Question about Cycling
Chain keeps coming off Baja mini bike
Chain keeps falling off the mini bike what is causing it? how do we fix it
5 Suggested Answers
ftw1952
  • 10319 Answers
SOURCE: We have an 18" boys huffy bike and the chain keeps...
If a single speed bike loosen the rear wheel and pull it back away from the pedals to get the chain tighter
If it has multi gears the arm hanging down has a ser screw that will need to be adjusted to align the chain to stop at the last gear
Posted on May 22, 2010
  • 9 Answers
SOURCE: I'm trying to find out what 97cc converts to in
The short answer is about 15 to 17cc = 1 hp or about 1 cu.in. = 1 bhp for a modern car. An accurate answer depends on many factors, rpms, type of hoursepower, how the moter is tuned, fuel, etc. In the case of your motor probably around 5 to 7 hp.
Posted on Jul 12, 2010
dunnbiker
  • 8546 Answers
SOURCE: How do you adjust the
http://www.parktool.com/blog/repair-help/categories/derailleur-systems
Posted on May 22, 2011
dunnbiker
  • 8546 Answers
SOURCE: CHAIN KEEPS FALLING OFF ROADMASTER
As "roadmaster' doesn't really narrow it down much perhaps a generic web search for "chain falls off bike" would work for you. YOU can see your bike. We can't even tell if its a single- or multi-speed.
Posted on Sep 22, 2011
Need to find out the year of this Baja mini-bike
Hi, Jimmy for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
ID year of Baja Mini Bike DIY Go Kart Forum
MINI BIKE PICTURES
OldMiniBikes com
Baja Motorsports
Nov 03, 2016 | Electric Razor Pocket Rocket Scooter Mini...
Baja warrior 196cc mini bike engine torque specs ???
Hi, Randall for more information about your question and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
Baja MB 200 Operator Manual
Baja Mini Bike Parts Baja Heat Parts Baja Mini Baja Parts
Mini Bike Easy Governor Bypass 1080P
http://docsfiles.com/pdf_baja_bike_manual.html
Mar 22, 2016 | Motorcycles
My Baja 196cc takes off when I start it don't know why just that the bike was given to me recently, no manual
Hi, Jeff your mini bike has a centrifugal clutch and the previous owner may have tried to modify/bypass the governor for more speed if not done properly it will give you the undesired result which can be easily fixed by watching the video below I am sorry you can't find the first and best tool you ever bought for your Baja but despair not for a mere $0 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.Mini Bike Easy Governor Bypass 1080P
http://www.bajamotorsports.com/system/documents/86_OWNERS_MANUAL_-_WR65_Warrior_Mini_Bike_US_VIN_prefix_LUAH_.pdf
Mini Baja 6 5hp motor or other problems on 4Strokes com Forums
Jan 01, 2016 | Motorcycles
How do I start a baja mini bike when I havent started it since fall
drain oil -- put fresh oil in it -- drain gas -- put fresh gas in it -- charge battery if it has one -- and it should start
Feb 26, 2015 | Motorcycles
How do i fix the rear sprocket on my huffy rock it bicycle
on all single speed bikes, it has been my experience, that chain tension is the reason for the chain to come off, try tightening it again, since this seems to keep happening the chain may be stretched out now and replacing the chain and getting it tight should solve the issue.
Apr 30, 2014 | Huffy BMX 20" Boy's Rock It Bike
My mini baja 196cc starts great, but once i start going and i pull the throttle the power doesnt go directly into the bike. I think some thing is wrong with the chain.. To explain it better when i pull the...
It's something related to the clutch.
Key fell out. Clutch failed.
You should be able to see the crankshaft spinning in the clutch housing if it's the key missing.
Probably have to disassemble the clutch to find the problem otherwise.
Jan 26, 2018 | Scooterx Go Kart Clutch 5 8 Bore 41 Chain...
I havent started my baja mini bike since last fall and now it wont start it seems to be not getting any gas
Chances are the carb is plugged up with stale gas. The carb will need to be disassembled and thoroughly cleaned, including all passages.
May 20, 2010 | Mini Motorized Bike
Chain keeps fallin off!
Does the rear wheel go on such that you can adjust it to take any play out of the chain? If so, turn the bike upside down or put it on a bike stand. Loosen the back wheel and pull it so that the chain is tighter and then tighten the wheel. There are other possible causes but I suspect this since you recently removed the wheel. Also I'm not sure how often the chain falls off. If this doesn't work, ask again and let us know how often its coming off. Good luck!
Mar 15, 2010 | Schwinn Windwood 26 Women s Cruiser...
My mini baja dirt bike has an oil leak how do i fix it?
if its coming from the plug on the bottom which is the only way i can see is a messed up gasket
Sep 07, 2009 | Trango Team Losi 1/18 Mini-monster Baja...
Cycling Logo
48 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
