Question about Bell 2012869 Rampage Bike Chain And Lock Black
Need key for bell rampage bike lock
Lost keys need replacement
I lost my key for pulsar 150.i want to take it to a work shop.i kept it at railway station. How can i start the bike without the key.can anyone help.plzzz
Hammer a flat bladed screw driver into the lock and turn it with a pair of locking grips. Replace lock and key.
Jan 22, 2017 | Motorcycles
Which other years have the same lock set as a 2005 CBF600?
I'd try and ring your local bike shop to find out.?
or take the lock barrel out and get a lock smith to cut a key for it.
good luck........
May 19, 2014 | 2005 Honda CBF 600
Giantco hunter ignition lock
hi there try ringing a locksmith and see if he can do it on the bike for you or more than likely you will need to take it to a locksmith or try taking it to the dealer that sell them and get him to cut a key that the lock has a number on the back of it cheers pete
Dec 03, 2013 | 2008 Giantco Hunter Sport 200
I lost my yamaha r15 bike key
I had the same problem with my ZX10R losing the master key to which all other keys need to be coded from and I am assuming that Yamaha might use a very similar system in which the key gives off a signal that is picked up from your bikes electrical system even before the key is placed into the key barrel if your key is not chipped and is a regular type key then one can be cut fairly simple or replace the key barrel with a new one and set of keys . But if you have lost the master key that codes all other keys for your bike then it can become a very expensive job running into the thousands of dollars easy because replacement of the security system that is integrated into the whole bikes computer and electrical system is a very complex and expensive system to replace . There are key coders that you might be able to use costing a few hundred dollars instead of thousands of dollars and without the need to replace your bikes whole security system as well as people that offer the service to recode your keys depending on the difficulties of your system . You will need to start looking on youtube for methods or devices or people that offer that type of service and start by searching for lost key transponders or key codes and then finding out if your system is compatible and can be given a new code and set of keys hopefully this will be the case because there isn't much of away around other than the very expensive total system replacement of your bikes security system . I have lost my master key and can not get any replacements cut and I have lost nearly all of the copied spare keys that were originally coded from the master key so I have attached a key permanently hidden on my bike that the transponder can pick up as a signal and I use a normal key to fit in and turn the key barrel as normal without the fear of losing the coded key , as well adding a few anti theft devices of my own like a hidden cut off switch , disc brake lock with alarm etc so I can make key copies at any key cutting place for a few dollars .
Nov 28, 2013 | Yamaha YZF-R15 Motorcycles
I lost my key to my bike and I spoke with a locksmith and he told that I would have to take the ignition out in order for him to replace or make me a new key so I was trying to figure out how to do so
Before you attempt to take out the ignition, call a dealer and ask him if they can get you a key for your bike by using the VIN as reference. Harley and some metrics can do it this way.
Apr 19, 2011 | kawasaki GPZ 500 S - GPX 500 R Motorcycles
Lost key to "81" honda goldwing GL1100 standard
hi, you are more likely to find the key code on 1 of the other locks on the bike like the seat lock, if you can remove the seat, and the lock, in the old days manufactors would put the code on the lock normaly wher you cant see it a good locksmith will make you a key if you take him the lock, paul
Jan 18, 2011 | 1981 Honda GL 1100 Gold Wing
I just bought a mosketo scooter and lost the key within days of purchase. of course only one key came with...so a friend said i can drill into the keyhole and then i will never need a key again!!!(nor will...
Stop right there.If you brought the bike from a dealer then tell them you lost the key .if it was a private sale then there nothing you can do. But if I was you .I would try finding a frendly mechanic and tell him you lost the key and he may be able to find an old key that will fit . As for drilling out the key lock ,Remember that if your bike gets stolen the insurance company will not pay you ouy .if you have to bypass the switch lock remove the whole lock and put a on off switch in the wires coming out the rear of the switch .
Mar 20, 2010 | 2004 Factory bike Chrono SM 250
NEED TO HOTWIRE A 1983 RAMPAGE
You'll still need to unlock the steering wheel and shift lever. This can only be done with the key or by breaking the collar for the keyswitch. Either it is very difficult, and best left to the hands of a proffesional.
Oct 08, 2009 | 1984 Dodge Rampage
I LOST MY KEY TO MY BIKE, AND I DONT HAVE THE TITLE TO IT HOW CAN I GET A NEW KEY FOR IT?
Take the ignition lock out and have a locksmith make a new key for it. If the ignition key also unlocks another part of the bike (e.g. a helmet lock or security lock) it's often easier to remove one of those. I'm assuming you don't have this problem as a consequence of stealing the bike ;-)?
Jun 04, 2009 | 1997 Suzuki GSF 1200 Bandit S
Bell 2012869 Rampage Bike Chain And Lock Black Logo
Top Bell Cycling Experts
dante
Mark Wolfe
Donald Ayers-Marsh
Are you a Bell Cycling Expert? Answer questions, earn points and help others
