Question about Verbatim 97472 Keyboard & Mouse
Mouse is working but keyboard is not - Verbatim 97472 Keyboard & Mouse
Windows update = dead mouse
Try using a usb mouse and keyboard.Your computer should already have drivers for these devices loaded.
Apr 08, 2010 | Dell Wireless Keyboard Optical Mouse w0147
My logitech wireless mouse works but the wireless keyboard does not. When I try connecting the keyboard the mouse stops working. I can get the mouse working but can't get the keyboard working. The only key...
The keyboard is not recognized by your PC. By the way, do you have the software installer for your keyboard.? Run the installer in your PC, and try again
if it now recognize the keyboard.
Sep 24, 2009 | Logitech Wireless Access Duo Optical...
Logitech CE0560 keyboard and mouse; first keyboard
First put new batterys in the mouse and key board. if you don't have a tester use a flashlight. pen light. push the remote pickup. light will blinknext push key board button and the mouse next. then try it and see if it works.
sometimes do the mouse first, Then the key board
Aug 10, 2009 | Computers & Internet
Keyboard only works if mouse isnt working and vice versa
does it come with a synchronization or reset button? try it...usually press the one on the receiver first then with the mouse and keyboard.
Aug 10, 2009 | Logitech Cordless Desktop Optical Y-RK49
Cordless access duo, mouse won't work
please go on control and look mouse setting and correct it. and also look battery of mouse, if not work there is hardwere fault. (nepal)
Jul 11, 2009 | Logitech Wireless Access Duo Optical...
Can't get cordless mouse and keyboard both working. Can only connect one or the other.
disconnect the small wireless dongle from the back of your computer..reboot the computer..put it back in,,and then press the connect button on bothe mouse and the keyboard to check,,the battery of teh mouse and the keyboard shud be checked if possible
May 08, 2009 | Logitech Wireless Access Duo Optical...
Logitech MX3200 Wireless keyboard works but mouse does not
i have the same wireless keyboard. i suggest that u redothe setup process and setup the mouse first. if the problem persist then move the wireless scanner.
Apr 10, 2009 | Logitech Cordless Desktop MX3200 Keyboard...
Keyboard Problems
Unplug the mouse and connect the keyboard where the mouse was connected check if that works, can you go into the bios with that keyboard ? if no then you might need to but windows with a ps\2 keyboard and installs the usb drivers for the keyboard that doesnt work.
Nov 25, 2008 | Dell Computers & Internet
Mouse does connect but keyboard does not, vice versa
reinstall the logitech cd which came with keyboard and mouse, with the mouse pluged in. once reinstalled restart and while restart plug the keyboard in..... this should resolve the issue.
May 29, 2008 | Logitech Cordless Desktop MX 5000 Laser
Logitech cordless mouse and keyboard installation
You probably already done this but try pressing the receiver button and while it is flashing turn the board over and press the small reset/connect button on the bottom of the board and also the reset/connect button on the bottom of the mouse. It should work okay after that. here is hoping that helps. Bud
Dec 20, 2007 | Logitech Cordless Desktop MX3200 Laser...
Verbatim 97472 Keyboard & Mouse Logo
Top Verbatim Computers & Internet Experts
Martin Murray
Computer Links
Marcin
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
