SOME MACHINE HAVE WHERE YOU CAN SETUP INTERMITTING TIME DELAY INBETWEEN FAXING LETTING THE MACHINE COOL DOWN BETWEEN FAXING AND I HAVE ANOTHER PROGRAM THAT MAY HELP IN THIS MATTER CALL GREENPRINT WORLD.COM
ROD
Feb 04, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
I have to hold down keys for 2-3 seconds to type. How to correct?
It might be due to a service called "ATI Hotkey Poller" running
which is intermittently slowing the keyboard typing down.
To disable it in Windows XP Home:-
Go to Start->>Run->>type "msconfig"->> click the "Services" tab->> uncheck Ati Hotkey Poller->> Then Ok, then Restart computer.
hope this helps
chris
ziraffa@hotmail.com
Dec 15, 2008 | Toshiba Satellite A105 Notebook
Keyboard lag
Does external kybd do same? if yes, ck disk space (c: properties) and mem usage (task manager-performance)
IF No, then you may have a bad kybd...suggest shop replace-easy fix to screw up :(
Dec 09, 2008 | Dell 0Y3740 Keyboard
Auto Shut off doesn't work anymore
Though I only work with Fellowes shredders this sounds like a paper feed sensor issue. If your unit has a mechanical paper feed sensor you can try to jiggle it in and out to see if any paper may have become jammed behind switch. If the unit has an electronic sensor it may simply need to be cleaned with a Qtip dipped in rubbing alchohol. Either of these should be located in the center of the paper throat.
If neither of these help your paper feed sensor or your pc1.gif board has gone bad and you will have to contact your manufacturer for further parts availability.
Dec 20, 2007 | Tech Solution TS-8000 Cross-Cut Shredder
Vermeer BC935 9IN Brush Chipper Logo
57 people viewed this question
Top Vermeer Heavy Machinery Experts
john h
L Pfaff
L Pfaff
Jerry Kramer
Jerry Kramer
Are you a Vermeer Heavy Machinery Expert? Answer questions, earn points and help others
