Question about Danby DIM1524W Ice N Easy Portable Ice Maker
Ice maker starts then shuts down - Danby DIM1524W Ice N Easy Portable Ice Maker
Ice maker will not shut off when full of ice.
There is usually a bin switch with a probe that is in the bin, when the ice covers the probe, the switch opens shutting down the machine, as you remove ice and uncover the probr the switch closes and the unit starts. Check the switch for continuity, its probably staying closed thus keeping the unit on
Aug 31, 2011 | U-Line Icemaker
The ice maker has stopped making ice. The red light is flashing (in the freezer. Part ot technician?
Hi, The blinking red light is just a sensor that shuts down the ice maker when the door is open so that it will not dump. This should have no effect on why the ice maker is not working unless the little door that blocks the beam does not return when the door is shut again...
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Oct 02, 2010 | Whirlpool Refrigerators
Unit runs but no ice.in searay boat fan does not want to come on. Unit runs. .Live in chatham ont. canada. what to do. dave @beams56@yahoo.com
My unit turns on works for a while then shuts down, fan would not re-start every cycle, causing over heating and shut down, cleaned the fan, oiled the bearings, cleaned all the elec. connections, seems to work now.
Jul 15, 2010 | Raritan Icer-ette Ice Cube Maker
My ice marker will not stop making ice the arm
This problem is going to be the ice maker itself. The arm you are talking about is the shut-off mechanism for the ice machine. Just before the ice machine starts to make ice, the arm slowly rises. Then the arm falls down, if there is ice blocking the arm from falling all the way down it will not make ice because there is plenty! If the arm is able to fall down completely, the ice machine will make ice like normal. If your ice maker is making ice regardless of the arms position, something is wrong with the ice maker. Depending on who replaces this, it could cost anywhere from $100 to $200.
May 28, 2010 | Roper RS22AQXKQ Side by Side Refrigerator
Hoshizaki ice maker am-50bae . Made ice regularily--- filled ice bin half way...next day-- all ice melted away with no more new ice? next day shut off for 3 hours now o new ice.
make a few quick checks. If there are water filters on the system, be sure they are not restricked. Could be clogged. Next, check the bin stat. It usually is mounted in the ice bin. If it breaks or goes bad, it shuts down the machine. Start there and let me know if I can be of any further help.
May 19, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Ice maker is not working.
Ice maker has built in thermostat that turns cycle on at around 10 degrees F. If freezer temp does not reach that point the ice maker will not cycle. So either the freezer is not cold enough or the thermostat is faulty.
Make sure that the ice maker motor that turns the cams and controls the various stages is also working.
Apr 08, 2017 | Frigidaire 20.6 cu. ft. Top Freezer...
The ice maker is not working
There is a way of testing the ice maker.
Diagnostics for ice maker starts on page 27
Apr 01, 2010 | Samsung RF265AA Bottom Freezer French Door...
Ice maker shut off arm keeps raising and shutting off the ice maker
There is a spring inside the icemaker head. It sounds like it has broken.
Reminder. When the bin is full and the arm comes down, if the ice has fallin in a way that it stops the arm real high. You may have to pull it down to start it again. Although this should not happen very often.
Please rate solution
Sep 22, 2009 | Amana Refrigerators
LG Refrig ice maker on model LSC27950 overflow bar i think is stuck in one position because it made to much ice and jammed it up. now no ice is being produced
you lift the bar up to shut the ice maker off . or the ice fills and shuts the ice maker off . simply push the bar back down to star the ice maker in operating again
please rate solution thanks
Oct 19, 2008 | Refrigerators
Danby DIM1524W Ice N Easy Portable Ice Maker Logo
22 people viewed this question
Top Danby Heating & Cooling Experts
Dan Webster
Dan Webster
Dennis Boxerman
mintvl
Level 1 Expert
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
