Question about Grohe Plumbing
Kitchen Faucet Grohe Model 20.440
Product manual
arealplumber
  • 33 Answers
SOURCE: DELTA MODEL 470-WH LOW WATER FLOW AT KITCHEN FAUCET
This could be a couple of things.
  1. First remove the aerator from the wand and make sure you have plenty of flow with it off.
  2. If there is flow clean or replace the aerator.
  3. Remove the wand and look between the hose connection and the wand there should be a screen between them. Remove the screen and clean or replace.
  4. Make sure hose is kinking under the sink.
If you need a diagram of the faucet with part numbers here is the link:
Delta 470
Hope this helps!
Posted on Dec 05, 2008
  • 35 Answers
SOURCE: Grohe ladylux plus kitchen faucet leaks from
Yes,it sounds like you have to replace the hose.Follow the braided hose under your sink until you come across a yellow and black fitting . it is comparable to an air hose fitting quick disconnection. once that is pulled from the sink port,unscrew the spray head and pull the ose through the faucet body from above the sink
Posted on Feb 23, 2010
  • 349 Answers
SOURCE: Kitchen Faucet is loose on granite counter
http://www.needplumbingsupplies.com/Grohe-Kitchen-Sink-Faucets.asp?id=13758
This link has a spec sheet that will give you an view of under neath counter top. There should be a nut that you can tighten it up with.
Posted on May 24, 2010
  • 111 Answers
SOURCE: Hi my Grohe kitchen sink
from underneath,may be really tricky to get a grip on you might need a basin wrench.
Posted on Jan 29, 2011
packrat1948
  • 528 Answers
SOURCE: we have a Grohe Lady
Take it back apart and check the placement of all the o-rings and or seals.
The low water pressure may be no more then the aerator being dirty where the water comes out of the spout.
Posted on Feb 05, 2011
I have a single handle Grohe kitchen faucet with very low water pressure. All other areas of the home are fine.
Try this site
http://www.doityourself.com/forum/plumbing-piping/310875-low-water-pressure-new-kitchen-faucet.html#b
Also alot of videos on specific Grohe faucets on youtube. Not sure your model. Take a look.
Hope this helps some.
Jan 26, 2017 | Grohe Plumbing
How do you remove the supply line from the spray head?
The hose should simply unscrew from the back of the head.
Here is the page on the Grohe site:
http://www.grohe.com/us/15219/kitchen/kitchen-faucets/ladylux/product-details/?product=33755-G077&color=SDE&material=33755SD0&~[ajax]=33063
Jun 03, 2014 | Grohe Plumbing
Loose Grohe kitchen faucet
there are mounting plates underneath the counter which fasten the faucet to the counter.This unit will need a small allen wrench if memory serves me correctly...keep in mind that all moen faucets are lifetime guranteed and alot of folks do not take advantage of this amazing warranty which makes these the most desirable faucet on the market.however the need to tighten this faucet prob isnt a warranty replacement procedure but can be determined once mounting items and faucet is inspected...good luck
Jun 28, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Grohe kitchen faucet burst supply line
With my past experiance with any Grohe product,you will experiance a problem.I have been doing plumbing service work for 20 yrs. and every time I encounter this product,there is always a major problem.I don't know what the big deal is about this product,it cost too much and parts are hard to come by,you must order most of the time.then wait 3 to 4 weeks.hope it's the right part!
Jun 19, 2009 | Plumbing
Grohe pull out kitchen faucet the inner tube ripped
go to the store you bought it and see if they carry parts. if not , try the internet under grohe.com.
Jun 11, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
My Grohe Kitchen Fawcett lost water pressure, is their a manual online available?
make sure you check the strainer that unscrews from the spout. SOmetimes these clog from sediment. ALso check the supply valves to the faucet (sometimes there is sediment in these--opening and closing helps) you may have to remove the cartridge(s) depending on you model number. You can probably download the manual at homeappliance.manualsonline.com
Jan 04, 2009 | Grohe Classic Kitchen/Bar Faucet ...
Plumbing Logo
56 people viewed this question
Top Grohe Plumbing Experts
Donni Steen
john h
Mike
Are you a Grohe Plumbing Expert? Answer questions, earn points and help others
