Question about Amana Refrigerators
Amana refrigerator asd2620hrb defrost timer - Amana Refrigerators
22yooper
  • 828 Answers
SOURCE: Defrost timer
http://www.us1internet.com/FRS24XGCW2_141846.htm
The above URL will take you to an exploded view of the controls. Look at number 23 which will be located behind toe plate below door on the left side. That is the defrost timer. Rotate the clutch head screw Clockwise SLOWLY until you hear a loud click. That is the defrost timer starting the defrost. If the unit restarts after 18-22 minutes and defrost does not take place you problem is most likely the defrost thermostat.
Posted on Jun 20, 2008
  • 93 Answers
SOURCE: Need to Replace Defrost Timer
check bottom back left should be a small hole with a small plastic place to turn with a srew driver some are insidethe fride on the left side arond where the lite is if you see a mall plate with a srew open it it should be there thanks from gilles
Posted on Mar 15, 2009
  • 531 Answers
SOURCE: Location of Defrost Timer
you unit do not carry it carry a board it at the back off the unit
Posted on Apr 01, 2009
  • 401 Answers
SOURCE: Defrost timer went bad. How do I manually bypass the timer?
IF ITS A DEFROST TIMER AND NOT A BORD THE WIRES ARE HEATER POWER COMPRESSOR THEN NEUTRAL IS ALONE.
I I I I
HPC N
GOOD LUCK!
ERIC
Posted on Jan 17, 2010
Testimonial: "I connected a jumper from the compressor to the power and I'm back in business. I'll have to find a new timer in the morning. Thank you!"
SOURCE: Where is the defrost heater timer located on an
It is located behind the lights under the light cover
Posted on Jul 03, 2010
ASD2620HRB
I think the best way to answer your question is to provide you with an Amana=> ASD2620HRB Parts List If you do not have Adobe Reader Click=> HERE Once you have the PDF open I want you to go to pages 22 and 36. The defrost heater is installed just like the parts/evaporator, clips are shown where the defrost has to mounts it to your evaporator. Then go to page 36 and bottom right corner of the diagram shows two different colors of wires. The brown wire makes a loop through one side of the defrost thermostat. The orange wire connects to the other side of the defrost thermostat and the orange wire also connects to the defrost heater. Please ask should you have questions and please rate my solution, Thanks Sea Breeze
ASD2620HRB Parts List.PDF
Nov 15, 2012 | Amana Side-By-Side Refrigerator 26 cu. ft....
Can not initiate defrost on amana asd2620rb
in the freshfood area there is your control assembly..the defrost timer located in there..there will be a round hole with a knob that has a slot in it..insert your screwdriver and turn clockwise until you hear refrigerator go off. this will put you into a defrost...if all is well and working ok..just replace timer....
if it goes into a defrost ,but will not come on..the defrost thermostat is most likely bad..these refrigerators have bad defrost t/s for some reason, but not always is it this fault...check your heater with a multi-meter and if okay...bypass the defrost thermostat..if its bad...this will let the heater come on..do not leave this circuit bypassed for any reason..if is a safety feature and will let the heater stay as long as its in defrost.....just replace this part ad all will be ok
Nov 28, 2010 | Amana ASD2620HRB Side by Side Refrigerator
Where is defrost timer on amana arrccb
The ice in the ice tray freeze together as if they melted for a time then refreeze. It appears to maybe be a defrost problem. Can I adjust the defrost cycle on My Amana Bottom Freezer Refrig?
Nov 01, 2010 | Amana ARB224RCC Bottom Freezer...
My Amana refrigerator defrost timer is supposed to cycle every eight hours. Instead it takes about 14 hours to cycle around back to the defrost mode. The defrost mode does last for the proper 20 minutes....
Relax, some people exagerate was all I was saying.
Anyhow, go to a good parts store and ask for a Supco EDT (Electronic Defrost Timer) replacement as they are more reliable and not much difference in price.
May 15, 2010 | Amana ABB1921DE Bottom Freezer...
Amana br18v1w bottom freezer iced up will not defrost
rotate defrost timer till compressor off
does it defrost if no then
jump out defrost t-stat (round disc)
if starts to defrost Replace defrost t-stat
if yes replace defrost timer if not turning
Oct 24, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Stuck in defrost mode after changing timer and thermostat
Amana adaptive defrost:
Press refrigerator light switch five times in six seconds to initiate defrost cycle. Pressing five more times within six seconds will cancel defrost and go straight into the run mode. Similar operation on both bottom mount and SxS refrigerators. After the defrost terminator/thermostat opens, six minutes of dwell time occurs before the compressor and condenser fan motor will operate. After defrost terminator/thermostat open, 10 minutes of dwell time occurs before the evaporator fan motor will operate.
May 05, 2009 | Amana 25.8 cu. ft. Side-by-Side...
Refrigerators Logo
15 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
