Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
LSQ9549PG2 Washer does not agitate
I thought the problem was in the load level switch.Replaced.Problem persists.Replaced Timer control. Problem persists.
    President:
  • 3,113 Answers
What is wrong with it?
Posted on Jun 18, 2009
Unit acts like it has received water then continues to cycle as if it hasn't, no water is pumped???
Symptom Check
Click on underlined items for further information Washer does not work and makes no noise Washer does not work but it does make noise No water is entering the wash tub
- or no hot water
- or no cold water The water fills the wash tub too slowly The tub does not fill with enough water
  • Test the water level switch
  • Check that the drain hose is positioned roughly as high as the top of the inner tub
The water overflows the wash tub Water drains out during the wash or rinse cycle
  • Check the drain control lever
  • Test the drain control coils
  • Check the cam bar
  • Test the timer control
Wrong temperature of water is used
  • Water supply hoses may be reversed
  • Hot or cold water supply valve may be turned off
  • Water supply hose may be kinked
  • Check water inlet valve
Water drains out while it is filling
  • Check the drain hose, it should be at least as high as the top of the wash tub, about 38 inches.
  • The drain hose must sit loosely in the house drain. Do not seal the air gap around the drain hose or a siphon will occur.
  • Check the cam bar
Water drips into the wash tub when the washer is off Water does not drain out of the wash tub Water is leaking onto the ground
  • Inspect the water supply connections
  • Inspect the drain hose
  • Inspect the water pump
  • Inspect outer tub for cracks or corrosion
  • Inspect the tub seal
  • Inspect the tub bearing
Agitator does not move Agitator movement is weak or moves in only one direction
  • Inspect the agitator
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
  • Inspect the pump coupling
Drum does not spin
  • Test the lid switch
  • Test the centrifugal switch
  • Test the motor
Clothes are too wet after spin cycle This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
Spin:
  • Test the motor
Cycle does not advance
  • If the washing machine fills with water and begins agitating, but the timer does not advance, the timer probably needs to be replaced
  • If the timer does not advance while the washer is in a spin cycle, the timer probably needs to be replaced
  • If the timer does not advance during the rinse cycle, check whether water has filled the tub, if not, it is likely cold water related. Check the cold water supply valve, check the supply hose for kinks, check the filter screen and check the water inlet valve
Burning or electrical smell
  • Unplug the washer
  • Locate the source of the odor then read the instructions in the related section
Foul or stale odor coming from washer or clothes
  • Check that the drain line is clear
  • Check the drain hose for kinks or blockages
  • Check pump for blockages
  • Check for build up of soap in the outer tub
  • Check for article of clothing stuck in the outer tub
Noisy or vibrates too much
  • General tips
  • Balance the load
  • Level the machine
  • Inspect the water pump for a blockage
  • Inspect the coupling
  • Inspect the transmission
  • Adjust the drive belt tension
  • Check the motor bearings
  • Check the drum brakes
Goes out of balance too often Clothing is damaged
  • Inspect agitator for cracks or rough spots
  • Inspect for rust spots
Jul 11, 2015 | Washing Machines
11 year old Kenmore washer fills then stops.
in the machine under the front control panel will be a module that controls the wash agitation. Have it checked out as they fail . There is no connection between the timer and this unit as it comes in to play when the water reaches a set level. The timer just keeps working through the cycles believing the washer is agitating.
Jun 26, 2013 | Kenmore 24032\24036 Top Load Washer
Washer won't change gears from water fill to agitate
Hi and welcome to FidYa, I am Kelly,
If it does not agitate or spin suspect the lid switch. Listen for a microswitch click as the lid just opens or closes. No Click = bad lid switch.
If it spins then the lid switch is fine and there is a problem with the water level control pressure switch or possibly the control.
Since you did not include a model number this is my best guess for a 3.2 cu ft machine
MVWC300VW0
This lid switch is item 6 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5519632
The water level control switch is item 4 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5519632&diagram_id=28626536#d28626536
The timer item 7 of the above link can also cause this symptom. You must elimiate the water level control as a possible cause first. There is a FOLDED wiring diagram in the literature packet insde the top panel 3 x 5 envelope you can use to jumper the wires on the water level control switch. If the motor agitates then the water level switch is the problem. If it does not agitate it can be the timer or the motor. (More troubleshooting required via the wiring diagrams following power through the circuit to the motor.)
At this time I think you may just have a water level control switch problem. If you do end up replacing it... the wash tub must be empty or it will overflow when testing.
Thanks for choosing FixYa,
Kelly
Sep 15, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
Washer will not spin or agitate Washer will fil and pump water out motor will not come on Have replaced the motor and the lid switch After replacing the motor the washer worked ok for about 4 or 5...
This is sounding like either a timer or a water level switch problem. I would elimnate the water level switch first. Here is why..... You had to tip the unit to change the motor. Tipping the unit would ensure that the small tube that runs from the bottom (side) of the wash tub to the water level control pressure switch cavitated. Once this is clear the water level control was for a while able to sense proper water levels and the diaphragm inside the pressure switch cycled normally. If the sens line had a pin hole in it or the water level control pressure switch contacts have a problem it will present the symptom you currently have.
I cheat.... I hook up an equal sized tube to the water level pressure switch and add pressure and release pressure orally to force the pressure switch to work. (Automotive vacuum line works like a charm!) If it works by physically forcing it to work then the timer is fine. The Pressure switch is probably ok also. The sense tube running from the presure switch to the tub would be the problem. With all water removed... (drain hose lowered too to empty the machine) tip the unit again. Then see if it will fill and agitate on a small load. Also check to see if it spins. IF it agitates and spins... the sense line if most likely the problem. (pin hole chaffed etc)
There is still a remote possibility of the Timer causing the problem OR the contacts inside the water level pressure switch as the problem. If you can find the tech data sheet inside the console there should be a wiring diagram. Check the water level control for power in and out both with water level reached and empty. If the contacts are working on the water level control pressure switch... your probably looking at the timer as the problem.
Kelly
Aug 31, 2011 | GE Profile WPRE6150KWT Colossal Capacity...
Whirlpool Washer model # LSN1000KQ0 overfilling
did you plug the hose back into the water level switch, double check to see if it is plugged, if it is your water level switch might be defective. trouble shoot by taking the front panel off... turn on the washer by using the timer, set water level to small...on the bottom of the tub housing there should be a nipple where the clear hose connects onto.....follow the clear hose from the switch down to the bottom of the tub.........disconnect the clear hose on the bottom of the tub.....plugg the nipple with your finger.........gently blow into the hose with your mouth.......but make sure the water level in the tub is at least at half way full...and the washer is on and filling up with water ...after you blow into the hose the washer should agitate.......if it does agitate your water level switch is defective...connect hose back........get your model number and source for the switch.........
Apr 10, 2010 | Whirlpool Washing Machines
My top loading whirlpool washer stopped after filling. Cycle dial does not engage any agitating, spinning,rinsing, nor draining activity. The dial does not advance with time, neither. Checked the outlet...
You could have a bad lid switch or a bad water level switch or a bad timer. In that order.
Open the control panel to access the components listed.
Make a small wire jumper and jump out the lid switch. Turn the timer on and see if it works. If yes, replace the lid switch.
If no, check power from the water level switch to the timer.
Terminals V to T should read closed on a meter set for ohms.
If the water level switch is closed the timer is bad.
Apr 22, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
GE SpaceMaker washing machine does not stop filling.
try replacing your water selenoid coming in. remember it isnt a mechanical timer it is a computerized timer, so if the selenoid isnt the problem, it might be the computerized timer. computers are very finicky, pain in the a- -!
Mar 23, 2009 | GE WSM2480DWW Unitized Spacemaker Washer...
Frigidaire front load washing machine won't stop filling
it sounds like your water valve is bad or you pressure switch is bad or hose from pressure switch to tub is cloged
Feb 07, 2008 | Frigidaire ATF6000ES Front Load Washer
Agitator not spinning
could'be water level switch or timer control. another posibility is corrosion on the motor wiring connector
Jun 22, 2007 | Kenmore 24032\24036 Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
93 people viewed this question
Dan Webster
Dan Webster
Sal De
