Question about Grilling
Master forge smoker manual
Why and how much water to put in the water pan located in the master forge electric wood chip smoker? do you put water in the pan at all or can you put another liquid in it?
  • 3 Answers
SOURCE: Have a brinkman all in one smoker but no instructions on how to use it
Put the briquettes in the bottom pan and put the wood chips around the outside edge. Put water in the top pan. All this must be done before you light the charcoal. Using an electric lighter works best and won't change the flavor of your food like starter fluid will. After coals are lit, place meat on rack and seal everything up. Now you're Smokin'!
Posted on Jun 29, 2008
SOURCE: Don't know where to put wood chunks in a Char-broil electric h20 smoker!!
Dip wood chips/chunks in boiling hot water for a few minutes if you're in a hurry or allow to to soak in tap water for about an hour if you have plenty of time. Either way, place the soaked chips around and under the heating element at the bottom. Don't throw out the water; heat it up and pour it in the water pan. Heating it up to boil will give your smoker a good head start. I've been doing that on my char-broil smoker for years.
Posted on Jul 04, 2008
SOURCE: instructions on use o;f char broil electric h2o smoker vintage 2000
please send me instructions
Posted on Sep 21, 2008
SOURCE: where do i put my wood chips? under the heating
Buy some lava rocks from your local hardware store. Get just enough to cover the coil with 1 layer of rocks. This will help control and retain the heat produced by the coil. Now, just throw a couple chunks of pre-soaked wood on top. I recommend hickory or cherry...never mesquite, it is way too harsh for slow smoking. Happy smoking!
Posted on Sep 06, 2009
SOURCE: Where to put the wood chips in my gas smoker
you soaked the wood chips in water for about 30 min. shake excess of water and place them on the flame disk bowl right under the water bowl.
Posted on Aug 15, 2010
Can I use the wood chip pan directly (not the side chute)?
It is a big process it has 7 steps they are as follows
  • 1
    Soak hardwood chips in water for at least 30 minutes and up to 2 hours for larger chunks. Drain them completely before adding to the smoker unit. Use 1 1/2 cups of wood chips when smoking for less than 3 hours. For longer cooking times use 3 cups of wood.
  • 2
    Place the bottom unit that contains the heating element on a sturdy surface, away from flammable materials. Make a foil pouch containing the wood chips and punch a few holes in the top. Place this pouch onto the pan containing the heating element. The chips can be added directly to the pan, but the foil pouch makes cleanup easier.
  • Place the large water pan onto the unit and fill it 2/3 full of water or apple juice. The water or juice will moderate the temperature and provide moisture for the cooking food.
  • 4
    Add the cooking grates to the top of the unit and close the lid to allow the unit to preheat.
  • 5
    Place the food on the preheated grates and cook until done. Keep the lid closed as much as possible to maintain the heat. Open the vent on the top of the lid to allow the smoke to escape.
  • 6
    Check the water level occasionally by opening the door on the side of the Charbroil Electric Smoker unit. Add more water as needed.
  • 7
    Add more soaked wood chips after a few hours if the smoke begins to die away. This is optional; the chips provide flavor but are not necessary for cooking the meat.
  • Performance Chip
    May 22, 2012 | Old Smokey Electric Smoker
    How do I smoke in this Smoker/Grill? Like where do I put the Smoker chips there is no smoker chip box, just the pan for the charcoal and a pan I think for water.
    Hi karin 1967...
    To use your Brinkman Smoker or Other Smokers
    1... Marinate or place a rub on the meat you will be smoking, and let it sit for a few hours or overnight in the refrigerator.
    2...Cover your wood chips with water(and if you wish you can add some Jim Beam Whisky or other flavorfull liquids in a bowl with the water, 1 inch above the wood chips and use a flat peice of metal (pie pan,etc.)to weigh the wood chips down underwater.
    You will do the wood chips at least 24 hrs before you plan to start smoking this gives the wood time to soak in the flavorfull liquids.
    3...Start a fire in the smoker having the fire below the meat, but do not put the meat on yet, wait till the flames die down first.
    Once they are coated with gray ash, you can place the meat on the racks and add your soaked chips to the smoker.
    I would place an aluminum drip pan under the center portion of the cooking area on your smoker, to catch the juices from the meat if you are not using a water pan in that position.
    4...Place the meat in the smoker on the grilling surface, and place the wood chips over the charcoal and hardwood in the main grilling area Close the lid and do not open it unless you must add wood chips during the cooking process.
    5...Continue adding wood chips to the tray as needed during the time you are cooking.
    If you have a Brinkmann or other smoker with one chamber for placing the wood chips and the meat, add wood chips only once per hour.
    6...Apply your sauce to the meat one hour before the meat should be done.
    Test your meat with a thermometer for for an internal tempreture of 160 degrees for medium and 170-180 degrees for medium well to well
    Note: Apply the sauce quickly to avoid loosing the heat in your smoker if you leave it open too long it will allow the heat and smoke to escape, increasing the cooking time.
    Close the lid if it needs to continue cooking till you reach the right internal tempreture
    7...Test your meat with a meat thermometer after a few hours of cooking time.
    Make sure your meat is at least 160 degrees internal tempreture for medium and more than 170 degrees for medium to well.
    Close the lid and maintain your heat if it needs to continue cooking.
    Please take time to rate me.
    Sep 24, 2011 | Brinkmann Smoke 'n Grill Double-Grill...
    I am new to smoking. I have the Masterbuilt 30 inch electric smoker (model 20070410). When do you use the water tray - put water in it. I know to use the wood chips, but when should I add water to the...
    According to Masterbuilt, you should use water all the time. It pan should be filled the the lines indicated on the pan, prior to turning the smoker ON.
    Hope this helped you and thanks for choosing FixYa.
    Aug 13, 2011 | Masterbuilt Electric 30inch Smokehouse ...
    In the water pan, do you just add water or can you put some wood chips with the water? i want to smoke a boston ****. should I put it in fooil or cook unwrappped?
    No, the water pan is just for water. The pre-soaked wood chips go in the charcoal bowl on top of the heated charcoal. Putting the wood chips in the water bowl with water in it, would serve no purpose as far as adding a smokey flavor is concerned. If you desire a smokey flavor, do not wrap the **** in anything.
    In case you have misplaced your owner's Manual, I have included a link to it that you can download and print for future reference. http://images.brinkmann.net/docs/pdf/810-5301-C.pdf
    I hope this helps you, to further your enjoyment of using a smoker. Thanks for choosing FixYa.
    Jul 25, 2011 | Brinkmann Smoke 'n Grill Double-Grill...
    Where does the wood chips need to be placed in the smoker?? I don't see a chip pan.
    If you don't have the wood chip tray, you're sitting dead in water, at this point. The wood chip tray goes above the burner, below the water pan. If this is a brand new, just purchased smoker. Go back to where you purchased it or call the number in Owner's Manual for "Parts missing". If it's not brand new, you can purchase a smoker tray from Masterbuilt Customer Service 1.800.489.1581
    Hope this helped you.
    Jun 27, 2011 | Masterbuilt 20050106 Propane Smoker
    Where do I put the wood chips on this propane Masterbuilt smoker??
    After soaking the chips in water, they should be placed on the wood chip tray, above the burner, but below the water pan.If you're using the water pan.
    Jun 22, 2011 | Masterbuilt 20050106 Propane Smoker
    How many hours do you you season the smoker initially before putting food items in it? do you put water in the pan for the initial smoke? and how many hours will it take to smoke a turkey?
    It takes three hours on medium setting to season the smoker. During the last 3/4 hour of seasoning, add 1 cup of wood chips to the wood chip box. Let the chips soak in water for a half hour prior to using them. Once three hours is up, turn off, unplug and let the unit cool off.
    Feb 13, 2011 | Masterbuilt Electric 30inch Smokehouse ...
    Have this smoker but really dont no how to use it where do i put the wood chips do i put them in the pan with the water our do i put them on the plate please help me with this
    Page 3 on this link shows the wood tray and explains the water tray. Wood chips are soaked to make them last. They will still go pretty fast but you can add more. Soak the chips or chunks overnight.
    http://www.charbroil.com/bps/char-broil/char-broil/knowledge/06701311_assembly%20manual.pdf
    Jun 10, 2010 | Char-Broil Electric H2O Smoker
    Jul 02, 2008 | Char-Broil Electric H2O Smoker
    Apr 06, 2008 | Rocky Mountain Range Outfitter 12" - OFTR...
    Grilling Logo
    73 people viewed this question
    Top Grilling Experts
    paulcarew
    Gary Kenady
    Gary Kenady
    Dan Webster
    Dan Webster
    Are you a Grilling Expert? Answer questions, earn points and help others
