Question about Hotpoint Ariston Aquarius WD420 Front Load All-in-One Washer/Dryer
My nob on the dryer is broken how can i find a replacement? It has a crack on the inside
    Problem Solver:
  • 7 Answers
Keep a look out for hard rubbish, I found knobs for my gas heater someone was throwing a model that was not the same but close, and they work.
Posted on Apr 15, 2014
I have a hotpoint Aquarius 1000 Washer/Dryer model number wd23w had it about 15 i used the dryer for first time and now everytime i put on a wash as soon as it is finished it goes straight on to dryer
Hi
you will prob find the knob for the dryer has broken
so you turn the knob but it doesn't turn the switch
remove the knob which just pushes on and pulls off
and look at the shaft of the knob you may see it has cracked
if you do just replace the knob and you should be fine
Jul 01, 2016 | Hotpoint Washing Machines
One of the nobs on the front of my gas stove is broken and i would like to know where i might get a replacement on ? the burner still works if i push the nob back on and turn it but it is broken in half...
Hello Danny, I have seen replacement knobs at Home Depot and Lowe's Hardware. Write down the make and model number of your stove and take a knob with you to compare.
Mar 24, 2015 | Kitchen Ranges
GE Front load Gas Dryer Model GTDP490GDOWS won't turn on
Remove the timer nob see if it is cracked, replace it with another nob or use pliers to turn the timer see if that works
Aug 26, 2014 | Dryers
Frigidaire dryer not drying clothes
did u clean out the vents inside and the hose vent leaving the house? if so then, it could be the control nob
Jun 07, 2012 | Frigidaire Dryers
My dryer is knocking.
Most of the time a "clunking" or "knocking" dryer is caused from a cracked drum (the actual area that the clothes sit in) It is usually a broken weld or simply a cracked drum. You will need to peek inside the dryer with a flashlight and look for a crack in the drum area.
Mar 23, 2011 | Amana Dryers
Does not run, power to dryer light on inside set dry time and turn start nob, does nothing.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 28, 2010 | Dryers
Nob for setting time keeps ticking after dryer has stopped cycle
the timer dial you set is at fault. A replacement will be needed soon for it will just quit some day soon
Jun 30, 2010 | Dryers
The off/on pull switch appears to be broken. I suppose we need a new part and someone to help me. Will you please advise? Thank you. Bill Anderson
If your handy enough to attempt to replace the control timer yourself..You can start by unplugging the dryer first and removing the screws on the rear of the control panel...You'll then need to slide a flat screw driver under the clips located on the left and the right sides of the panel that attach to the top lid of the dryer... its a little tricky but you'll figure it out... once inside the control panel remove the nob from the timer and remove the wiring clip attached to the timer...remove all the screws holding the timer in place on the panel...A new timer could cost up to $85.00 it depend on the model...Good luck
Apr 20, 2010 | Kenmore 64902 Electric Dryer
Refrigerator temperature was turned down to lowest number (1) and now the refrigerator will not come back on and chill inside when temp dial is increased to higher #'s. Light is on so it is plugged in.
Repalce the thermostate nob which has teeth to hold the nob in desired level. Due to constant usage of turning the nob it would have broken. Please replace the thermostate nob and do not change the setting on and often to avoid such situation. It wil take care of itself without turning it on our own.
Jul 07, 2009 | Refrigerators
Dryer will not stay on.
Hi, It sounds like the start winding in the motor has gone bad.
How old is this unit?
If I can get a model#, I will look up the motor and the cost for you.
Thanks
Vic
May 27, 2009 | Dryers
Hotpoint Ariston Aquarius WD420 Front Load All-in-One Washer/Dryer Logo
23 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
