Question about Karcher Garden
Open karcher k4 600 - Karcher Garden
Karcher Leaking from Back or inside...Help please
Karcher pressure washers are very sensitive to over-winter freezing. The plastic parts break, and you have to replace all of the leaking parts.
You may be missing a locking tab, without seeing the thing apart next to the exploded parts view, it's really hard to tell. Search google for "karcher parts", and put in your model number...
Aug 03, 2015 | Karcher Garden
Water coming out of detergent pipe from top for karcher 3030 b jet wash
DISCONNECT HYDRO OR WITH ENGINE NOT RUNNING DISCONNECT SPARK PLUG THEN RE-LEAVE WATER PRESSURE BEFORE SERVICING the detergent pipe plugs into a pipe on the pump, under which is a spring and ball bearing (stuck open, debris) WEAR YOUR SAFETY GLASSES
Apr 01, 2014 | Karcher Garden
Karcher vaporapid 1105 manual
there should be a labeled fill line on the clean water resavore
Mar 26, 2014 | Karcher Vacuums
Karcher sc 952 having problems with no steam coming out.
this machine uses an electrical solenoid to open the flow of steam from the heater..... the switch is in the hand trigger and the valve on the machine.... one of these is at fault
If you have a Karcher then you should always post your machines barcode.
The karcher barcode is on a silver sticker and is usually 15 digits long. Example 156987400000123 is actually model 1.569-874.0 and serial number 00123....
Aug 04, 2013 | Karcher DE4002 Steam Vacuum
Is there a reset button on the karcher de 4002
open the lid and you will fine a red button with a clear rubber cover
press that button. When you have to reset, it is telling you that you need to descale the unit
Jun 15, 2011 | Karcher DE4002 Steam Vacuum
My Karcher is leaking from the motor I think. Is it fixable? It's a KB 5050
My Karcher K 3.99 is leaking and dropped pressure. is it fixable (not filter)
Apr 04, 2010 | Karcher K DS 5500 Vacuum
Karcher 2400 Psi Pressure Washer No gain of pressure
remove the hose from the machine. Check that water is flowing. and there is no corrosion reducing the opening. If that is OK then it is the internal seals and pressure vallve on the pressure unit Cost to have it fixed by Karcher is $200
Thanks for using FIXYA
Sep 26, 2009 | Karcher 2500 PSI Pressure Washer
Karcher K 3.68M Electric Pressure Washer. Wand trigger Locks Up.
Sounds like the pressure valve is broken thats why you cant depress the trigger , the valve is on the pump , i would suggest taking it to a repair shop as they are fiddly things to fix
Jun 04, 2009 | Karcher PSI Electric Pressure Washer
Karcher prssure washer motor will not start
try going to www.karcher.com
then click on europe
the international,
then service and will then see spare parts, enter k620
tick the button for you are a engineer and you are on your machine
download.
micro switch might be at fault.
Mar 25, 2009 | Karcher Garden
Karcher 395
I found that by putting the housing in the freezer for a couple of hours, i was able to tap the metal and plastic body apart and install the new inlet elbow.
Aug 17, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
47 people viewed this question
Top Karcher Garden Experts
John Trevino
Are you a Karcher Garden Expert? Answer questions, earn points and help others
