Question about GE Advantium 120 Convection/Microwave Oven
Zsc1001 display lights all on - nothing can be read
    Novelist:
    Scholar:
  • 166 Answers
Replace electronic display panel.
Posted on Apr 15, 2014
Why does light comes on turntable turns when door opens nothing lights on display or nothing works ?
Normally faulty micro switch which needs replacing: Caution: hight voltage may be present so best left to service person
Jul 23, 2014 | Oster Microwave Ovens
Microwave genius sensor 1300w
I don't believe it is possible to change the display angle/tilt on this microwave. The unit ships with a protective film over the display that should be removed to make the display easier to read. However, this model is known to be difficult to read unless looking at straight-on. That and needing a flashlight to look at your food with the door open since the internal light does not stay on when door is opened. Good luck!.
Jun 13, 2014 | Panasonic NN-SN657SMicrowave Oven
The display on my Sharp Grill 2 Convection Model R 82ojs-f is too dim to read.
either the display is bad or the unit may have a setting in the menu for adjusting the brightness level
Dec 04, 2012 | Microwave Ovens
Model jes636wk01 the readout display reads E 1 and none of the buttons work. I press clock and nothing...i press thaw and nothing...I press start and nothing...
This is a common 700Wcounter top oven with no special features, so honestly it will be more economical to replace it rather then repair it.
That said, you probably have a failed keypad.
Jan 18, 2011 | GE Microwave Ovens
Display works well but is very hard to read even in the dark.
UNFORTUNATELY THIS IS A COMMON PROBLEM..THEY HAVE 2 SEPARATE LIGHTS IN THESE DISPLAYS AND ONE HAS WENT BAD...UNLESS YOU CAN SOLDER AND FIND THE REPLACEMENT LIGHT BULB THE ALTERNATIVE FIX IS TO REPLACE THE DISPLAY CONTROL ON THE UNIT....PLEASE VOTE...GOOD LUCK TO YOU
Jan 03, 2011 | Microwave Ovens
Emerson Microwave stopped working
Have 1 of 2 choices, the main fuse or the control board for the front switches and clock. primary of the small power transformer has opened. Unplug the unit and take case off and measure the fuse with an ohm meter. if u read 1 ohm or less then fuse is good. then measure across the main power plug tips. If read open then the power transformer is bad. Need to replace the board as not sure if transformer is available.
Jul 26, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Replacing the cavity light on the g e advantiom zsc 1001
The bulb is a halogen type and there is a service kit that slighty changes the way it is mounted. It is not easy to get to from the top unless you do it for a living. Call GE Factory Service for the kit and a nice smiling technician to come out and take care of it. It may still be under warranty. 1-800-432-2737
Dec 16, 2008 | GE Advantium 120 Convection/Microwave Oven
Dim control panel unable to read
Removed the amber glass which obscures the display enough to remove the wiring from view. This also allows you to see the characters much more clearly. You now can see the inidvidual light elements.
It's not too bad, people don't even notice, but they do notice you can now tell the time and see what the oven is doing.
Nov 10, 2008 | Frigidaire Microwave Ovens
Nothing works, displays numbers 1 thru 4.
What you're describing sounds like a corrupted controller, or maybe there is some grease, etc. on the controller, maybe where the keypad plugs into the controller.
Can you post a video demonstrating what happens?
This sounds really odd!
Jul 19, 2008 | LG LMV1630ST Microwave Oven
Display panel reads "RESET" and keypad doesn't work
I believe I answered this, so pardon me if this is a dupe. It sounds like a problem on the control board. If it was stored in an unheated garage, shed, or other building, it could have some condensation deposits which could cuase corrosion on the circuit board. We repair these control panel assemblies nationwide for $32.50 and you can find out more through my listing here on FixYa: http://tinyurl.com/yzjozk If you have not tested and cleaned the keypad strip where it goes into the board, post back or e-mail me and I can give you instructions on that.
Jan 16, 2007 | GE JVM1190 Microwave Oven
GE Advantium 120 Convection/Microwave Oven Logo
35 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
