Question about Zenith IQC60H94W 60" Rear Projection Television
My Zenith tv plays well, then the picture starts jumping and then picture goes off. Repair man has had tv for almost 2 months and can't seem to find out what is wrong.
  • mamagia2004 Jun 18, 2009
    the sound is still on, just the picture goes off.
  • Sonny Berry
    Sonny Berry May 11, 2010
    When you say the picture goes off. Do you just loose the picture and still have sound? Or is it dead with no picture or sound? Let me know and I will assist you to determine whats wrong. Please respond to this same post.
  • Zenith Master
  • 8,617 Answers
Check the Vertical output IC and the Solder connections on the Vertical deflection yokes. Bad solder on the yoke plug connectors will cause the same symptom, and the Vertical IC may just need to be resoldered as thats fairly common with that model.
Posted on Jun 18, 2009
SOURCE:
WHENVER I PLAY AUDIO CD / VIDEO CD WITH DVD-FP580 DVD PLAYER, TV STARTS FLIKERING AND CD TRACK JUMPS AND DVD GOES OFF AUTOMATICALLY. I AM SURE MY TV IS O.K. BUT IT SEEMS THERE IS PROBLEM WITH DVD-FP580...
Ask for a repair man to check it. There is a problem on the circuit that the dvd player system detects and automatically shuts off to avoid further damage.
Oct 21, 2010 | Samsung Televison & Video
My Zenith 50 in. tv won't come on, it went out yesterday. When you push the the power button, it flashes green for a few seconds then goes to the red off button.
it's your power supply that has gone. I had the same problem after owning my LG Z50PX2D for 2 months. The repair shop had it for 6 months. now I have the famous "POP & BLACK SCREEN SICKNESS" LG/Zenith should fix this.
Jun 11, 2009 | Zenith Z50PX2D 50 in. Plasma HDTV
We were watching tv and all of a sudden we heard a
I had the same problem. We replaced the Y Sustain board. It was under $200 and not at all hard to do yourself. Remove the back of the tv. Make sure you watch what screw goes where. You will see the board on the left side. The number should be on the bottom right corner of the board. Just watch how you removed the board making small notes as to what goes where. Its really not that hard and you can save 600$ or more
Jun 06, 2009 | Zenith Z50PX2D 50 in. Plasma HDTV
Zenith tv picture jumps after 20-30 min.
the variations of the supply causes that. a verticle stability be checked, specially semiconductors and capacitor changing valuas
Q= CV
Q=IT
THEREFORE
IT=CV=Q AND frequincy = f=i/t
so if I AND T CHANGES CAUSING MOVEMENT OF PICTURE
SO I is for time and T for tempareture
Mar 28, 2009 | Zenith B25A02Z TV
Static Sound along with Static/Jumping Picture.
this is just the tuner and it can be replaced or it just needs some soldering but i fix these and i can tell you it sounds like the tuner is failing and needs replaced , the tuner can be about $80 and the repair can very between 50 -$60
hope this info is worth a fixya as other ratings only hurt our rating
and if you need more assistance I'll be glad to help
electech
Nov 27, 2008 | Zenith C36A26 36" TV
Logik lt2974 small picture
the problem is in the verticle section, if you are a technician check a verticle IC and a capacitor of that stage. to allocate a verticle stage follow 4 cables coming down from deflection coils, two of these wires goes near transformer, this is horizotal and the other two goes near an IC this is verticle. positive idea.
Nov 22, 2008 | Zenith B25A02Z TV
Zenith E44W46 Audio works - intermittant picture
i hava a Zenith Model # E44W46LCD telivision. There is a light blue line about an inch or 2 wide running across the bottom of the screen. The TV is about 4 years old. It doesn't get a lot of play probably less than 10 hours a week. can you help me
Jul 18, 2008 | Zenith E44W46LCD 44" Rear Projection...
Junk TV & Poor service
zenith agreed today to replace mine.
Mar 12, 2008 | Zenith Z50PX2D 50 in. Plasma HDTV
Loud electrical sound in rear of set(tv)
Sounds like the High voltage is leaking out and arching somewhere. Have a look in the back and see where it is BUT be CAREFULL!! This is enough voltage to cause serioud harm to you. If you have no TV repair experience, this is not the repair to start experiementing with. Play it safe and call out a pro to assist you. Good Luck.
Mar 31, 2007 | Zenith R40W46 40" Rear Projection...
Toshiba 42H81 - Constant jumping picture on scren
it needs the hyper module replaced might as well have em do the stk packs too its too old to be a lemon the part that was replaced was not new it was in someone elses tv and had problems there too the trick is to find someone that will fix it so it lasts
Dec 05, 2006 | Toshiba 42H81 42" Rear Projection...
Zenith IQC60H94W 60" Rear Projection Television Logo
161 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
