Question about Fitness Quest Eclipse 1100 Hr/A Elliptical
Edge 491 exercycle says e2 error code
Bike works but e2 comes up as code.bike is used could this just be low battery
2 Suggested Answers
SOURCE: edge 491 exercise bike monitor panel dead
http://www.academy.com/images/pdf/Fitness_Quest/Edge_Recumbent_Bike_491r.pdf
Mine went dead last Spring. I ordered a replacement part from Fitness Quest. I think the link is above. Actually, while I was waiting for the part, I reconnected all the wires on the whole bike and the panel worked. So I actually have an extra new working panel if Fitness Quest doesn't have the part for some reason and u want mine. Double check ALL the connections of the wires first. They come loose easily.
Nancy
Posted on Aug 10, 2009
I have a fitness Edge 491 Recumbent bike that the display window reads E1 . the resistance is hard and I am unable to reset. when I press start stop for 2 seconds it all looks like it will reset but then...
The bike is no longer sold and the company went bankrupt in 2014, so neither support nor parts are available from the company. Try the results of this Google search regarding the E1 error code:
fitness quest edge 491 e1 error Google Search
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Nov 25, 2017 | Cycling
Error code 80 and then 138 quantum edge w/c
Low voltage. Check the batteries and connections to the power module and joy stick. Make sure no loose connections are present.
If problem still persist, then maybe new batteries are needed.
Sep 16, 2013 | Quantum Edge 6 Wheelchair - Used Electric...
Shinco fault code e2
I recently had the E2 error code on 2 units a KFR-35GW/BMVE and KFR-50GW/BMVE. I recommend checking the refrigerant. Our's was extremely low and having it filled/charged resolved the issue. In all of the Googling, this solution never came up.
Initially the error code would come on and flipping the breaker off for 10 mins or so would reset it and it would work. Probably did this about 10 times every so often (like over weeks). Eventually this did not work and researching online led us to believe that either the indoor pipe sensor or indoor PCB was bad. Spent lots of time online trying to find these replacement parts to no avail. Was finally able to get a friend of a friend that is an A/C person to check them out and discovered the Freon was too low. Hope this helps someone else out there stuck with these "unserviceable" units.
May 06, 2013 | Heating & Cooling
My Proform 100 ZLX Exercycle is stuck in low/zero pedal resistance, and doesn't respond to console settings. Can this be economically fixed?
follow the steps, and fix it. God bless you
Be aware that the resistance is often the part that requires repair. Resistance is managed magnetically, so often if the machine is working, but the resistance isn't setting correctly or at all, check the bolts that secure the magnets. If they are loose, the resistance will slip. If the bolts are fine, check the magnets themselves by using a refrigerator magnet and see if it is attracted or repelled by the your fridge magnet. If not, the magnets have de-magnetized and need to be replaced.
Dec 05, 2012 | Exercise & Fitness
Where can I buy a belf for my Edge 491 bike?
http://www.fitnessquest.com/images/edge491OM.pdf
Page 4 says how to order parts. No belfs but they do have a v-belt. Manuals - gotta read 'em.
Aug 26, 2011 | Cycling
My "Edge 491r" recumbant bike
Same as above, have an Edge 491 with E1 and need to fix it
Jan 04, 2011 | Fitness Quest Eclipse 1100 Hr/A Elliptical
I have an Edge 491 Exercise bike and the control
Take a look at the battery compartment under the panel (left looking up). I had a similar problem and had just fixed it. Hopefully you can get the same results.
If the strip of metal with the spring is corroded, take the batteries out, and carefully remove the metal strip. I used metal duct tape and wrapped the piece of metal with the tape. Carefully put a slight bend in the middle of the strip and reinsert the strip. If the batteries do not connect up, bend the piece a bit more or add more of the metal duct tape. After doing this, the panel came back to life. If this is not your problem, then my apologies. If it is, then good luck.
Feb 02, 2010 | Fitness Quest Cycling
Edge 491 exercise bike monitor panel dead
Nancy
Jul 12, 2009 | Fitness Quest Eclipse 1100 Hr/A Elliptical
Palm tungsten e2 will not turn on, replaced batttery,
Plug you E2 into your PC for 8 hours to slow charge. Press reset button on back and later in life your E2 will come on by itself.
Dec 23, 2008 | Palm Tungsten E2 Handheld
Pops up a fatal error when i put on my tungsten E2
I have yet to find anyone that knows any codes for E2. Press the power and soft reset at the same time.
Dec 15, 2008 | Palm Tungsten E2 Handheld
Fitness Quest Eclipse 1100 Hr/A Elliptical Logo
105 people viewed this question
Top Fitness Quest Sport & Outdoor - Others Experts
Joseph Mueller
Joseph Mueller
Dave Callender
Dave Callender
Rigger
Are you a Fitness Quest Sport and Outdoor - Other Expert? Answer questions, earn points and help others
