Question about InFocus IN2104EP Projector
Infocus firmware update - InFocus IN2104EP Projector
How can I get firmware, if it was already deleted from the manufacturer website?
Go here: https://portal.infocus.com/support/Product%20Pages/downloads.aspx?mic=LP70%2b&on=downloadsthen down load the file then find the text document "D3 D3+ firmware upgrade instructions.pdf" in C:\LP70plus\002-0870-08\I , or where ever you saved it. That will give you the complete instructions on how to upgrade.
Jan 30, 2015 | InFocus LP70+ Multimedia Projector
Infocus in2114 firmware wont update
search on google plenty of fw availible but unknown if you can downgrade it without flashing back to stock
Nov 06, 2013 | InFocus IN2114
My infocus 1503 short throw projector is having issues. When I turn it on the fan gets very loud, like on overdrive. It then will just shut off unless I tap the side of it. After tapping the fan gets quiet...
I own two of these projectors. You need to update the firmware to 1.03 which can be found on the infocus website. This solves the fan issues which also causes premature shutdown of the projector. Once you download the update, open it, there will be step by step instructions on how to do this procedure. I could not get this to work with Vista 64 so you might need to run this on XP or 7.
Aug 22, 2011 | InFocus IN1503 DLP Projector
My infocus 1503 works however once it is turned on the unit sounds as though it is ready to take off. The fan is very loud then after a few minutes it quiets down and then the fan becomes very loud again....
Mar 11, 2011 | InFocus IN1503 DLP Projector
Projector will not power on.
Since you see a the power button light up green there is a chance that the power supply is still good. Try updated the firmware. You can get it from the infocus website. If that doesn't work then something is wrong with the power supply. I can repair it if you'd like. My ebay screen name is gtitubro.
Apr 28, 2010 | InFocus ScreenPlay 5700 Multimedia...
I have InFocus LP120 the picture comes and goes within fraction of a second when connected to any video device.
First try another cable, if you tried that already, then try a firmware upgrade. Infocus has the firmware on their website. If that doesn't work then you have a defective main board.
Oct 12, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Gray Screen Infocus X1
reset the settings to factory default. if that does nothing, you may have video processing issue (main board-dmd chip interface).
Jan 22, 2009 | InFocus X1 Multimedia Projector
Infocus sreenplay projector
Contact the manufacturer for a firm ware upgrade. My two brother in laws/sisters own this same pj and had the same issues you are talking about. Once they installed the update [aka: firmware upgrade]it created a solution to the problem.
Let me know how it goes. They can either mail you a CD, direct you to where on their website, otherwise email you the update to download. You have to connect your pj as well.
Let me know how that goes. I'm fairly confident that will fix it. There was a certain time frame [manufacturer dates], and serial numbers that had these issues.
Oct 02, 2008 | InFocus ScreenPlay 4805 Multimedia...
Infocus In24+ driver?
I think projector is do not need driver, i see in the infocus website as long as you connect it to the computer it always display.
please see the details of your infocus here:
http://www.infocus.com/Support/Products/Projectors/IN24.aspx
and also you can download updates firmware to fix some error display.
May this help, best regards, melnavz
Jan 14, 2008 | ASK Proxima Proxima DP2000S Data Video...
InFocus IN2104EP Projector Logo
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
color wheel light...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
