Question about Whirlpool Washing Machines
Whirlpool LXR9245EQ2 tub won't fill at beginning of cycle
Whirlpool LXR9245EQ2 top loading washer For some strange reason, when I started the washer this morning, it went straight to agitating instead of filling with water first. I tried changing the cycle, even tried putting it on a rinse cycle, still no fill. Changed the size of the load, no fill, but when I moved it while the cycle was agitating, the water started flowing as the size knob was between sizes. I was able to hold it there while the tub filled and get my load completed, but I can't do this for every load. Is this something I can fix myself? Payday isn't until the 1st.
  • 6,784 Answers
HI, you have a combination issue. the Water fill level pressure switch and, the cycle selector switch are both damaged and, they should be replaced. the total cost of these switches will run you about $90.00.
We recommend the hands of a skilled service tech when repairing this type of electrical issue.
Posted on Jun 18, 2009
Whirlpool top loading washer won't fill completely
did you shorten the stand pipe for the outlet drain ?if not try putting a short extension on the top .
Nov 18, 2017 | Whirlpool Washing Machines
Whirlpool top loading washer, LXR9245EQ2, quit agitating, spinning and makes a clacking noise, pump looks like it's still holding the water in the tub though and won't pump out?
There are two clips that hold the pump to the motor, remove it and inspect, turn pump axle in either direction. If not replace the pump. However if you remove it you may find a sock or something in which case you can remove item and put back into service. If jammed you need to replace with a new pump. Good luck, masta tech
P.s.if water remains in tub it has something blocking it, be ready to capture any water in tub when removing hose clamps. If it a small amount you may be able to just lean it backward to hold water.
Aug 21, 2011 | Whirlpool LSR5132PQ Top Load Washer
Whirlpool LXR9245EQ2 top loading washer tub won't fill
try taking the knob off and see if the nut is tight on the timer,it might if came loose
Jun 18, 2009 | Whirlpool Washing Machines
Maytag Atlantis MAV6200AWW Washer Problem?
I HAVE AN ATLANTIS MAYTAG WASHER . I HAD THE SAME PROBLEM AND I SOLVED AS FOLOLWS. REMOVED THE MOTOR, I APPLIED GENERAL PURPOSE GREASE ON BOTH SIDES OF THE SLIDING MOTOR SURFACE PLATE (MOTOR BASE) . THE GRASE HELPS THE MOTOR TO SLIDE BECAUSE AS YOU KNOW THE MOTOR DOES NOT HAVE ANY ADJUSTMENT. TRY IT PLEASE . GOOD LUCK
Feb 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Cold cycle does not work
hey thats crazy.anyway first things first.water passes through the fill valve.in the valve[ where the black fill hoses attach to your washer] are screens that stop minerals from going into the valve itsself and blocking up the valve internaly.i know its going tobe tough[trust me i've done 100s]but its how your complaint is solved 99 out of 100 times.you turn off the water remove the cold hose and clean the cold fill screen.also while the hose is off flush it into a bucket or the washer tub[wont hurt a thing]make sure you put the screen back into the valve.so next time valve wont get harmed.if the screen is clean and you have water at the cold facuet at the washer.you could have a bad valve.that would be a voltage check.we wont go there now.if you still need help you can email me thru fixya.hope this helps. God bless ,tom
Jan 08, 2009 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool LSB6300 died mid-cycle now only clicks
HOPE THIS WORK, DON'T FORGET TO RATE ME
  • Timer is fried.
  • Washer went off-balance and tripped the off-balance switch.
  • Dec 28, 2008 | Whirlpool LSB6300PW Top Load Washer
    Washer Will Not Fill
    Could you retype this to better describe?
    Feb 24, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
    Washing Machines Logo
    185 people viewed this question
    Sal De
    Marvin
    Marvin
    Gerry Harvey
    Gerry Harvey
