Question about Kodak ESP C310 AllInOne InkJet Printer
Printer does not turn on
The green light is on but won't turn on.
MX310 green light flashing and beeping. Won't turn off or reset
You can restart splooler....
--Right click on my computer
--click on manage (a new window open)
--to the left look for Services and application and double click
--this will drop down the some task.
--click on services
--then to your right look for the print splooler
--right click and click on restart.
Mar 04, 2013 | Canon PIXMA MX310 All-In-One Printer
Alps MD1000 printer won't do anything.
Do you get the green ready light when you first turn on the printer?
Nov 05, 2012 | Alps MD 1000 Thermal Printer
Amber and 2 green lights on solid and won't pick up paper
To clear the error, turn the printer off and then on again. If the problem
persists, leave the printer off for 15 minutes to reset the formatter. If
the problem continues, contact HP Service. See HP Customer Care
Oct 26, 2011 | HP LaserJet 2200D Printer
My printer won't turn on. I have tried turning everything off and back on but it still won't turn on.
There is only one way to find out if it is an issue with the printer or the Power cord or Power Adapter.
Normally every HP printer has 2 parts. One cord connects the Printer to an Adapter. the Adapter cord then connects to the Wall outlet.
Now that you have connected the printer to working outlet, Check after 10-15 mins if the Adapter ( black box ) is warm or cold. If the Adapter is warm and the green LED light on adapter is glowing, then it could an issue with the Cord or the Printer.
Try with another Adapter or power cord to diagnose.
For Other brand printers, there should be a power adapter ( black box ) and it should be warm when connected to wall outlet, if it is not warm then it is defective power adapter that you need to replaced. Else it is a problem with printer mechanism.
Regards,
Shawn
May 07, 2011 | Office Equipment & Supplies
My Canon pixma ip 4000 won´t print. The light at the turn on button blinks five times orange and then comes one green blink. I have tried to clean the print head but that didn´t change anything....
this indicates a the print head is not installed correctly or is faulty.
if the green and orange is alternating 5 times then it is caused by the sheet feeder.
Dec 08, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Canon ip4300 service error b200 green and orange light keep flashing ink toner won`t move
Try this:
Pull the power cord out of the back of the printer.
Then move the printhead to the center and pull out the ink and the printhead. Clean the printhead and examine the bottom for burned areas.
With the printhead still out, close the cover and plug the power in and turn the power on. If your printer isn't damaged, it should go through all diagnostics and give you a solic green light. This means you probably need a new printhead.
Apr 17, 2009 | Office Equipment & Supplies
Printer won,t work
I can't get my 1210 hp printer to turn on
May 01, 2008 | HP PSC 1210 All-In-One InkJet Printer
Kodak ESP C310 AllInOne InkJet Printer Logo
26 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
