Question about Kenmore 44102 Front Load Washer
F28 error message
My kenmore elite HE3t front loading washer washed a load of towels but had an error of F28. It wouldn't unlock the door but eventually I got it. I tried the drain and rinse but that didn't work. I took the towels out and they were a bit wet. I changed loads, set the cycle and now it will not wash. It keeps showing me the same F28 error message and will not rinse and drain.
  • 15,935 Answers
F28 is a serial bus error from the CCU (Central Control Unit) to the MCU (Motor Control Unit).
All you need is some Electronics contact cleaner spray and a 1/4 inch socket to remove the top of the machine and the back of the machine.
The CCU is the computer looking box at the top front right hand corner.
Find connector M13, (has red marking on it and only 3 wires) disconnect it by pushing the retainer tab back and pulling gently on the connector.
Spray the contacts of the connector and computer with connector cleaner.
Then re-assemble connector.
The MCU is in the back lower left corner.
Find the connector with 3 wires and red mark, and remove this connector in the same way you did the other, spray it and re-install.
Put the back and top back on.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 11, 2010
Elite HE3t washer, in the middle of a load, it stopped. it flashes dL, F
door lock error...door lock mechanism broken,,,replace door switch,,,if your lock out remove toe panel and reach up and pull tab,,always unplug first...good luck
Sep 03, 2011 | Kenmore Elite 45986 Front Load Washer
We have a he3t washer that is showing an error message of F DL code? actually, it is an he4t
Hello and welcome to FixYa
DL f is a door lock error and is caused due to an issue with the door lock when it is unable to lock/unlock. Please check the door lock mechanism/door switch assembly and replace the part that has gone bad so that the issue is resolved. Please get back to me if you have any other questions.
Kevin
Jul 15, 2011 | Kenmore Elite 45986 Front Load Washer
I notice F22 error message on washer. Door seems to be jammed and will not unlock
This is a door lock failure code and it means the door lock is broken or just failed to unlock. Click on the links below for the detailed instructions for manually unlocking the door and replacing the door lock and switch assembly if it has indeed failed.
Manual Door Unlocking of Whirlpool Duet and Kenmore Elite front-Load Washing Machines
Replacing the Door Lock and Switch Assembly on Whirlpool Duet and Kenmore Elite front-Load Washing Machines
Mar 12, 2011 | Kenmore HE2 Plus Front Load Washer
Kenmore Elite HE3t 11042922200 Front Loading. F02 drain Problem
We experienced the same thing. I was able to restart and locate the noise to the water pump. After disassembling the water pump found the impeller shaft sliding out. For some reason this shaft will not stay in place. Had to order a complete pump assembly as the electric motor is not available.
Jan 15, 2010 | Kenmore Elite 45986 Front Load Washer
WHAT IS DU?
DU is door unlock error - A Door Unlock Error occurs if the door cannot be unlocked. It will try to unlock the door 6 times before displaying the error.
Solutions -
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
  • May 19, 2009 | Kenmore Elite 45986 Front Load Washer
    Kenmore Elite HE3t model 42922
    After the complete wash cycle is finished, the clothes are still soaking wet sometimes. This is not an every load problem.
    Aug 12, 2008 | Kenmore 46462 Front Load Washer
    F28 ERROR
    I have a Kenmore Elite that has done the same thing, I had to press power and then start (to start a new cycle) then the stop/cancel button and this unlocked my door. Power and then cancel/stop just turned off the power again and did not unlock the door. I hope this works for you.
    Jul 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Kenmore 44102 Front Load Washer Logo
    171 people viewed this question
    Sal De
    fordexpert
    Jim Goldsmith
    Jim Goldsmith
