Question about Samsung SCH-U310 Knack Cell Phone
Battery gets hot in standby and drains - Samsung SCH-U310 Knack Cell Phone
What is the life of my satellite l30-101 battery off the ac charger
Toshiba's line of Satellite PC laptops offers a variety of screen s that are customizable when ordered online. The laptops offer built-in webcams and backlit keyboards. Most Toshiba Satellite laptops use six-cell lithium-ion batteries that can last up to six hours. To reach that six-hour mark, you can use several tricks to maximize your battery's capacity.
Charge your battery completely before its first use. Check your user manual for the exact charging time required, which is typically at least 12 hours. Discharge your battery completely every two months. Allow it to drain fully before recharging it. Recharge it completely, for at least 12 hours before using it again. Remove CDs and DVDs from your laptop's drive when not in use. These drives spin when loaded, which can drain your battery unnecessarily. Set your laptop to hibernate mode when you need to take a break. This conserves more power than standby. Store your laptop battery in a cool place. Never let the battery sit in direct sunlight or leave it in your car on a hot day. For even longer battery life, remove the battery from the laptop which can get hot while in use when you are plugged in. Turn off your Wi-Fi connection when not in use. Constantly searching for a Wi-Fi connection can drain your battery faster. Work in only one program at a time. The more programs you have open, the faster your battery will drain. Unplug any USB devices, especially those that charge when plugged in, such as your cellphone. These will drain your battery quickly. Dim your Satellite's screen to conserve battery. Hold down your "Fn" key and tap "F6" several times to dim the screen. The "F6" key should show an open circle with small lines radiating out, to symbolize a dim display.
b>
Feb 12, 2013 | Toshiba Satellite Computers & Internet
How many years can I get out of my laptop
That will depend on how much you use it and treat it ?
Hope this helps.
b>
Jan 22, 2013 | Toshiba Satellite L455DS5976 Notebook
Xperia Play Battery Drain and screen malfunction during charge.
Apps and services in the background drain your phone even while in standby mode. Turning off your 3G or 4G connection will deprive you of the internet but it will still permit you to get phone calls. Meanwhile, you are not having apps such as Google constantly draining your power in the background. And they are, even in standby mode. Charge your phone frequently to help preserve battery life.
Sep 17, 2017 | Sony Ericsson - Xperia PLAY Mobile Phone -...
Htc wildfire a333 battery hot software
Htc wildfire a333 batterynot getting anyware
Apr 21, 2012 | Cell Phones
My nokia 6700 classic (about a year old and little use), has, since I came back from the UK, has a very short battery life - 12 hours with no use. I have replaced the battery with a new nokia battery and...
machines and the airport cannot intercept your phone, it's the phone that can cause disturbance to aircrafts.
BTW, for that case, your cellphone causes the battery to drain faster than its standby time . the terminal might be shorted. Also consult a technician to have your camera and Bluetooth be checked too.. ")
Feb 10, 2011 | Nokia 6700 Classic Cell Phone
I have tried removing battery and reinstalling. i have reset with button and have used new ac adapter. I get power to laptop but all it will do is the power light blinks like in standby mode. it will not...
Due to regular use of the notebook, some static charges tend to stay in the computer, and sometimes results in not allowing the computer to function properly.
Please follow the power drain procedure to confirm the same:
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30seconds to 1 minute.
4. Put the Battery in.
5. Reconnect the AC adapter.
6. Turn on the Notebook power.
7. Restart the Notebook.
Please get back with the results.
Mar 19, 2010 | HP Compaq Presario 2135US Notebook
When the bike is switched off the battery drains
If the battery is getting old (4 to 5 years) it may not be able to hold a charge as well as it did. Have it tested, it may need changing. If an alarm is fitted to the bike it will drain the battery as it will use power even in standby mode.
Mar 12, 2010 | 2000 Harley Davidson FLSTC Heritage...
Battery drains very fast
First, before we proffer any solution, we need to know the problem.
Before the battery drains, does the phone gets hot in any way?
If your phone gets hot, then maybe the problem is from the phone board.
But if your phone does not gets hot before battery drains, then it is obvious that the fault is from your phone battery.
The solution therefore is for you to change your battery to an original one. The same problem might persist if you don't purchase a good battery, please take note.
I wish you the best.
Dec 08, 2009 | Nokia 5310 Cellular Phone
Fast battery drain only 6 hours standby (new battery)
i think some of the motorola mobile phones has a fast battery drain..
Feb 24, 2008 | Motorola Mobility E398 Cellular Phone
Samsung SCH-U310 Knack Cell Phone Logo
20 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
