Question about southland Garden Cultivator Tiller S-cv-43 -
Need a gas cap for a200781 - southland Garden Cultivator Tiller S-cv-43 -
Why does gas cap light come on?
You need to check the seal on gas cap. If its bad then get a new cap or replace seal. Gas cap may also have a hairline crack. Lasty rotate cap back n forth to reset seal as a starter. Simple fix
Aug 18, 2015 | Ford Expedition Cars & Trucks
How to replace gas cap
Step 1 - Determine Your Type of Gas Cap Before acquiring a new one, think about whether you need a gas cap that locks to prevent a gas thief from stealing your gas. But keep in mind, if you put one of these caps on your car, your spouse or children who put gas in your car will need the gas cap key.
Step 2 - Remove the Cap Retention Ring When you actually replace your gas cap, you may need to remove a retention ring that keeps the cap attached to your car. If you do, you can remove it simply by using a pair of needle-nose pliers. Just slip one tip of those pliers under the ring edge; then close the pliers and pull the ring off the old cap and slip it over the new cap.
Step 3 - Check the Warning Sensor Light Your car may have a sensor light that will illuminate when you change your cap. If so, drive your car a few miles to see if the light goes off. If it doesn't, see your repair mechanic to fix the problem
Aug 17, 2015 | 2002 GMC Envoy
Gas cap stuck won't come off?
Grab a pair of channel locks to get a good grip on the cap and twist counter clockwise. The back pressure created in the tank from the gas depleting can make the cap seem impossible to remove.
Jul 16, 2014 | 2001 Oldsmobile Alero
Gas cap
Carolyn
You may need to press down and twist the gas cap at the same time..similar to a "child safe" bottle of asprin or medicine. Usually you remove it counterclockwise
Then when you put gas cap back on press down and turn it clockwise to seall the vacuum in the gas tank.
Many newer cars have this gas cap feature
Mar 31, 2014 | 2004 Pontiac Grand Prix
My check gas caplight on ,i tight my gas cap
Sound like the seal on the gas cap has failed. You will need to replace the cap.
Dec 26, 2010 | 2005 Ford Focus
Gas cap warning light is on. Gas cap is tight.
If the cap is tight then you need to replace the fuel cap. the light will go off when cap is replaced
Jul 13, 2010 | 2000 Dodge Caravan
Check Gas Cap alarm comes on and engine light is on
You gas cap is not on tight enough to seal causing the Check Engine Light to come on. When you tighten your gas cap you need to tighten it until it clicks at least 5 times, if it is tight than the seal on the gas cap may be bad. Replace with a OEM GM gas cap or a quality replacement that meets OEM specs.
Jun 16, 2010 | 2004 Pontiac Grand Prix
Check engine light is on and where the milage goes it says gas cap
Your gas cap is loose and setting a code, may need to replace cap. When you tighten gas cap turn cap slowly it may seal better. You should feel it turn before it starts to click..
Feb 23, 2010 | 2006 Chrysler Pacifica
Light on my dashboard
ford taurus's are well known for this. the seal on the gas cap goes bad. before you replace the gas cap make sure when you close the gas cap you are turning it at least 5 clicks. if light stays on get a new gas cap. they are easy to install all you need to do is remove the gas cap.remove the gas cap strap. put ******** the new cap, close cap and turn 5 clicks. not clicking 5 time can set a p400 or p401 evap code causing the check enging /ses light to come on.
Apr 19, 2009 | Ford Taurus Cars & Trucks
southland Garden Cultivator Tiller S-cv-43 - Logo
66 people viewed this question
Top southland Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a southland Garden Expert? Answer questions, earn points and help others
