Question about Toshiba E-STUDIO 850 Copier
FINISHER ERROR EA10 - Toshiba E-STUDIO 850 Copier
I have a ir5070 that is getting a E000584 AND E00014. Trying to find a list of error code descriptions but now luck. Anyone know what they mean or why I am getting these?
the error 14 is fixing unit error a dn 584 is finisher shutter error
first disconnect the finisher and solve the fixing error 14
reset the error
copier>function>clear>err>ok and reboot
once the unit is ready to copy run 10 copies to confirm
then connect the finisher and solve the next error 584
Oct 25, 2013 | Canon Office Equipment & Supplies
How to fix the error code for Ricoh 1232c sc517 and how to clear it
there's no error code like that
http://www.unitedtechsonline.citymax.com/page/page/4653767.htm
101: EXPOSURE LAMP PROBLEM
120:SCANNER HOME PROBLEM
121:SCANNER HOME
124:SCANNER MOTOR PROBLEM
125:SCANNER MOTOR PROBLEM
126:SCANNER MOTOR PROBLEM
127:SCANNER MOTOR PROBLEM
129:SCANNER MOTOR PROBLEM
130:SICU / SBU PROBLEMS
300:CHARGE CORONA PROBLEMS
301:CHARGE CORONA PROBLEM
303:CHARGE GRID PROBLEM
304:CHARGE GRID PROBLEM
305:CHARGER UNIT WIRE CLEANER PROBLEM
306:CHARGER UNIT WIRE CLEANER PROBLEM
310-316:DRUM POTENTIAL SENSOR ERROR ISSUES
321:LASER UNIT WRITE PROBLEM
322:LASER UNIT 1 SYNCH. PROBLEM
323:LASER UNIT DRIVE PROBLEM
335-338:POLYGON MOTOR PROBLEMS
340-342:TONER DENSITY SENSOR ERROR ISSUES
345:DEVELOPER BIAS PROBLEM
350-355:IMAGE DENSITY SENSOR PROBLEMS
360:HARD DISK 1 PROBLEM
361:HARD DISK 2 PROBLEM
362:HARD DISK 1 PROBLEM
363:HARD DISK 2 PROBLEM
364:HARD DISK 1 PROBLEM
365:HARD DISK 2 PROBLEM
366:HARD DISK 1 PROBLEM
367:HARD DISK 2 PROBLEM
370-375:IMAGE COMPRESSION ERROR
376-377: SICU,IMAGE COMPRESSION ERROR
380-383:IMAGE DATA TRANSFER PROBLEM(SICU, SBU,PRINT CONTROLLER)
384-385:IMAGE DATA TRANSFER PROBLEM WHEN TANDEM IS USED(SBU,INTERFACE
BOARD,SICU,PRINT CONTROLLER)
390:TANDEM IMAGE DATA TRANSFER ERROR(NOISE,SICU,INTERFACE BOARD)
391-392:IMAGE STORAGE ADDRESS ERROR(SICU391-01)
395:CD-R/RW ERROR, INTERFACE BOARD ISSUES
397:CD ACCESS ERROR
398:CD-R/RW DATA ERROR
400:TRANSFER BIAS ROLLER ISSUES
401:TRANSFER ROLLER
430:QUENCHING LAMP ERROR
440:DRUM MOTOR LOCKED
441:DEVELOPER MOTOT LOCKED
491:LASER COOLING FAN LOCKED
495:TONER BOTTLE PROBLEM
496:TONER COLLECTOR BOTTLE PROBLEM
501:LIFT PROBLEMS FOR TRAY 1
502:LIFT PROBLEMS FOR TRAY 2
503:LIFT PROBLEMS FOR TRAY 3
504:LCT 1ST TRAY PICKUP OR LIFT PROBLEM
505:LCT 2ND TRAY PICKUP OR LIFT PROBLEM
506:LCT 3RD TRAY PICKUP OR LIFT PROBLEM
510:PAPER FEED MOTOR PROBLEMS
511:LCT MOTOR PROBLEM
515:TANDEM REAR FENCE MOTOR PROBLEM
520-521:DUPLEX JUGGER MOTOR PROBLEMS
531:FUSING DUPLEX MOTOR LOCKED
532:RELAY MOTOR LOCK
541:OPEN FUSER THERMISTOR
542:LOW FUSER TEMPERATURE
543:HIGH FUSER TEMPERATURE
544:HIGH FUSER TEMPERATURE
545:HIGH FUSER TEMPERATURE
546:LOW FUSER TEMPERATURE
547:ZERO CROSS PROBLEM
550:WEB EXPIRED
591:TONER SUPPLY MOTOR PROBLEMS
592:TONER BANK MOTOR PROBLEMS
601:SBICU TO SBU COMMUNICATION PROBLEMS
602:SBICU TO HARD DISK DRIVE BOARD COMMUNICATION PROBLEMS
620-622:SBICU TO ADF COMMUNICATION PROBLEMS
625-626:BCU TO FINISHER COMMUNICATION PROBLEMS
630:LINE ADOPTER TO CSS CENTER COMMUNICATION PROBLEMS
640-645:BCH TO SICU COMMUNICATION PROBLEMS
646:SICU PROBLEM
650-653:COUNTER ERROR JAPAN
701:ADF P/U ROLLER PROBLEMS
702:ADF FEED MOTOR PROBLEM
703:ADF TRANSPORT BELT MOTOR PROBLEM
704:ADF EXIT MOTOR PROBLEM
705:ADF ORIGINAL TABLE LIFT ISSUES
720:FINISHER LOWER TRANSPORT MOTOR ISSUES
722:FINISHER JOGGER MOTOR ISSUES
724:FINISHER STAPLER HAMMER PROBLEMS
725:FINISHER STACK EXIT MOTOR PROBLEMS
726:FINISHER SHIFT MOTOR PROBLEMS
727:FINISHER STAPLER ROTATION PROBLEMS
729:FINISHER PUNCH MOTOR PROBLEMS
730:FINISHER STAPLER MOTOR PROBLEMS
735:FINISHER PAPER STACK PLATE MOTOR PROBLEMS
736:FINISHER EXIT GUIDE MOTOR PROBLEMS
737:FINISHER FULL STAPLER HOPPER
738:FINISHER SHIFT TRAY LIFT MOTOR PROBLEMS
739:FINISHER FOLDER PLATE MOTOR ERROR
740:FINISHER FRONT SADDLE STITCH STAPLER MOTOR PROBLEMS
741:FINISHER REAR SADDLE STITCH STAPLER MOTOR PROBLEMS
742:FINISHER JOGGER SIDE FENCE MOTOR
750:COVER INTERPOSER BOTTOM PLATE MOTOR PROBLEMS
800:VIDEO OUT TRANSFER,CONTROLLER BOARD
804:VIDEO OUT TRANSFER,CONTROLLER BOARD
818:OPTIONAL BOARD,CONTROLLER BOARD, SYSTEM PROGRAM
819:BAD SOFTWARE
820:CONTROLLER BOARD OR SOFTWARE
821:CONTROLLER BOARD
822:HDD PROBLEM
823:NIB, CONTROLLER BOARD
824:CONTROLLER BOARD, NVRAM
825:NVRAM ERROR
826:NVRAM
827:CONTROLLER BOARD, RAM
828:SOFTWARE,ROM,CONTROLLER
829:RAM, CONTROLLER
835:CONTROLLER,CENTRONIC LOOPBACK CONNECTOR
836-837:FONT DEVICE
838:CONTROLLER BOARD
850:IP ADDRESS,CONTROLLER BOARD,NIB
851:1394 I/F CONNECTIONB,I/F INTERFACE,CONTROLLER BOARD
860-861:HDD
862:HDD BAD SECTORS
863:HDD
864:DATA TRANSFER ISSUES
865:HDD
900:NVRAM PROBLEM.ELECTRICAL COPY COUNTER
901:MECHANICAL COUNTER ISSUES
921:IMB, BICU FAILING
922:IMB, BICU FAILING
924:DRAM,BICU,IMB FAILING
925:BICU, IMB FAILING
926:BICU, IMB FAILING
951:F-GATE SIGNAL ERROR PROBLEMS
953:SCANNER IMAGE SETTING ERROR ISSUES
954:PRINTER IMAGE SETTING ERROR ISSUES
955:MEMORY SETTING ERROR ISSUES
964:PRINTER READY ERROR ISSUES
966:POLYGON MOTOR PROBLEM
970:SCANNER READY ERROR
980:HDD ACCESS ERROR
981:BICU, NVRAM
982:HDD CONSTRUCTION ERROR
984-987:HDD DATA TRANSFER ERROR
990:SOFTWARE PERFORMANCE ERROR
991:REBOOT SOFTWARE ERROR
997-998:DIMM, RAM ERROR
999:PROGRAM DOWNLOAD ERRORS
Oct 29, 2008 | Ricoh Office Equipment & Supplies
Scan error
The error code refers to the hard drive for the finisher. If you want to avoid replacing the hard drive, you can just take the finisher off. The hard drive is used to store print jobs when making sets of copies with the finisher... Good Luck
Jun 06, 2013 | Gestetner Office Equipment & Supplies
I purchased car Ford Fiesta EA10 ZZM in December from Motorpoint and had a 12.500 mile service done on 30th Dec 2010. This included an oil change. Recently an amber oil change service light has come in...
No, they you just need lights reset with an OBII scanner. (They forgot to reset your service interval) Any good parts store like Advance, Autozone, etc can do this for you too and FREE
Mar 05, 2011 | Ford Fiesta Cars & Trucks
How do you convert 36.07 celsius to Farenheit?
Multiply by 1.8 then add 32.
36.07 degrees C is 96.926 degrees F.
Sep 17, 2010 | EA Sports Extech EA10 Easyview 200 Degrees...
Minolta Bizhub C253 - C-11C3 finisher error
The 11XX code refer to the printer and hard .To reset push the reset button or open the front door and close.
Dec 11, 2009 | Konica Minolta Office Equipment & Supplies
Printer displays c-0096 on display
C0096 Image Transfer Belt pressure/retraction failure
please have this services as this is a part of the printer that is not consumable.
Code Item
C0000 Main Motor’s failure to turn
C0001 Main Motor turning at abnormal timing
C0016 Bk PC Motor’s failure to turn
C0017 Bk PC Motor’s turning at abnormal timing
C0018 Color PC Drum Motor’s failure to turn
C0019 Color PC Drum Motor’s turning at abnormal timing
C001A Color Developing Motor’s failure to turn
C00l B Color Developing Motor’s turning at abnormal timing
C0040 Suction Fan Motor’s failure to turn
C0046 Fusing Cooling Fan Motor/1 failure to turn
C0048 Fusing Cooling Fan Motor/1 or Fusing Cooling Fan Motor/2 failure to turn
C004C Ozone Ventilation Fan Motor’s failure to turn
C004D Toner Suction Fan Motor’s failure to turn
C004E Power Supply Cooling Fan Motor’s failure to turn
C004F Cooling Fan Motor 2’s failure to turn
C0060 Fusing Drive Motor's failure to turn
C0061 Fusing Drive Motor turning at abnormal timing
C0094 2nd Image Transfer Roller pres-sure/retraction failure
C0098 Fusing Pressure Roller pressure/retraction failure
C0200 Cyan PC Drum Charge Corona malfunction
C0202 Magenta PC Drum Charge Corona malfunction
C0204 Yellow PC Drum Charge Corona malfunction
C0206 Black PC Drum Charge Corona malfunction
C0208 PC Drum Charge Corona malfunction
C0400 Exposure Lamp’s failure to turn ON
C0410 Exposure Lamp turning ON at abnormal timing
C0500 Heating Roller warm-up failure
C0501 Fusing Pressure Roller warm-up failure
C0510 Heating Roller abnormally low temperature
C051 1 Fusing Pressure Roller abnormally low temperature
C0520 Heating Roller abnormally high temperature
C0521 Fusing Pressure Roller abnormally high temperature
C0650 Scanner Home Sensor malfunction
C0660 Scanner overrun failure
C0900 Tray3 Elevator failure
C0910 Tray2 Elevator failure
C0950 Tray4 Elevator failure
C0960 Bypass lifting motion failure
C0990 LCT Elevator Motor malfunction(Elevator malfunction)
C0991 LCT ascent motion failure(soft limit error)
C0996 LCT Shift Motor malfunction
C0997 LCT shifting failure
C0998 LCT ejection failure
C099C LCT Shift Gate malfunction
C099D LCT communications error
C0805 Finishing option Paddle Motor malfunction
C0B20 Finishing option Stapler Unit CDdrive failure
C0B2S Finishing option Stapler Unit SlideMotor malfunction
C0830 Finishing option Aligning Bar moving mechanism malfunction
C0B39 Finishing option Front AligningMotor malfunction
C0B3A Finishing option Rear AligningMotor malfunction
C0B48 Finishing option Exit Roller pressure/retraction failure
C0B4A Finishing option Storage Roller pressure/retraction failure
C0B4C Finishing option Exit Motor malfunction
C0B50 Finishing option stapling mechanism malfunction 1
C0B55 Finishing option Staple/Folding Motor malfunction
C0B75 Finishing option Punch Cam Motor drive failure
C0B76 Finishing option Punch Unit Board malfunction
C0B77 Finishing option Punch Side Registration Motor malfunction
C0B78 Finishing option Punch Motor malfunction
C0B79 Finishing option Punch Sensor malfunction
C0B80 Finishing option Shift Motor mechanism malfunction
C0BA0 Finishing option Elevator drive malfunction
C0F30 Abnormally low toner density detected Cyan ATDC Sensor
C0F31 Abnormally high toner density detected Cyan ATDC Sensor
C0F32 Abnormally low toner density detected Magenta ATDC Sensor
C0F33 Abnormally high toner density detected Magenta ATDC Sensor
C0F34 Abnormally low toner density detected Yellow ATDC Sensor
C0F35 Abnormally high toner density detected Yellow ATDC Sensor
C0F36 Abnormally low toner density detected Black ATDC Sensor
C0F37 Abnormally high toner density detected Black ATDC Sensor
C0F3A Cyan ATDC Sensor adjustment failure
C0F3B Magenta ATDC Sensor adjustment failure
C0F3C Yellow ATDC Sensor adjustment failure
C0F3D Black ATDC Sensor adjustment failure
C1200 Standard controller configuration failure
Cl 203 File Memory mounting error
C1204 Memory capacity discrepancy
Cl 220 Image Input Time Out
C1229 Image Output Time Out
C1240 JBIG0 Error
Cl 241 JBIG1 Error
C1242 JBIG2 Error
C1243 JBIG3 Error
C1250 Compressor 0 command buffer stop failure
C1251 Compressor 1 command buffer stop failure
C1252 Compressor 2 command buffer stop failure
C1253 Compressor 3 command buffer stop failure
Cl 261 Compression hardware timeout
C1265 Extraction hardware timeout
C1279 PCI-SDRAM DMA operation failure
C1290 Compression/extraction timeout detection
C12B1 Image processing ASIC failure 1
C12B2 Image processing ASIC failure 2
C12B3 Image processing ASIC failure 3
C12B4 Image processing ASIC failure 4
Cl 2C0 Hard disk recognition error
C12C1 Hard Disk Error 1
C12C2 Hard Disk Error 2
C12C3 Hard Disk Error 3
C12C4 Hard Disk Error 4
C12C5 Hard Disk ErrorS
C12C6 Hard Disk Error 6
C12C7 Hard Disk Error 7
C12C8 Hard Disk Error 8
C12C9 Hard Disk Error 9
C12CA Hard Disk Error A
C12CB Hard disk data transfer error
C12CC Hard disk unformat
C12CF Hard disk specifications error
C12D0 Controller hardware error
C13C8 New Transfer Cleaner Unit reset-ting failure
C13CA New Fusing Unit resetting failure
C13D1 Cyan Imaging Unit EEPROM access error
C1302 Magenta Imaging Unit EEPROM access error
C13D3 Yellow Imaging Unit EEPROM access error
C13D4 Black Imaging Unit EEPROM access error
C13D5 Cyan LPH correction data down-load failure
C13D6 Magenta LPH correction data download failure
C13D7 Yellow LPH correction data download failure
C13D8 Black LPH correction data download failure
C1800 Controller start failure
C3310 CCD clamp/gain adjustment failure
C3331 MSC undefined malfunction occurring
C3332 Scanner Section undefined malfunction
C3333 Engine Section undefined malfunction
C3E00;C3E01;C3E02 NVRAM initialization failure
C3F00 Vendor connection failure
C3FFC ROM contents error upon startup(LPH)
C3FFD ROM contents error upon startup(Scanner)
C3FFE ROM contents error upon startup(PRT)
C3FFF ROM contents error upon startup(MSC)
Aug 14, 2009 | Office Equipment & Supplies
Malfunction detected C-0096
Code Item
C1240 JBIG0 Error
Cl 241 JBIG1 Error
C1242 JBIG2 Error
C1243 JBIG3 Error
Feb 10, 2009 | Kyocera Office Equipment & Supplies
Intermittent error code E713-0004 Already replaced every board in copier and finiser (R-1). Also replaced the wire harness from copier to finisher, even tried another R-1 finisher, still throws code.
E713-0004 -05 Title Finisher IPC communication error (checksum error)
Remedy 1. Check the cable connection of the Finisher.
DC Controller side: J462, Finisher Lattice side: J9043
2. Replace the Finisher Controller PCB.
Description Communication between the host machine and the Finisher was lost
Dec 18, 2008 | Canon Office Equipment & Supplies
64 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
