Question about Garden
Karcher kb9020 wont switch on - Garden
Why my karcher hd650sx wont turn on
If the on/off switch goes bad ...............................
Aug 19, 2016 | Karcher Garden
What to try when karcher pressure washer wont start//?
unit may have either a bad power switch or stuck flow switch normally located at the inlet of pump inside where you hook up the garden hose
Aug 07, 2014 | Karcher Garden
Karcher wv50 spare on off switch
If you contact one of the Karcher Centers ( details are on Karcher.co.uk website) they may be able to help.
regards Gary
Aug 02, 2014 | Karcher WV50 Window Vacuum
Why wont my karcher window vac switch on even after a full charge any ideas ?
Take it apart and see what is stopping it (the motor) from turning .
Jun 23, 2014 | Karcher WV50 Window Vacuum
I have a karcher kb9020 which pulses when idol any ideas why
The "manifold" as talked about above is also called the "Control head".
For a picture of the very small cracks in the control head see here: Karcher Control Head cracks
The video linked to below talks about the cracks in the control head at 7:00 through to 7:08. They guy incorrectly calls it the cylinder head in the video. How to FIX Karcher pressure washer
If Karcher made the control head from an aluminium casting, or used a metal insert near the point of failure, their product range would be a LOT more reliable.
May 30, 2014 | Karcher PSI Electric Pressure Washer
My karcher pressure did turn on but stopped working altogether now wont turn on
Make sure that your circuit breaker did not go off and you have power..
Turn on the water after connecting the hoses. Then connect an ohm meter to the hot and ground legs of the male power plug. Push the on/off button to on and then pull the trigger. When you do that your ohm meter should indicate the resistance of the motor windings. If the resistance still stays at zero, then 1 - your motor is burnt out, 2 - the on/off switch is not working, 3 - the water pressure switch is electrically open. Check all three for proper operation and replace as needed.
Apr 01, 2014 | Karcher Garden
Karcher wont start
there is a pressure switch in those machines that goes bad. it is a common problem. if its under warranty let them work on it. if not take it apart and you will see the problem. it is replaceable and you can do it.
Mar 28, 2014 | Garden
How do you reset a karcher pressure washer
The Knob is broken off of the Plastic Shaft..to the switch assembly.
A new switch assembly is available direct from Karcher.
May 24, 2010 | Karcher K2.26 Electric Power Washer
Australian Karcher 2.91 intermitant start
Under the top cover there is a micro switch that sometimes dislodges
This switch is for auto cut off when you release the trigger
Jul 27, 2009 | Karcher K2.26 Electric Power Washer
Garden Logo
93 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
