Question about LG BH6720S 1000W 3D Wi-Fi Smart Bray Home Theater System [BH6720S]
Closed captioning ************
How to get rid of closed captioning
If pressing the cc button on the Sharp remote does not turn off the closed captioning then the closed captioning is most likely coming from the cable box or whatever you have connected to this television. You can go into the cable box menu by pressing the menu button on the front when it is turned off. That's right turn off the cable box and then press menu on it to access the hidden menu that includes closed captioning. Scroll down to closed captioning and scroll over to disable. A number of other Directv receivers have the CC located on a "captioning" tab on the "display" page under setup and for dish network:
Setting Closed Captioning:
  1. Press and release the MENU button and then select "Preferences."
  2. Select "Closed Caption."
  3. Select "Caption On/Off."
  4. Select "CC is On."
  5. Select "Done."
Sep 20, 2011 | Sharp Televison & Video
How to turn off the close caption on tv
Hello
Not all TV programs and product
commercials are made with
Closed Caption (CC) information
included. Neither are all Closed
Caption modes (CC1, or CC2) necessarily
being used during the transmission
of a closed caption program.
Refer to your area's TV program listings
for the stations and times of
Closed Caption shows.
To close the close caption display from screen; press "CC" button on the remote control.
Jul 08, 2011 | Philips Magnavox 20MT133S 20" TV
I haven't been able to put closed captioning on tv. I don't understand how and what code to use to get the closed captioning to work.
Enable Caption Using the Original Remote
  1. Press the [CCD] button to change the CCD mode.
  2. Using this button will set the Closed Caption mode when viewing a DTV or TV channel.
Enable Caption Using the TV Menu
  1. Open the Menu screen, select the third icon, in the middle, this is the Setup Menu.
  2. In the Setup Menu, choose the Caption option.
  3. Caption: There are three items in it - Analog Closed Caption, Digital Closed Caption and Digital Caption Style
  • Analog Closed Caption: CC1, CC2, CC3, CC4, TEXT1,TEXT2, TEXT3, TEXT4.
  • Digital Closed Caption: Service1, Service2, Service3, Service4, Service5, Service6.
  • Digital Caption Style: There are two Caption Styles. One is the automatic function set as the broadcaster, while the other is the custom style where you can adjust the font size, color, opacity, background color etc., accordingly.
Mar 10, 2011 | Element ELC-HS321 32 in. LCD TV
How do I turn off closed caption?
Hello
From the main menu, surf though and enter the closed caption window. Here you can see options for Analogue closed caption, Digital; closed caption and Caption style to select. Here select "OFF" for both analogue closed caption and digital closed caption option.OK.
Refer to your TVs user manual. If you haven't its user manual, inform me though Fixya. Send your email ID too. OK.
Feb 14, 2011 | Hannspree XV32 32 in. LCD Television
I need closed caption
Tv air broadcasting shows have to say it,to have closed captioning or have to have a white small sign that said CC to be able to get closed captioning ok.Look for it in ur remote there a button that said CC pushes that button go to CC1,2,3..now u will get closed captioning.Or go into ur tv Menu find closed captioning functions turn it on like CC1,2,3...or Text 1,2,3.. on.Now ur tv are ready to get closed captioning,for the tv air broadcasting shows,that have closed captioning.
Dec 10, 2010 | Broksonic TV
How do I get closed captioning on a Samsung TV model TXJ2754?
Hello
Your TV displays the closed captions that are broadcast with some
television shows. These captions are usually subtitles for the hearing
impaired or language translations. All VCRs record the closed caption
signal and most pre-recorded commercial video tapes provide closed
captions. Check for the closed caption symbol in your television
schedule and on the tape's packaging: .
1 Press MENU repeatedly until you see the Setup menu. Press CH
to select "Caption."
2 Press VOL+ to open the Closed Caption menu.
3 Press VOL + to turn closed captioning on.
Misspellings and odd characters can occur in captioning. Also, there may be a
captioning delay after changing channels. Neither situation is a TV malfunction.
4 Press CH to highlight "Mode." Press - VOL or VOL + to choose
"Capt." (captions) or "Text." In caption mode, captions appear and
cover a small portion of the picture. In text mode, information unrelated
to the program, such as news reports, are displayed and
often cover a large portion of the screen.
5 If you wish, use CH , CH , or VOL + to change the captioning
channel or field. Then, press DISPLAY to return to normal viewing.
 Different channels and fields display different information, such as additional
languages or supplemental information
Nov 23, 2010 | Samsung TXJ2754 27" TV
Need to know how to put the tv on close caption
Captioned programs are marked in TV listings by "CC". so press the cc button on the remote and the closed caption option will be applied.press that cc button again to turn off the closed caption option.
1) Check the size and manufactured year of your television. If it was made after 1993 and is larger than 13 inches, it has a closed captioning system built into it. Otherwise, you may need to purchase a separate closed caption system, which are available at a number of online outlets.
  1. 2)Turn on your TV and access the menu for closed captioning. The precise location of the menu varies by television set. Most are accessible by pressing the "Audio" or "Set Up" menu on your remote, then scrolling down to the "CC" or "Closed Captioning" option. Check your owner's manual for precise instructions.
  2. 3)Turn the closed captioning option to the "On" position. It will then run closed captions for every program that broadcasts them. Newer sets may allow you to adjust the size, font and colors of the closed captioning letters to fit your individual tastes.
  3. 4)Tune to a particular program for a few minutes to make sure the closed captions are working. Note that while many broadcasts run closed captioning, not all of them do. If the captions don't appear, check your TV listing to ensure the program includes them.
  4. 5)If you're watching a DVd on your TV, access the DVD's "Set Up" menu. It should have captioned options, which allow you to show captions in English and possibly other languages as well.
  5. thanks.
Nov 11, 2009 | Televison & Video
Closed caption
Are you talking computer or TV?
Closed caption on a TV is when the volume is muted and it prints the speech in a box on the screen. You have to turn it on in the menu.
Nov 27, 2008 | Computers & Internet
Closed caption
There are external close caption boxes that you can add to your system. But be aware: many cable boxes do not process the close captioning information "through", forcing you to use the close captioning on the cable box.
Dec 02, 2007 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
Closed Captioned
Assuming whatever your TV receiving from has close caption. (Not all TV channel has close caption) Solution 1) Get a new universal remote that support your model and has close caption button. Once you program in the code for your TV model and it works then all button should also programmed including th close caption button. Solution 2) Search online for the owner manual and read see how to turn it on using buttons on TV (if possible). Solution 3) Get new TV with close caption. (If you have an old old TV with bad and huge pixels then this solution is the best. Your eyes will thank you.)
Aug 25, 2006 | Panasonic CT-32G11 32" TV
LG BH6720S 1000W 3D Wi-Fi Smart Bray Home Theater System [BH6720S] Logo
24 people viewed this question
Computer Repairing
Computer Repairing
