Question about Mio Cyclo 300
Mio cyclo 305 wont sync - Mio Cyclo 300
Mio Cyclo 315 touchscreen detect problem.
Perhaps it doesn't care which corner you press if it works leave it alone Or Return it to point of purchase
May 20, 2015 | Mio GPS
Mio s555 wont load after accepting safety agreement
Connect to a PC and save the contents to the PC.
Format your Mio and copy back the contents.
Dec 18, 2014 | Mio GPS
Pure Evoke Mio Portable wont pick up all stations
check manufactures spec and try a factiry reset
Sep 02, 2014 | GPS
Mio cyclo 305HC "MIO Dodge v2.0 Application error, please restart. Same message appears after every restart.
I had the same problem and followed Mio's advise on formatting etc. but without any result. The errors kept popping up. Figured maybe a corrupt backup might be the source of this.
So I looked for the backup location and deleted that before formatting the device. This worked for me.
The backup location can be found:
C:\Users\[username]\AppData\Local\CycloAgent\temp\
Aug 24, 2013 | Mio Cyclo 300
How to set time on my echo-7 cyclo computer, this is the older type echo-7 not f7, and it has 1 function button colored yellow at the bottom and you access all ..odo dst rt clk ..etc.
Hi, I got the same cyclo computer. Put the cyclo with the yellow button on the clock (CLK). Press shortly the reset button on the backside. The hour digit starts to flash. You can adjust the hour by shortly pressing the yellow button. If you want to switch to minutes hold the yellow button until the minutes starts to flash. When done press again shortly the reset button on the backside. When pressing the reset button the cyclo will start at zero seconds.
Bob
Mar 13, 2012 | Cycling
How to connect Mitac Mio P550 to a PC?
if you have xp you will need to download microsoft active sync from www.microsoft.com and if you have vista you will need microsoft sync centre, these will be the latest versions and should work fine good luck
Aug 08, 2009 | Mitac Mio P550 Pocket PC
The gps wont start
Have you checked the fuse in the charger?
Aug 28, 2008 | Digi MIO Walker 136 GPS Mobile Navigation
Broken 22 Pin,sync,charge,connector
Here's a solution for the broken socket on Mio 168 and Medion Micromaxx mdppc150 clones. Cheers
Mar 17, 2008 | Mitac Mio 168 Pocket PC
Active sync
you must resolder the charging connector, or you can put in a service
Oct 20, 2007 | Mitac Mio 168 Pocket PC
Mio Cyclo 300 Logo
43 people viewed this question
Top Mio GPS Experts
Tre Elkins
Michael Vincent Cruz
k24674
Are you a Mio GPS Expert? Answer questions, earn points and help others
