Question about Logitech X-530 Computer Speakers
Only have the subwoofer, no speakers can i still hook-up to tv?
How do I hook up the receiver to the subwoofer to the tv
Here's the Owner's manual -> https://docs.google.com/viewer?url=https%3A%2F%2Fwww.paradigm.com%2Fdownloads%2FOM-100.pdf.
There are many ways to connect the system depending on your receiver's outputs and the speakers. Usually, the TV L/R output connects to one of the receiver's inputs. The receiver's preamp sub output goes to the powered subwoofer. The receiver's FL/C/FR/SL/SR/RL/RR speaker outputs go to the respective speakers.
Mar 03, 2017 | Paradigm Audio Players & Recorders
Can u hook it directly to a lg tv tried but sounded really bad
What are your front channel speakers connected to? Or are you just using the TV speakers for that? Most TVs don't have a dedicated subwoofer output and that's a necessary level of pre-amp out to give the subwoofer proper low frequency signals. If you have an amp/receiver then it probably has a subwoofer output.
Feb 23, 2016 | Pioneer SW-8MK2 Andrew Jones Designed...
I tried hooking up my boston acoustic soundbar to the tv's audio inputs, but i get nothing. if i hook it up to my dish receiver i get sound, but i cant use my bluray, cause its hooked in the receiver. why...
because your tv output is not of suffieient power to drive the soundbar. The soundbar needs to be hooked up to an amplifier that is being fed by your tv line out (or earphone output)
Mar 20, 2011 | Boston Acoustics TVee Model Two TV...
We cant find the right cords or hookups to our speakers and how do they hook up to your tv
Speakers don't hook directly to a TV unless your TV is unique and has its own amplifiers (not likely). Speakers are driven by amps, amps are usually inside a receiver and IT would connect to your TV to receive sound program. However, the TV usually has serious audio limitations (or we wouldn't need receivers and after-market speakers, right?) so why not get the audio IT monitors from the source itself and conenct it directly to the controlling receiver, which specializes in audio?
Aug 29, 2010 | Theater Research TR-2810 Main / Stereo...
I have a Sony DVD-SLV-271P to hook up to a Samsung TV. I have five wires coming out of the DVD player and need help
yellow is video, red is speaker, white is speaker, you should only have to hook up the three to the back of TV.
Apr 07, 2010 | Audio Players & Recorders
Purchased speakers with no manual. Do I need
Ummm, TV's don't usually have the facilities and amplifiers to drive external speakers. Be more specific with the brands/models.
Dec 27, 2009 | SDAT CES500 Speaker
Need a diagram to hook my Bose CinemaT speakers. When I hook it directly to the tv no problem but can't figure out how to hookup my reciever and CD player to work also? Help Please
You'd be better off hooking the speakers to the RECEIVER'S speaker outputs, THEN hooking your TV audio output to an unused receiver input, such as AUX. The signals from your receiver cannot reach the TV; thus your CD player and radio will not play through the speakers if the speakers are hooked to the TV. All receiver INPUTS are designed to accept the same signal level; thus, you can use any input for your TV audio, such as Aux, DVD, CD, etc. Just remember which input you're using for the TV audio, and everything should work fine. Almost all receivers have an AUX input; hopefully yours also has a dedicated CD input to avoid confusion. The you simply select the AUX input to hear your TV through the speakers.
Dec 26, 2008 | Bose Cinemate Digital Home Theater System...
How to hook my altec lansing speakers to my TV? and my laptop @ the same time
You can do this through a receiver (like a stereo receiver). Hook the tv up to line 1 and the computer up to line 2, then hook the stereo receiver output to the input of your subwoofer. Then shift the receiver from line 1 to line 2 (as easy as pressing a button on the front of the receiver) to hear either one through your speakers.
Nov 26, 2008 | Altec Lansing ADA 885 Computer Speakers
DURABRANS DVD HOME THEATER SYSTEM sts 96
umm, I hooked mine up yesterday, and I my tv has dolby digital signals going out. If your tv doesn't, that will cause some (if any) to not work. Also, make sure you have your sound setting to stereo and not mono, that will also cause some of the speakers to not work correctly.
Finally, make sure you have your tv's Audio (left/right) OUT going to the main units (your dvd player's) Audio (left/right) IN.
And have your video going from the main units OUT to one of your Tv's cmp or vid IN
Thats about it really.
Justin Fox
Dec 24, 2007 | Audio Players & Recorders
Logitech X-530 Computer Speakers Logo
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
