Question about Honeywell Warm Mist HWM-2030 Humidifier
HWM 2030 humifier parts
Require an element for this model. Please advise if it is available.
4 Suggested Answers
  • 23 Answers
SOURCE: Is there a version of the manual for my Honeywell
Go to this website: http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000006709.pdf this is the .pdf user's manual for the Honeywell/Kaz model HWM-2030 warm mist humidifier.
Ken
Posted on Jan 20, 2011
  • 23 Answers
SOURCE: Honeywell Warm Mist HWM-2030 how to clean it ?
Just uploaded the user manual to this site, which contains the cleaning instructions. You may also download the manual directly here: http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000006709.pdf
kcomp1863
  • 23 Answers
SOURCE: Warm Mist HWM-2030 Humidifier: DOES NOT GIVE OFF VAPOR...
If the unit runs normally otherwise, but doesn't give off vapor, then your heating element is the culprit. i.e. if fan runs, switches in normal positions, indicating lights on, etc.and restart slide switch depressed and no mist, then, yes the heating element is the source of the problem. It may be bad, or otherwise it may just be scaled up from hard water, and require cleaning.
You may refer to your users manual, or if you no longer have a copy, you may download one at this link: http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000006709.pdf
Hope this answers your question.
kcomp1863
Is not producing the mist
Most misting humidifiers use an atomizer to generate the mist. It is a small metal disk that vibrates very fast. I have yet to see one of these that ever lasts more than a year or two. If you remove the water container you should be able to see the atomizer. If you can put you finger on it and it isn't vibrating then thats the problem. On most small humidifiers it is cheaper to buy a new one that to try and get it fixed.
Dec 16, 2012 | Honeywell Warm Mist HWM-2030 Humidifier
The humidstat light is on when I first try to get humidifier going.
This is normal, based on where you have the humidistat knob set to, it will go out only after reaching the humidity level set on the knob. Also if you have it setting in a fairly large open area of your home, it may take a loooong time to reach the proper humidity level. My cousin has one of these units setting in his living room, which has a cathedral ceiling, the unit's humidistat light never goes off, and the unit runs continually, unless the resevoir runs low. But the unit operates fine.
Hope this answers your question. You may refer to your user's manual regarding this, or if you don't have a copy, you may download one at this link: http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000006709.pdf
kcomp1863
Nov 30, 2010 | Honeywell Warm Mist HWM-2030 Humidifier
kcomp1863
May 18, 2010 | Honeywell Warm Mist HWM-2030 Humidifier
Start switch doesn't work
the switch is bad or there is a loose wire connection, if you have a multi-meter you can check the resistance on the switch, it should be 0.0-0.2 if the switch is good it could be the pump.If the pump is bad don't bother fixing it.
Feb 06, 2010 | Honeywell Warm Mist HWM-2030 Humidifier
Have a warm air Honeywell humidifier. The "refill/restart" button is permanently on even if I refill the humidifier and the humidifier does not want to work now. How do I fix this? It seems a sensor is...
This may be due to one of two things.
1. If you turn the unit off or unplug it when you refill the resevoir, then plugging back in or turning it back on will not automatically reset the refill sensor. You must depress the restart slide switch on the bottom front controls to reset and restart the unit, or.....
2. It the refill light won't clear after refilling the resevoir or following the above step, the most likely cause of the problem is a scaled up heating element, which must then be cleaned.
I just uploaded a copy of the user manual to this site, but if you would like to download it directly, follow this link: http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000006709.pdf
Hope this helps!
kcomp1863
Dec 03, 2009 | Honeywell Warm Mist HWM-2030 Humidifier
I don't know how or what to clean it with.
Just mosted the user manual to this site, which contains the cleaning instructions. Also, you can download the manual directly here: http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000006709.pdf
kcomp1863
May 18, 2009 | Honeywell Warm Mist HWM-2030 Humidifier
Need Replacement Tank for HWM-450 humidifier not under warranty
the website that you can go to to order is www.appliancefactoryparts.com. type in your model number, clickon a picture once it loads and then scroll down the page until you see water tanks. right now the price is 39.99
Feb 24, 2009 | Honeywell HWM-450 4 Gallon Humidifier
kcomp1863
Nov 23, 2008 | Honeywell Warm Mist HWM-2030 Humidifier
Cleaning Light
Either you have a problem with the sensor or the control board. Try disconnecting the sensor and see if it come on. If it does change the sensor. If not it is the control.
Dec 21, 2007 | Honeywell HWM-330 3 Gallon Humidifier
Honeywell Warm Mist HWM-2030 Humidifier Logo
37 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
jdthefixer
Bill Long
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
